scheduler.lua
Repo & Code:
A Lua port of the Python
 library
by Daniel Bader  job scheduling for humans.
Designed for
 and Fibaro HC3 QuickApps,
but works in plain Lua too.
Why a port?
The Python schedule API is a fluent builder pattern that reads almost like
English. Lua's metatables (specifically __index as a function) let us
reproduce both the bare-property chaining (.minutes, .day, .monday) and
the method chaining (:at(...), :to(...), :tag(...)) without the user
having to type extra parentheses.
Two execution models are provided:
Mode Use when
Polling  schedule.run_pending() Plain Lua, your own event loop
Reactive  schedule.start() plua / HC3 / anything with setTimeout
Plain interval jobs are drift-free (anchored to their first scheduled
fire). Wall-clock anchored jobs (:at("HH:MM"), weekday jobs) are tied to
local time and self-correct.
Installation
plua / Fibaro HC3 QuickApp
There's no require in QA context, so scheduler.lua installs itself onto
fibaro.schedule when loaded via the multi-file directive:
Plain Lua
Differences vs. the Python original
  • No timezone support. All times use os.time() / os.date() in local
    time. The Python version's at(time, tz=...) is not implemented.
  • do is a Lua keyword, so the method is :do_(fn, ...) (with a
    trailing underscore) instead of Python's .do(fn, ...).
  • Property access uses ., not :. In Lua you cannot write obj:property
    without a call. So:
    • every().monday  (property)
    • every():monday  (Lua syntax error)
    • every().day:at("10:30")  (.day is a property, :at is a method)
  • Two execution models. The Python version only has polling. This port
    adds :start() / :stop() for native setTimeout-based scheduling.
  • until_() instead of until (Lua keyword).
Grammar / chaining cheat sheet
Singular forms (.second, .minute, .hour, .day, .week) require an
interval of 1; using every(2).minute raises IntervalError.
Weekdays require interval of 1 (every().monday, never every(2).monday).
at() format depends on the unit:
Unit Format
.day / weekday HH:MM or HH:MM:SS
.hour :MM, MM:SS, or :MM:SS
.minute :SS
until_(when) accepts:
  • a number — epoch seconds (large), or seconds-from-now (small)
  • "YYYY-MM-DD HH:MM:SS" (or without seconds, or just date)
  • "HH:MM" / "HH:MM:SS" — today
Examples
Time-based intervals
Wall-clock times
Randomized intervals
Sunrise & sunset
Sun events are computed per upcoming day (so future days use the correct
sunrise/sunset for that date, not today's value). On HC3 the location is read
automatically from api.get("/settings/location"). Elsewhere, set it once:
Then:
Sun-based jobs require interval 1 and either .day or a weekday property.
They return a useful next-run because _schedule_next_run scans the next 14
calendar days for the first matching event in the future.
Passing arguments
Tags & bulk cancellation
Self-cancelling job
Return schedule.CancelJob from the function to unschedule it:
Deadline
Inspection
Running
Multiple schedulers
The module-level schedule.every, schedule.run_pending, etc. all use a
shared default scheduler. You can also create independent ones:
API reference
Module-level (default scheduler)
Function Description
schedule.every([n]) Start a new job, returns a Job
schedule.run_pending() Run any due jobs (polling mode)
schedule.run_all([delay]) Run all jobs immediately, optionally with delay between
schedule.get_jobs([tag]) List all jobs (optionally filtered by tag)
schedule.clear([tag]) Cancel all jobs (or all with matching tag)
schedule.cancel_job(job) Cancel a specific job
schedule.next_run([tag]) Epoch of next run, or nil
schedule.idle_seconds() Seconds until next run, or nil
schedule.start() Begin reactive (setTimeout) execution
schedule.stop() Stop reactive execution and clear timers
schedule.jobs() Direct access to the list of jobs
schedule.CancelJob Sentinel — return from a job to unschedule it
Job methods (all chainable, return the job)
Method Description
:to(latest) Use a random interval in [interval, latest]
:at("HH:MM[:SS]") Anchor to a wall-clock time
:at_sunrise([offset]) Anchor to sunrise (offset in seconds, may be negative)
:at_sunset([offset]) Anchor to sunset
:at_sunrise_twilight([offset]) Anchor to civil-twilight sunrise
:at_sunset_twilight([offset]) Anchor to civil-twilight sunset
:tag(...) Attach one or more tags
:until_(when) Set a deadline after which the job is cancelled
:do_(fn, ...) Register the function and start the job
Job properties (no parens)
  • Units: .second(s), .minute(s), .hour(s), .day(s), .week(s)
  • Weekdays: .monday, .tuesday, .wednesday, .thursday, .friday,
    .saturday, .sunday
Scheduler class
schedule.Scheduler.new() returns a fresh instance with the same methods
as the module-level functions (using :), e.g. s:every(2):minutes,
s:run_pending(), s:start(), etc.
Sun helpers
schedule.set_location(lat, lon) Set the lat/lon used for sun calculations (auto-read from api.get("/settings/location") on HC3)
schedule.sunCalc([time]) Returns sunrise, sunset, sunrise_twilight, sunset_twilight as seconds-since-midnight on the local date of time (default os.time()). Returns -1 for an event if the sun never rises/sets that day.
Testing
QA_scheduler.lua exercises ~10 features and uses speed.lua (also in this
repo) to compress a 24-hour simulation into seconds by hijacking setTimeout
and os.time.
Credits
  • Original library:
     by
    Daniel Bader and contributors — MIT-licensed.
  • Inspirations cited by the original:
    • Adam Wiggins' "
    • The Ruby
       module
  • Lua port by Jan Gabrielsson, 2026.
  • jgab changed the title to Schedule lib
