    Yes,
    specifically, the Lua vm is embedded via a Python library (Lupa), and because it brings in the standard Lua vm (there are many choices) as a binary, it links with it's standard C libraries like normal (ex. C string functions).
    However, a standard Lua interpreter seems to pick up the LC_CTYPE when running and setting that for the C library. The Lupa embedding didn't, and it wasn't documented what I could see
    This really is impressive work. What stands out to me is not only the amount of code, but - maybe mainly - the fact that project appears as structured, intentional.
    Edited by Łukasz997
    Well, it's my 4th attempt to create a HC3 emulator / developer tool... :-)
    v1.3.2 released - lots of potential bugs squashed...
    New library, speed.lua that can be used in the emulator to run code faster than realtime.
    It intercepts setTimeout and setInterval and the various debug functions so it runs everything as fast as possible ,just bumps the virtual time logged.
    We need to call fibaro.speedTime(hours, fun) on the main function that drives our timers.
    The --%%time directive allow us to start the emulator at a given date (works without the speedTime function)
    Really handy when debugging schedulers over weeks or months...
    • 1 month later...
    When I do >pip install plua -u, I am getting v1.3.11, not 3.1.2, Normal?
    Yes, made a couple of releases since 1.3.2…
    With the last version, I have now the following errors during the QA process in vscode:
    [06.06.2026][07:02:07][INFO   ][PLUA]: Starting helper server on 192.168.1.32 8082
    Fibaro SDK, online, (0.7281s)
    [06.06.2026][07:02:07][DEBUG  ][HOMETABLE5555]: ---- onInit() starts ----
    [06.06.2026][07:02:07][DEBUG  ][HOMETABLE5555]: QA HomeTable id:5555 starts
    [06.06.2026][07:02:07][DEBUG  ][HOMETABLE5555]: --------- onInit( ends --------)
    [06.06.2026][07:02:08][DEBUG  ][HOMETABLE5555]: ======================== update of HomeTable starts ========================
    [06.06.2026][07:02:08][DEBUG  ][HOMETABLE5555]: -------- Getting Device list --------
    [06.06.2026][07:02:11][DEBUG  ][HOMETABLE5555]: #devListAll 409
    [06.06.2026][07:02:11][DEBUG  ][HOMETABLE5555]: #devListVisible 409
    [06.06.2026][07:02:11][DEBUG  ][HOMETABLE5555]: #aQ less VoipUsers= 404
    [06.06.2026][07:02:49][DEBUG  ][HOMETABLE5555]: 156 Escalier_Grenier . Lum_Escalier_Grenier_ = 195
    [06.06.2026][07:02:49][DEBUG  ][HOMETABLE5555]: HomeTable[ Escalier_Grenier ][ Lum_Escalier_Grenier_ ] id= 195
    WARNING:plua.fastapi_process:\U0001f527 QuickApp 5555 not found
    [06.06.2026][07:03:09][DEBUG  ][HOMETABLE5555]: 248 Communs . Lum_Communs = 324
    [06.06.2026][07:03:09][DEBUG  ][HOMETABLE5555]: HomeTable[ Communs ][ Lum_Communs ] id= 324
    [06.06.2026][07:03:11][DEBUG  ][HOMETABLE5555]: 253 Grenier_Pignon . Lum_Pignon_Grenier = 329
    [06.06.2026][07:03:11][DEBUG  ][HOMETABLE5555]: HomeTable[ Grenier_Pignon ][ Lum_Pignon_Grenier ] id= 329
    But at the end of the QA process, the HomeTable is correctly created and also displayed in the webUI as a table.
    What can create such Warning message?
    Well, your QA seems to do some heavy processing (home table with 409 devices?) initially which keeps it busy.
    The web frontend meanwhile tries to call the Lua engine (your QA) to get the UI to display. It doesn't get it and logs the warning. It will retry and eventually it succeeds and everything should work. So it's harmless. Maybe the warning message could be more informative.
    (This has always been an issue if the lua engine is too busy to answer the frontend...)
    • 3 weeks later...
    @jgab please tell me what stupid thing I'm doing wrong. Running this from vscode terminal, project has .env file in root with the four required entries, checked and double checked.
