  2. It used to be a bit random. It may be that after they fixed the QA file load bug some time ago that the order has become more predictable. However, if that was the case I would assume that they had a way to reorder the files in the edit UI ? ER7 uses a module system where each module sets a priority. < 0 loads before main code runs and > 0 loads after. There are many ways to solve it. As I proposed in the post 6 years ago we could agree about a model to make it easier to use each others modules, but there were no believers at that time.
  3. Yesterday
  4. If I'm wrong with my opinion, I think the load manager should be very easy to write. File ONE (file order - no matters): MODULES = MODULES or {} MODULES.database = function() --whole content of the module, even thousands of lines -- like: Database = {} local cache = {} function Database.read(id) return cache[id] end function Database.write(id, value) cache[id] = value end end File TWO (file order - no matters): MODULES = MODULES or {} MODULES.compiler = function() -- whole compiler content -- functions, locals end ...and all other files of the project. Finally, load manager: MODULES = MODULES or {} local loadOrder = { "database", "compiler", -- and more components in desired order } function QuickApp:onInit() for _, name in ipairs(loadOrder) do local loader = MODULES[name] if not loader then error("Missing module: " .. name) end print("Loading module: " .. name) loader() end MODULES = nil -- and more code of project end This ensures controlled order of loading. Name scooping behaves practically the same as not function-enclosed. * One trap: in each module do not forget final end
  5. I think we can assume that the files are launched in the same order in which they appear in the box interface. And what I described above seems to happen repeatedly.
  6. You can’t rely on the load order of QA files on the HC3. The only given is that :onInit() is called after all files are loaded.
  7. Good morning, I’ve encountered some unexpected behavior in PLUA. Is this a bug? In my opinion, it would be worth fixing. When selecting Run Task/upload current file as QA, if the file contains --%%file=... directives, the files are not loaded into the QA in the same order as the --%%file directives. This can matter. In my case, it did. However, if a project file is created first, which, to my knowledge, essentially means starting a debugger session, and then Run Task/update QA is selected, the files are loaded in the same order as the file directives.
  8. Last week
  9. In fact, I think that something went wrong during the last update as when launching a old QA code which was perfectly working before, I am getting the following message: Process started Detected host IP: 192.168.1.34 ╭──────────────────────────────────────────────────────────────────────────────╮ │ Python:3.14.2, Lua:5.4 │ │ API:8080 │ ╰──────────────────────────────────────────────────────────────────────────────╯ Fibaro SDK, offline, (0.3965s) no field package.preload['dkjson'] no file 'C:/Users/bruvi/scoop/apps/python/current/Lib/site-packages/lua/dkjson.lua' no file 'C:\Users\bruvi\scoop\apps\python\current\dkjson\init.lua' no file 'C:\Users\bruvi\scoop\apps\python\current\..\share\lua\5.4\dkjson.lua' no file 'C:\Users\bruvi\scoop\apps\python\current\..\share\lua\5.4\dkjson\init.lua' no file '.\dkjson.lua' no file '.\dkjson\init.lua' no file 'C:\Users\bruvi\scoop\apps\lua\current\bin' [C]: in function 'require' [C]: in function 'xpcall' [string "<python>"]:1: in main chunk I tried to reinstall plua and I am getting at then end of the TERMINAL log: ... Requirement already satisfied: colorama in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from click>=7.0->uvicorn>=0.30.0->uvicorn[standard]>=0.30.0->plua) (0.4.6) Requirement already satisfied: colorama in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from click>=7.0->uvicorn>=0.30.0->uvicorn[standard]>=0.30.0->plua) (0.4.6) Requirement already satisfied: colorama in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from click>=7.0->uvicorn>=0.30.0->uvicorn[standard]>=0.30.0->plua) (0.4.6) Requirement already satisfied: httptools>=0.6.3 in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (0.7.1) Requirement already satisfied: python-dotenv>=0.13 in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (1.2.1) Requirement already satisfied: pyyaml>=5.1 in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (6.0.3) Requirement already satisfied: watchfiles>=0.13 in C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages (from uvicorn[standard]>=0.30.0->plua) (1.1.1) WARNING: Ignoring invalid distribution ~lua (C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages) WARNING: Ignoring invalid distribution ~lua (C:\Users\bruvi\scoop\apps\python\current\Lib\site-packages) Do I have to reinstall everything using scoop?
