    The command
    >plua --init
    will create a project setup in a new workspace for vscode.
    Besides choosing a QA template it will also install
    /.vscode/launch.json
    /.vscode/tasks.json
    The launch.json contains 2 different launch configs:
    -plua: Run Current Lua File with Debugger
    -plua: Run Current Fibaro File with Debugger
    The first config just runs a lua file without loading the fibaro APIs. The second expects the file to be a QA and will load the fibaro APIs and try to start QuickApp:onInit if it exists.
    Note that when pressing F5 or choosing "Start Debugging" in vscode, it will run the current chosen launch configuration. If that happens to be the first config, in this case, it will complain that there is no fibaro.* or api.* functions available.
    In vscode we select the launch config in the run and debug side panel.
    Good morning,
    I've noticed that:
    fibaro.getValue(1, "sunsetHour")
    stopped working on plua emulator (up to date version) - returns nil.
    With sunriseHour - the same.
    Sooner it's working on the emulator. On real box - it's working as well.
    7 hours ago, Łukasz997 said:
    Good morning,
    I've noticed that:
    That was a strange bug... the problem seems to have been there for a long time...
    Try v1.3.14
    hi @jgab,
    I just started a new QA for controlling a new High Loal module from Nice, id 818 and I am getting the following error when using fibaro.getValue(818;"name") or api.get("/devices/818"):
    Process started
    Detected host IP: 192.168.1.34
    │ Python:3.14.2, Lua:5.4                                                       │
    │ API:8080        │
    Fibaro SDK, online, (0.7574s)
        [C]: in upvalue 'original_error'
        [C]: in function 'xpcall'
        [string "<python>"]:1: in main chunk
    This is the first time I get this...
    F5 was with "Plua Run Current Fibaro File with Debugger"
    As the line print("sunSet at",fibaro.getValue(1, "sunsetHour")) is working now, I need to check if my request has the correct format...
    I have corrected the format of my requests and it is working now but I wonder why I did not get previous error message with line number where the error occurs.
    Edited by Christb
    In fact, I think that something went wrong during the last update as when launching a old QA code which was perfectly working before, I am getting the following message:
    Process started
    API:8080        │
    Fibaro SDK, offline, (0.3965s)
        no field package.preload['dkjson']
        no file 'C:/Users/bruvi/scoop/apps/python/current/Lib/site-packages/lua/dkjson.lua'
        no file 'C:\Users\bruvi\scoop\apps\python\current\dkjson\init.lua'
        no file 'C:\Users\bruvi\scoop\apps\python\current\..\share\lua\5.4\dkjson.lua'
        no file 'C:\Users\bruvi\scoop\apps\python\current\..\share\lua\5.4\dkjson\init.lua'
        no file '.\dkjson.lua'
        no file '.\dkjson\init.lua'
        no file 'C:\Users\bruvi\scoop\apps\lua\current\bin'
        [C]: in function 'require'
    I tried to reinstall plua and I am getting at then end of the TERMINAL log:
    Requirement already satisfied: colorama in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from click>=7.0->uvicorn>=0.30.0->uvicorn[standard]>=0.30.0->plua) (0.4.6)
    Requirement already satisfied: httptools>=0.6.3 in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (0.7.1)
    Requirement already satisfied: python-dotenv>=0.13 in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (1.2.1)
    Requirement already satisfied: pyyaml>=5.1 in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (6.0.3)
    Requirement already satisfied: watchfiles>=0.13 in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (1.1.1)
    WARNING: Ignoring invalid distribution ~lua (C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages)
    Do I have to reinstall everything using scoop?
    Good morning,
    I’ve encountered some unexpected behavior in PLUA. Is this a bug? In my opinion, it would be worth fixing.
    When selecting Run Task/upload current file as QA, if the file contains --%%file=... directives, the files are not loaded into the QA in the same order as the --%%file directives. This can matter. In my case, it did.
    However, if a project file is created first, which, to my knowledge, essentially means starting a debugger session, and then Run Task/update QA is selected, the files are loaded in the same order as the file directives.
    /monthly_2026_07/image.png.da49c0e7e58427ada2a6c544caf9fff2.png" />