    Quote
    PS C:\Users\mss\VSCode\ER7> pip install plua
    Requirement already satisfied: plua in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (1.3.11)
    Requirement already satisfied: lupa>=2.4 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from plua) (2.8)
    Requirement already satisfied: aiohttp>=3.10.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from plua) (3.14.1)
    Requirement already satisfied: aiomqtt>=2.3.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from plua) (2.5.1)
    Requirement already satisfied: fastapi>=0.115.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from plua) (0.138.1)
    Requirement already satisfied: uvicorn>=0.30.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (0.49.0)
    Requirement already satisfied: websockets>=13.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from plua) (16.0)
    Requirement already satisfied: httpx>=0.27.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from plua) (0.28.1)
    Requirement already satisfied: prompt_toolkit>=3.0.47 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from plua) (3.0.52)
    Requirement already satisfied: rich>=13.7.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from plua) (15.0.0)
    Requirement already satisfied: aiohappyeyeballs>=2.5.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from aiohttp>=3.10.0->plua) (2.6.2)
    Requirement already satisfied: aiosignal>=1.4.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from aiohttp>=3.10.0->plua) (1.4.0)
    Requirement already satisfied: attrs>=17.3.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from aiohttp>=3.10.0->plua) (26.1.0)
    Requirement already satisfied: frozenlist>=1.1.1 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from aiohttp>=3.10.0->plua) (1.8.0)
    Requirement already satisfied: multidict<7.0,>=4.5 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from aiohttp>=3.10.0->plua) (6.7.1)
    Requirement already satisfied: propcache>=0.2.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from aiohttp>=3.10.0->plua) (0.5.2)
    Requirement already satisfied: yarl<2.0,>=1.17.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from aiohttp>=3.10.0->plua) (1.24.2)
    Requirement already satisfied: idna>=2.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from yarl<2.0,>=1.17.0->aiohttp>=3.10.0->plua) (3.18)
    Requirement already satisfied: paho-mqtt<3.0.0,>=2.1.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from aiomqtt>=2.3.0->plua) (2.1.0)
    Requirement already satisfied: starlette>=0.46.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from fastapi>=0.115.0->plua) (1.3.1)
    Requirement already satisfied: pydantic>=2.9.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from fastapi>=0.115.0->plua) (2.13.4)
    Requirement already satisfied: typing-extensions>=4.8.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from fastapi>=0.115.0->plua) (4.15.0)
    Requirement already satisfied: typing-inspection>=0.4.2 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from fastapi>=0.115.0->plua) (0.4.2)
    Requirement already satisfied: annotated-doc>=0.0.2 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from fastapi>=0.115.0->plua) (0.0.4)
    Requirement already satisfied: anyio in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from httpx>=0.27.0->plua) (4.14.1)
    Requirement already satisfied: certifi in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from httpx>=0.27.0->plua) (2026.6.17)
    Requirement already satisfied: httpcore==1.* in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from httpx>=0.27.0->plua) (1.0.9)
    Requirement already satisfied: h11>=0.16 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from httpcore==1.*->httpx>=0.27.0->plua) (0.16.0)
    Requirement already satisfied: wcwidth in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from prompt_toolkit>=3.0.47->plua) (0.8.1)
    Requirement already satisfied: annotated-types>=0.6.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from pydantic>=2.9.0->fastapi>=0.115.0->plua) (0.7.0)
    Requirement already satisfied: pydantic-core==2.46.4 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from pydantic>=2.9.0->fastapi>=0.115.0->plua) (2.46.4)
    Requirement already satisfied: markdown-it-py>=2.2.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from rich>=13.7.0->plua) (4.2.0)
    Requirement already satisfied: pygments<3.0.0,>=2.13.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from rich>=13.7.0->plua) (2.20.0)
    Requirement already satisfied: mdurl~=0.1 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from markdown-it-py>=2.2.0->rich>=13.7.0->plua) (0.1.2)
    Requirement already satisfied: click>=7.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from uvicorn>=0.30.0->uvicorn[standard]>=0.30.0->plua) (8.4.2)
    Requirement already satisfied: colorama in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from click>=7.0->uvicorn>=0.30.0->uvicorn[standard]>=0.30.0->plua) (0.4.6)
    Requirement already satisfied: httptools>=0.8.0 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua)(0.8.0)
    Requirement already satisfied: python-dotenv>=0.13 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (1.2.2)
    Requirement already satisfied: pyyaml>=5.1 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (6.0.3)
    Requirement already satisfied: watchfiles>=0.20 in C:\Users\mss\AppData\Local\Programs\Python\Python313\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua)(1.2.0)
    PS C:\Users\mss\VSCode\ER7> plua --version
    PLua 1.3.11
    PS C:\Users\mss\VSCode\ER7> plua --diagnostic
    Detected host IP: 10.76.10.41
    🚀 PLua version 1.3.11        │
    │ Python:3.13.14, Lua:5.5        │
    │ API:8080        │
    Diagnostic mode enabled. Running tests...