  10. hi @jgab, I just started a new QA for controlling a new High Loal module from Nice, id 818 and I am getting the following error when using fibaro.getValue(818;"name") or api.get("/devices/818"): Process started Detected host IP: 192.168.1.34 ╭──────────────────────────────────────────────────────────────────────────────╮ │ Python:3.14.2, Lua:5.4 │ │ API:8080 │ ╰──────────────────────────────────────────────────────────────────────────────╯ Fibaro SDK, online, (0.7574s) [C]: in upvalue 'original_error' [C]: in function 'xpcall' [string "<python>"]:1: in main chunk This is the first time I get this... F5 was with "Plua Run Current Fibaro File with Debugger" As the line print("sunSet at",fibaro.getValue(1, "sunsetHour")) is working now, I need to check if my request has the correct format... I have corrected the format of my requests and it is working now but I wonder why I did not get previous error message with line number where the error occurs.
  11. 802.Growatt Open API v4 monitor & control for Fibaro HC3 Download v1.0.0: 802.Growatt_v4.fqa Marketplace link: https://marketplace.fibaro.com/items/802-growatt-api-v4 I'd like to share 802.Growatt v4, a QuickApp for Fibaro HC3 that discovers and monitors every Growatt inverter in a plant through the official Growatt Open API v4, and optionally lets you control them. What it does: - Discovers every inverter serial and exact device type in your Growatt plant/account (optionally filtered to one Plant ID). - Polls production data per inverter: current power, today/month/year/lifetime energy, PV1/PV2 input details when supplied by the API. - Creates stable standard meter child devices per inverter: <serial> Power, <serial> Energy Today, <serial> Total Energy, and PV1/PV2 power meters when available. - Parent device totals sum current power and energy across all discovered inverters, so the parent's Power/Energy properties represent the whole plant, not a single inverter. - Guarded write controls: Inverter On/Off, active-power limit (0-100%), and VPP charge/discharge target (-100% to +100%). All of these require a continuous 3-second hold on Apply before anything is sent, and every command is verified by reading the setting back afterwards. - Adaptive polling: uses your configured PollSeconds during daylight and automatically switches to a slower night interval between HC3's sunset/sunrise, capped so it changes exactly at the boundary. - Daily production stats: peak power with timestamp, first/last production time, duration, and a rolling history of completed days. - Highest combined AC output record since installation or last Factory Reset. - Optional fire-alarm safety action (Force ON/Force OFF) triggered by an HC3 custom event via EventLib. - Supports both Classic (HTML card) and New (physical label row) HC3 view layouts; switching is a 5-second hold on Change View. - Reinstall-safe configuration: on first install or reinstall, the QA restores BaseUrl/PlantId/DeviceSn/PollSeconds/AutoUpdateTime/debug (and the API token) from a same-plugin HC3 global-variable backup, written automatically once per day. On restore, the API token is written to the QA's own internal storage only, never back into the visible ApiToken QuickApp variable, so it doesn't show up in QuickApp-variable exports. Note the HC3 global variable used for the backup itself is still plain system-wide storage - see the README for the full caveat. Requirements: - Fibaro HC3 with internet access to the Growatt Open API. - A Growatt-issued Open API token (Growatt Cloud / OpenAPI access), entered once in the ApiToken QuickApp variable. - PollSeconds between 60 and 3600 seconds (default 300). - Growatt inverter (only tested with Neo 800) (https://server.growatt.com/) Setup is just: install the QA, fill in ApiToken, optionally PlantId/DeviceSn, and enable it. Everything else (child creation, discovery, view layout) is automatic. Keeping it up to date: This QA updates itself through jgab's QA Dist Manager - https://forum.fibaro.com/topic/80052-qa-dist-manager/. Install that QA once (any of jgab's or my other QA Dist Manager-enabled apps will detect it automatically, no configuration needed). After that, this QA's Updates section gives you: - Check Update: only checks whether a newer release is available, never installs anything. - Auto Update: installs the available release automatically at the time set in AutoUpdateTime (default 03:33). - Update Now: asks QA Dist Manager to install the available release immediately. If QA Dist Manager isn't installed, the Updates section shows "QA Dist Manager is unavailable" and update checks are simply skipped; everything else keeps working normally. Full technical documentation, API endpoints used, and behavior details are in the bundled README. Feedback, bug reports, and feature suggestions are very welcome here. Source code: https://github.com/Brors94/802.Growatt-v4 Support continued development: If you find this QuickApp useful, donations would be greatly appreciated. Contributions will help cover more AI token usage while developing, testing and improving this and future QuickApps. Donate through PayPal: https://www.paypal.com/donate/?hosted_button_id=VUADCH6HQCYM2 Disclaimer: this is an independent, community-made QuickApp. It is not affiliated with, endorsed by, or supported by Growatt, Shine, or any of their subsidiaries. "Growatt" and related names/trademarks belong to their respective owners. Use of the Growatt Open API is subject to Growatt's own terms and account permissions. Thanks for reading!
