Btw, on Win11 download and installed the eventlogger and worked straight away! :D ( had the .env setup from the Homemap app) :D
This is alos an awesome toll @jgab!! :D
Also really nice that you can copy and paste the whole log into excel to store it! :D
Excel:
Edited by Brors94
    4 hours ago, Christb said:
    Hi@jgab,
    I have a password starting by # and I am working with Windows 10.
    I have not yet been able to have the HC3 Event Logger to connect (red dot on top right☹️)
    I had already a .env located in C:\Users\ASUS  root folder which has already HC3_URL, HC3_USER, HC3_PASSWORD correct lines so I have just added HC3_HOST=<HC3 ip address> and HC3_PROTOCOL=https lines. I tried also the powerSell method without success as I still have the following:
    603      console.log('Config from environment:', {
                        host: config.host || 'NOT SET',
                        user: config.user || 'NOT SET',
                        password: config.password ? 'SET' : 'NOT SET',
                        protocol: config.protocol || 'NOT SET (defaults to http)'
    Any idea why?
    1. First, verify the file location - In PowerShell run:
    echo $env:USERPROFILE
    This will show the correct path (likely C:\Users\ASUS)
    2. Check if the file exists there:
    Get-Content $env:USERPROFILE\.env
    This will show what's actually in the file
    3. Fix the password with quotes, # is considered a comment line otherwise:
    HC3_HOST=192.168.1.xxx
    HC3_USER=admin
    HC3_PASSWORD="#actualpassword"
    HC3_PROTOCOL=https
    Sorry @jgab I missed the above, just do it and now I can see the device in the floor and the HomeMap application stays connected😁
    /monthly_2025_10/image.png.f20fc2296950aa4879a5eb67197eb544.png" />
     when Edit Mode is off, the light can be changed from Off to On and reverse.
    Last question for today, is it possible to have the light_On icon with a bigger size than light_ Off icon? just fo more visibility
    You could create your own version of the light widget (light.json) and make it point to your own icons.
    You could also, if you have a smaller floor plan, zoom in to make the icons larger relative to the floorplan.
    A future version will allow you to add widget parameters to a device definition, so you could tell the built-in light widget to use your own icon set...
    But this is the wrong forum thread for HomeMap discussion :-)