    ERROR:plua.cli:Engine error: ...thon/Python313/Lib/site-packages/lua/fibaro\emulator.lua:12: attempt to call a nil value
    stack traceback:
            ...thon/Python313/Lib/site-packages/lua/fibaro\emulator.lua:12: in upvalue 'loadLib'
            ...thon/Python313/Lib/site-packages/lua/fibaro\emulator.lua:132: in method '__init'
            ...rograms/Python/Python313/Lib/site-packages/lua/class.lua:7: in local 'Emulator'
            ...ograms/Python/Python313/Lib/site-packages/lua/fibaro.lua:8: in main chunk
            [C]: in global 'require'
            ...ms/Python/Python313/Lib/site-packages/lua/diagnostic.lua:5: in main chunk
            ...Programs\Python\Python313\Lib\site-packages\lua\init.lua:602: in main chunk
            [string "<python>"]:1: in main chunk
    Edited by StoreyWho
    It seems like plua is not correctly installed, some files like tools.lua (used by diagnostics) is missing.
    Try to do
    and then check if tools.lua is there
    Something like
    1.3.13 looking good, thank you 👍
    On 6/29/2026 at 10:46 AM, jgab said:
    Try plua v1.3.13
    Installed successfuly but I have at start this WARNING:
    PS C:\Users\bruvi> pip install plua -U
    Requirement already satisfied: plua in .\scoop\apps\python\current\Lib\site-packages (1.3.11)
    WARNING: Cache entry deserialization failed, entry ignored
    Collecting plua
    Installing collected packages: plua
      Attempting uninstall: plua
        Found existing installation: plua 1.3.11
        Uninstalling plua-1.3.11:
          Successfully uninstalled plua-1.3.11
    Successfully installed plua-1.3.13
    Any idea why or where is the issue?
    Quote
    Executing task: plua --fibaro -a 'downloadQA -1198:dev' dummy.lua
    usage: plua [-h] [-v] [--init-qa] [-e EVAL] [-i] [--telnet] [--loglevel {debug,info,warning,error}] [-o] [--desktop [DESKTOP]] [-t]
                [--nodebugger] [--nogreet] [--fibaro] [--diagnostic] [-l L] [--header HEADER] [--api-port API_PORT] [--api-host API_HOST]
                [--telnet-port TELNET_PORT] [--no-api] [--run-for RUN_FOR]
                [scripts ...]
    plua: error: unrecognized arguments: -a
     *  The terminal process "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -Command plua --fibaro -a 'downloadQA -1205:dev' dummy.lua" terminated with exit code: 1.
    Quote
    PS C:\Users\mss\VSCode\ER7> plua -tool downloadQA 1205
    🚀 PLua version 1.3.13        │
    │ API:8080        │
    [30.06.2026][21:57:58][ERROR  ][PLUA]: Unknown tool: 1205
    Collecting plua
    It's a pip error that the pip install cache was somehow corrupt However, it successfully installed plua-1.2.13 at the end so it should work. scoop installation of python keeps the cache under scopes somewhere...
    You can try
    >pip cache purge
    The cmd line flag for plua to run a tool is -t (or --tool)
    The VSCode.md file was outdated, fixed it now.
    My task file to download a QA from a VSCode task looks like