      • 2
  12. I agree, zigbee is not always stable - hopefully NICE will go finally to Alpha (not Beta)
  13. Hi, I run a SONOFF SWV (ID 260, battery-powered) for garden irrigation on Yubii Home Pro 5.210.12. Three months flawless — then two problems: Problem 1 — hub.call() fire-and-forget: After a command flood (watchdog sending turnOff 50x in 1h — my own bug), the valve stopped accepting any remote commands. Physical button and status messages still worked. Fix: batteries out for minimum 5 minutes (60 seconds not enough). Question: Has anyone found a way to make hub.call() more reliable for ZigBee battery devices? I now send turnOff 3x with 2s gaps — any better approaches? Problem 2 — Device parameters: The device JSON shows autoOffDefaultTime: 900 but the Auto-off toggle in Yubii is greyed out for this device. When the valve is open and I manually enable Auto-off, it works — but resets to off after the valve closes. Question: Is there any way to set device parameters like autoOffDefaultTime permanently via Lua (hub.call or API)? The device supports it — Yubii just won't let me activate it persistently. Setup: Yubii Home Pro 5.210.12 · SONOFF SWV · ZigBee · battery-powered
  14. Hi, Nice/elero has a very useful feature in Yubii Home Pro: "Synchronize all devices" which forces the gateway to actively poll all devices and update their status. ZigBee has nothing equivalent. There is no network map, no forced sync, no mesh heal — and the mesh heal function that existed in older firmware has been removed. Is there any plan to re-introduce a ZigBee mesh management tool — even a basic one? Active polling or a network map would make a huge difference for diagnosing ZigBee issues. Setup: Yubii Home Pro 5.210.12, 4 ZigBee repeaters, mix of battery and mains-powered ZigBee devices.
