Hey Jan,
Thanks, MQTT is back !
However {allowUnauthorized=true} and / or {rejectUnauthorized=falseTLS options ais not accepted in PLUA. the same code work in native fibaro quickapp.
The battery only accept MQTTS connnection and is using a self-signed certificate.
Return the following error.
    Ok. pushed a new version of plua.
    This should work now:
    Hmmm thanks, but not working at all ;-(
    I checked both options.
    ERROR:asyncio:Exception in callback AbstractEventLoop.add_reader()
    handle: <Handle AbstractEventLoop.add_reader()>
    Traceback (most recent call last):
      File "C:\Program Files\Python313\Lib\asyncio\events.py", line 89, in _run
        self._context.run(self._callback, *self._args)
      File "C:\Program Files\Python313\Lib\asyncio\events.py", line 552, in add_reader
        raise NotImplementedError
    NotImplementedError
    ERROR:asyncio:Exception in callback AbstractEventLoop.add_writer()
    Downgrading to v 1.2.56 get back the connection error rejecting the certificate.
    NotImplementedError
    Ok, this seems to be a Windows issue... I don't usually run/develop on Windows so I may miss stuff like this.
    I made a patch for Windows in v1.2.58, try it and see if it works better...?
    Many thanks, it works on window too now!
    Good morning,
    In one application I have the following message from plua, no idea whats wrong:
    In turn, other application after a while of working ends with:
    and with Python crash. Python is 3.12.3
    With hc3emu - no such problems.
    Could you try to guide me whats wrong?
    Update: after upgrading to PLUA .58 second app throws this and crashes:
    Edited by Łukasz997
    The first error is an error from the HC3, are you trying to create an internalStoarge variable with strange characters?
    The second  error may be that 3.12 is a bit different and the lupa (lua python lib I use) was bit old.
    Try to do
    >pip install --upgrade plua
    so it updates to the new plua and the new libraries.
    Thank you for so quick reply.
    Actually, internal storage is used here. This is the name of internal storage variable:
    local LAST_GOOD_STATE_KEY = "__LICEMAN_LAST_STATE"
    I don't see anything wrong with it. On hc3emu and on the hub it works. However I eliminated underscores, shortened - and I saw:
    [10.03.2026][23:15:51][DEBUG ][PLUA]: Helper msg: [true,null,404]
    Regarding second: unfortunately, error persist after upgrade from 1.2.58 to 1.2.59
    Should I raise to the newest Python (3.14 or something)?
    For internalStorage you are not allowed to have a variable starting with "__"
    You get the error
    Wrong variable name format. Accepted format: [A-Za-z][A-Za-z0-9_]*
    Testing it on the HC3 you don't get the error, but the variable is not stored (silent fail)
    I have made fixes in 1.2.62 that will make the use of restricted calls more robust - it may have fixed some of your other problems.
    Let me know. If not, try to capture as much as possible  of the error message. Also if you have a small QA example that creates the error it would be good.
    (I tried to run some complicated QAs on my Windows machine Win11,python 3.13.7, and I couldn't get an SIGSEGV error)
    1. Thank you for the information about the naming convention - I didn't know that.
    With PLUA *.62 and without the "_" prefix, it works.
    2. This is a huge application (~5000 lines), so unfortunately I can't provide a minimal sample.
    Sometimes it looks like this might be a pcall-related issue: the application has a very large RefreshState handler section. Hub internally calls the handler in protected mode. The crash always happens right after (inside?) the handler execution. The handler completes its job (at last visible part) and then it crashes (+ Python crash). However, the same code works both on the HC3 and on the older emulator.
    At times I also wonder whether this could be caused by some interaction between the proxy or helper components of the two emulators. I currently have both installed because I'm trying to migrate to PLUA. The reason I'm thinking about this is that occasionally - not always - PLUA prints the following message:
    WARNING: Invalid HTTP request received.
    But this application does not use any communication of that kind (no remote calls, no HTTP).
    Additionally, I have an error from PLUA proxy quickapp: [11.03.2026] [12:35:16] [ERROR] [QUICKAPP1270]: End of file
    I have over 80 warnings from .venv/lib/python3.12/site-packages/lua (qwikchild, json, mobdebug).
    Honestly, I don't know what other hint I could give you. Maybe it's best to leave it for now. I can continue working with the old emulator and try again later. One last step - I will try to reinstall PLUA.
    Edited by Łukasz997
    The proxy error, is it in Plua or on the HC3?
    How does these 80 errors manifest themselves? logs?
    Proxy error is on HC3.
    These warnings (not errors) are listed in VSC windows PROBLEMS.
    Well, you see the whole development tree with a lot of test files... no worries for them. When I have nothing to do I may start to clean them up... I think there is a vscode setting that allow you to set directories that should be ignored for the problem report - in this case the .venv directory.
    I said that because I thought it might point you in the right direction.
    It can be excluded by adding section:
    in settings.json - for anyone user it may concern.
    plugin.restart()
    or
    api.post("/plugins/restart",{deviceId=self.id)
    Hello @jgab,
    regarding mentioned few posts before PLUA crash: please find included the python error report and the AI analysis of it.
    The analysis points more than less the issue - maybe it can guide you to a solution.
    Thanks for the report, try v1.2.63 that I uploaded and see if it fixes the problem.
    Indeed, the symptoms of the illness have retired - I am grateful.
    Fingers crossed... 😉
    Hello @jgab,
    unfortunately, I have another error. UpdateQA script does not work, not only generating error when uploading main file, but also deletes some files (until error) and leaves quickapp in a little "devastated" state. Additionally I would like to draw your attention to utf8 - library is present, but it name is not propagated to globals (_G). It's worth to include it there.
    Please see the picture. What could it be?
