    The command
    >plua --init
    will create a project setup in a new workspace for vscode.
    Besides choosing a QA template it will also install
    /.vscode/launch.json
    /.vscode/tasks.json
    The launch.json contains 2 different launch configs:
    -plua: Run Current Lua File with Debugger
    -plua: Run Current Fibaro File with Debugger
    The first config just runs a lua file without loading the fibaro APIs. The second expects the file to be a QA and will load the fibaro APIs and try to start QuickApp:onInit if it exists.
    Note that when pressing F5 or choosing "Start Debugging" in vscode, it will run the current chosen launch configuration. If that happens to be the first config, in this case, it will complain that there is no fibaro.* or api.* functions available.
    In vscode we select the launch config in the run and debug side panel.
    Good morning,
    I've noticed that:
    fibaro.getValue(1, "sunsetHour")
    stopped working on plua emulator (up to date version) - returns nil.
    With sunriseHour - the same.
    Sooner it's working on the emulator. On real box - it's working as well.
    7 hours ago, Łukasz997 said:
    Good morning,
    I've noticed that:
    That was a strange bug... the problem seems to have been there for a long time...
    Try v1.3.14
    hi @jgab,
    I just started a new QA for controlling a new High Loal module from Nice, id 818 and I am getting the following error when using fibaro.getValue(818;"name") or api.get("/devices/818"):
    Process started
    Detected host IP: 192.168.1.34
    │ Python:3.14.2, Lua:5.4                                                       │
    │ API:8080        │
    Fibaro SDK, online, (0.7574s)
        [C]: in upvalue 'original_error'
        [C]: in function 'xpcall'
        [string "<python>"]:1: in main chunk
    This is the first time I get this...
    F5 was with "Plua Run Current Fibaro File with Debugger"
    As the line print("sunSet at",fibaro.getValue(1, "sunsetHour")) is working now, I need to check if my request has the correct format...
    I have corrected the format of my requests and it is working now but I wonder why I did not get previous error message with line number where the error occurs.
    Edited by Christb