  15. # 804. History Charts and 992. InfluxDB 2 I have created two companion QuickApps for collecting and displaying historical Fibaro HC3 device values: - **804. History Charts** displays historical values as SVG charts directly in the Fibaro interface. - **992. InfluxDB 2** continuously sends selected HC3 device values to an InfluxDB 2 server for longer retention and more detailed history. This is something I know many people have missed on the Fibaro HC3. We can now keep long-term history, display it inside the HC3 interface and compare several devices in the same chart. I am also open to suggestions and improvements! 😄 History Charts can retrieve data from either the built-in HC3 history API or an InfluxDB 2 server. The source is selected with a switch, so History Charts can be used by itself or together with the InfluxDB 2 QuickApp. The QuickApps have separate responsibilities: - **992. InfluxDB 2** is the writer. It listens for HC3 device changes and stores them in InfluxDB. Download v1.0.0: 992.InfluxdbV2.fqa - **804. History Charts** is the reader and chart renderer. It can read either HC3 History or the values stored by 992 in InfluxDB. You do not need 992 or an InfluxDB server to use HC3 History mode. Install both QuickApps when you want longer retention and InfluxDB-backed charts. Download v1.0.0: 804.History_Charts.fqa ## Usful URL's Fibaro Marketpalce URL: https://marketplace.fibaro.com/items/804-history-charts https://marketplace.fibaro.com/items/992-influxdb-2 Github: https://github.com/Brors94/992.InfluxdbV2 https://github.com/Brors94/804.History-Charts QA Dist Manager by @jgab, for possible to update Quickapps from the QA itself Thanks for all your Nice Tools Jgab!! Couldnt have made this without them! To find my Quickapps add this quickappvariable manifest to the QA Dist Manager: https://raw.githubusercontent.com/Brors94/HC3Quickapps/main/dist.json ## What the QA can do - Load historical values from the HC3 history API. - Query historical values from InfluxDB 2. - Display up to six devices in the same chart. - Use separate left and right Y-axes when devices have different units, for example temperature and power. - Keep the last value as a continuous step line between recorded changes. - Draw a blue zero-reference line when the chart contains values above and below zero. - Show the minimum, maximum and mean value for every displayed device. - Use raw InfluxDB values for the displayed minimum, maximum and mean statistics. - Convert cumulative kWh counters to hourly or daily consumption and display them as grouped bars. - Keep the previous chart visible until a new request has completed successfully. - Restore the last aggregated chart after a QuickApp restart. - Store six favorite chart setups for frequently used device combinations. - Display the current HC3 energy tariff schedule as a virtual Tariffs device type. ## Device selection The QA loads the HC3 device catalog and provides two multiselect lists: 1. Device Types 2. Device List ## Date, time and scale controls The To date and time can be edited by selecting year, month, day, hour or minute and then using the minus and plus switches. Holding a switch accelerates the adjustment. The **Set To Time to Now on Load** toggle updates the To value immediately before history is requested. Available chart scales currently include: - Manual (default) - 1 hour - 1 day - 2 days - 1 week - 2 weeks - 1 month - 2 months - 3 months - 6 months - 1 year - This Year - Last Year - This Month - Last Month - This Week - Last Week - Today - Yesterday When Manual is selected, the Change switch cycles through ten editable targets instead of five. The first five edit To year, month, day, hour and minute. The next five edit the corresponding From values. Minus and plus, including held acceleration, work for both timestamps. The relative scales derive From from the editable To time. The calendar scales use exact local calendar boundaries and refresh automatically when history is loaded. Current calendar periods end at the current minute, while Last Year, Last Month, Last Week and Yesterday cover the complete previous period. The record limit can be selected from 2,000 to 100,000 records per device. A configurable 200,000-record ceiling applies to the complete load, so the effective per-device limit is reduced automatically when many devices are selected. ## Y-axis modes The chart supports four Y-axis modes: - **Auto** adds suitable padding around the observed values. - **Include Zero** keeps zero inside the displayed range. - **Fixed Range** allows the minimum and maximum bounds to be adjusted manually. - **Min / Max** scales directly to the observed minimum and maximum values without additional space. Below From, To and Scale, the statistics header also shows the final minimum and maximum scale used by each rendered Y-axis. Dual-unit charts show two Y-Axis rows. This makes smaller variations easier to see. For example, a voltage chart containing values between 220 V and 240 V no longer needs to use a fixed 0–300 V scale. ## Favorites Six favorite switches are available above the notification setup. - Hold a favorite switch for five seconds to store the selected devices, query range, scale, Y-axis setup and current aggregated chart. - Press it once to restore the saved setup and chart. - Press it three times within two seconds to restore the favorite and request fresh values. The QA shows a countdown while a favorite is being saved and displays the device IDs and names stored in every favorite slot. ## HC3 tariff chart The virtual **Tariffs** device type reads the current tariff schedule from the HC3 energy billing endpoint and displays the rate in NOK/kWh. The QA automatically adopts the time range covered by the returned tariff schedule. The HC3 endpoint provides the current recurring schedule, not an archive of previous tariff definitions. But this is a bit work in progess so will come back to it ## 992. InfluxDB 2 writer The **992. InfluxDB 2** QuickApp collects HC3 device-property events and writes them to an InfluxDB 2 bucket using line protocol. It can: - Send values from selected HC3 devices or all devices. - Restrict exported properties with an allowlist, such as `value`, `power` and `energy`. - Store device ID, device name, room, device type and property information with the values. - Batch writes to reduce HTTP traffic. - Keep a bounded in-memory queue during temporary connection problems. - Retry transient failures with limits instead of retrying forever. - Use an optional failover InfluxDB endpoint. - Export bounded HC3 system-event telemetry. - Export the HC3 energy tariff schedule at startup and once per day. - Show connection, queue, filtering and transport diagnostics in its interface. The writer uses `value_num_v2` for numeric device values. History Charts can also read legacy `value` data, so charts can cover periods written before and after the field change. ## InfluxDB charts in 804. History Charts InfluxDB mode queries the selected HC3 device IDs and aggregates values to the current chart resolution on the server. This keeps the response and QuickApp memory bounded even when the database contains many raw records. Normal plotted lines use aggregated mean values, but the displayed Min, Max and Mean statistics are calculated separately from all raw values in the selected period. This preserves the real statistics and short spikes even when the chart line is smoothed by aggregation. When every selected device uses a cumulative kWh value, the QA uses the last counter value in each interval, calculates non-negative hourly or daily consumption deltas and renders the devices as grouped bars. The statistics header below the SVG shows the actual bar interval, for example `1 h`, `6 h`, or `24 h`. The **Records** selector is active in both source modes. HC3 applies the selected limit to each device request. InfluxDB applies it after `aggregateWindow`, so it limits the aggregated points returned per device or series rather than the raw database rows. Because the chart is normally reduced to about 300 points, the lowest 2,000-record setting will usually be sufficient for InfluxDB. The current writer schema uses the numeric field `value_num_v2`. The QA also reads older `value` data across the complete selected range and merges both schemas, preferring `value_num_v2` wherever both fields contain the same timestamp or chart interval. HTTP and HTTPS are supported. When HTTPS is selected, `tls_verify` controls whether the server certificate is validated. It has no effect in HTTP mode. On startup and after Reload Lists, History Charts automatically reads UUID-validated nonsecret connection settings from the `jbs992_InfluxdbV2` global, including the current measurement. Its existing 804 configuration remains the fallback if the 992 global is unavailable or invalid. A token configured specifically for History Charts through its QuickApp variable, Config or own global always takes precedence. This allows a write token for 992 and a separate read token for 804. The 992 token is used only as a last-resort fallback when History Charts has no token of its own. If InfluxDB returns HTTP 401 or 403, History Charts reports whether authentication failed or the token lacks read permission. When the rejected token came from the 992 fallback, the warning explains that it may be write-only and recommends configuring a separate read token for 804. The token is never displayed or written to the QA log, but HC3 global variables contain readable plaintext. The global and its backups must therefore be treated as sensitive. Do not publish screenshots, exported globals or configuration dumps containing an InfluxDB token. ## Saved state The QA stores only bounded, aggregated chart values rather than every raw history event. The latest successful chart survives a restart and can also be restored by a fresh QA using the same permanent UUID. The versioned `jbs804_History_Charts` global is refreshed on every enabled startup and daily at the configurable `BackupTime` while the QA is enabled. Factory Reset removes the QA-owned saved state and global backup. Restart preserves the configuration and saved charts. ## Language and interface support The QuickApp includes: - English - Norwegian - Dutch - Polish - Follow Home Center Language - Automatic Classic-view setup and a protected one-way switch back to Classic view - Enabled/disabled mode - CPU and memory diagnostics - Update controls - A built-in manual ## Versions - **804. History Charts:** v1.0.0 - **992. InfluxDBv2:** v1.0.0 ## Installation and configuration ### Using HC3 History only 1. Install 804. History Charts and its companion files. 2. Open the QuickApp and wait for the HC3 device list to load. 3. Select one or more device types and devices. 4. Select HC3 History as the source. 5. Select the time range, scale, record limit and Y-axis mode. 6. Press Load History. ### Using InfluxDB 2 1. Install and configure 992. InfluxDB 2 with the server, bucket, organization, measurement and token. 2. Select which HC3 devices and properties the writer should export, or enable Send All Devices. 3. Confirm in the 992 status labels that writes are reaching InfluxDB. 4. Install 804. History Charts. It automatically adopts the UUID-validated nonsecret connection settings from 992; configure a separate read token for 804 when desired. 5. Select InfluxDB 2 as the History Charts source. 6. Select the devices and requested time range, then press Load History. HC3 History mode works without an external database. InfluxDB mode requires an InfluxDB 2 server, bucket, organization and token with permission to query the selected bucket. ## Support continued development If you find these QuickApps useful, donations would be greatly appreciated. Contributions will help cover more AI token usage while developing, testing and improving these and future QuickApps. [Donate through PayPal](https://www.paypal.com/donate/?hosted_button_id=VUADCH6HQCYM2) Feedback, testing results and suggestions for additional chart types or supported device properties are welcome.
      • 4
  16. I've added nr and basicAuthorization support to v0.1.49 that I just pushed. It was left out from ER5. The third issue with temperature looks syntacticly correct. The error suggests that the variable temperature is a table...? Do you set the variable in some other rule?
  17. Dear Jan, all other Eventrunners, Two more things (in addition to the node-red integration) I struggle with whilst moving my rules from 5 to Eventrunner7 are the following: rule([[@13:07 & wday('fri') => _creds = fibaro.basicAuthorization('user','password'); log('#C:red#Restart HC3'); hc3api.post('/service/reboot',{recovery=false}) ]]) [24.07.2026] [13:07:00] [ERROR] [QUICKAPP859]: ❌ RULE4: attempt to call a nil value _creds = fibaro.basicAuthorization('user','password'); ^^^^^^^^^^^^^^^^^^ src: @13:07 & wday('fri') => _creds = fibaro.basicAuthorization('user','password'); log('#C:red#Restart HC3'); hc3api.post('/service/reboot',{recovery=false}) [24.07.2026] [13:07:00] [ERROR] [QUICKAPP859]: ❌ RULE4: Disabled src: @13:07 & wday('fri') => _creds = fibaro.basicAuthorization('user','password'); log('#C:red#Restart HC3'); hc3api.post('/service/reboot',{recovery=false}) and another one that works in 5 but not in 7: rule("vloerverwarming:isOff & (temperature:value < 17.0 ) & 08:00..23:00 & $Profile == 'Home' => vloerverwarming:on ") OUTPUT: 24.07.2026] [13:39:35] [DEBUG] [QUICKAPP572]: 🎬 RULE25: #device{"id":535,"value":22.0,"old":21.8,"property":"value"} [24.07.2026] [13:39:35] [ERROR] [QUICKAPP572]: ❌ RULE25: attempt to compare table with number vloerverwarming:isOff & (temperature:value < 17.0 ) & 08:00..23:00 & $Profile == 'Home' => vloerverwarming:on ^^^^^^^^^^^ Thanks for any guidance anyone might have. Wishing you all a great summer.
  18. That is SolarEdge Live (ModBus), see also here for more tips and setup option: It is quit common to get "Socket CONNECT errors". It all depends on your WiFi connection and behaviour of your inverter. You can prevent the quickapp going into offline mode by raising the quickapp variable "maxResponseTime". My setting is 240 seconds.
  19. Now it's working again. Thank you!
  20. That was a strange bug... the problem seems to have been there for a long time... Try v1.3.14
  21. Hi @reso007 could be anything. But what SolarEdge quickapp are you talking about?
  22. Hi solaredge quick app goes offline at least once a day. until last week it worked OK.
  23. please contact support for the assistance.
  24. Good morning, I've noticed that: fibaro.getValue(1, "sunsetHour") stopped working on plua emulator (up to date version) - returns nil. With sunriseHour - the same. Sooner it's working on the emulator. On real box - it's working as well.
  25. Thank you @Sankotronic for your comment and improvements. We will verify what we can implement
  26. same here, it's mark as solved but I have no way to select and so to connect my elero product, if there is no solution I have to return the hub
  27. Sorry was asking Ical is not in QA-Dist manager. Jan, perhaps a good idea to add it??
