@jgabhi !here is my eventrun4 rule , but now in eventrun7 will error. TimeProfile: {"Morning":{"start":"06:00","end":"10:00"},"Day":{"start":"10:00","end":"18:00"},"Evening":{"start":"18:00","end":"22:00"},"Night":{"start":"22:00","end":"06:00"}} function timeToSeconds(timeStr) local h, m, s = timeStr:match("(%d+):(%d+):(%d+)") if h then return tonumber(h) * 3600 + tonumber(m) * 60 + tonumber(s) end h, m = timeStr:match("(%d+):(%d+)") return tonumber(h) * 3600 + tonumber(m) * 60 end rule("global('DayTime')") rule("timeToSeconds($TimeProfile.Morning.start)..timeToSeconds($TimeProfile.Morning.end) => $DayTime='Morning'").start() rule("timeToSeconds($TimeProfile.Day.start)..timeToSeconds($TimeProfile.Day.end) => $DayTime='Day'").start() rule("timeToSeconds($TimeProfile.Evening.start)..timeToSeconds($TimeProfile.Evening.end) => $DayTime='Evening'").start() rule("timeToSeconds($TimeProfile.Night.start)..timeToSeconds($TimeProfile.Night.end) => $DayTime='Night'").start()
- 379 replies
Hi @ll I am not able to enter the system after reset ! (HC3 with v5.210.12) User: admin Password: admin Doesnt work anymore, I tried the older ones.. doesnt work ! I did also a recovery from the revovery mode. Thanks for some suggestions. Flexo Solved.
Flexo joined the community
as i said, it works in access control mode, as you can see i do have users with PIN, and my keypad is set to access control The user has to wake up keypad, enter PIN, confirm it with unlock key, the keypad will then lit up blue which means it is unlocked and it does react to central scene events You see in my logs, unlocked and then central scene on key 11 to ARM, or unlock and then central scene on key 12 to DISARM
Please expose UDP socket support in QuickApps
ChristianSogaard replied to ChristianSogaard's topic in Update 5.210
Thank you, you were right, I asked before fully exploring the available options. I have now developed a working Nilan Gateway QuickApp and shared it here in the community. It communicates locally using UDP Thanks for the clarification. https://marketplace.fibaro.com/items/nilan-gateway-qa -
AndyT joined the community
litvishko joined the community
Jan how to write in ER7? RULE142: ./include/props.lua:268: Wrong parameter type, string required. Provided param 'nil' is type of nil user:msg = 'Partitie 03 Ramen appartement is BETREDEN!!!!!!!!!!!!'; ^^^^
- 379 replies
Sorry in fact everything was working (again) after the reboot but all Fibaro new messages went into the Spam (unwanted) email...Corrected and everything back to normal.
I'm not sure, but sometimes reboot, or recovery helped me, when thing were wrong. I just got into the same problem: a week ago I was still receiving email but now no way. I have not find any reason why... code is: fibaro:call(2,"sendEmail","Dead nodes","La scène 20 vient de redémarrer") I did reboot the HC2 with no success (with or without backup)! I will open a ticket
NLW joined the community
m.roszak replied to ChristianSogaard's topic in Update 5.210
@ChristianSogaard https://manuals.fibaro.com/home-center-3-quick-apps/, check section about UDP there. -
Hi Fibaro team, @[email protected] I would like to request UDP socket support for user-created QuickApps on Home Center 3. Some local integrations depend on UDP-based protocols, discovery, or request/response communication. One example is Nilan Gateway, which uses a local UDP-based Micro Nabto protocol. Without UDP support in QuickApps, these integrations require an external proxy or bridge service, even though the actual device is available on the local network. For many HC3 users, requiring an extra Raspberry Pi, NAS service, or local server defeats the purpose of having the Home Center as the central automation hub. It would be very useful if QuickApps could access a supported UDP API, for example: - create UDP socket - send datagram to host/port - receive datagram responses with timeout - optionally enable broadcast/multicast for discovery Even a limited, sandboxed UDP API would make many local LAN integrations possible without external services. Is UDP socket support for user QuickApps something Fibaro could expose officially in a future firmware release? Thanks.
IamTed joined the community
After "Apply selection", the 429 errors did not appear anymore. I've edited the scenes and button relations, tested, still no errors. Suddenly, after some 30/35 minutes, they came back, but appear to have been triggered by a parsing error: [24.06.2026] [02:46:06] [DEBUG] [QUICKAPP92]: Event: motion Hal sensor [24.06.2026] [02:46:07] [WARNING] [QUICKAPP92]: /eventstream parse: ./include/HueTransport.lua:55: attempt to index a nil value (global 'debug') (retry in 1000ms) [24.06.2026] [02:46:11] [DEBUG] [QUICKAPP92]: Event: light_level Hal sensor [24.06.2026] [02:46:12] [WARNING] [QUICKAPP92]: /eventstream parse: ./include/HueTransport.lua:55: attempt to index a nil value (global 'debug') (retry in 1000ms) [24.06.2026] [02:46:16] [DEBUG] [QUICKAPP92]: Event: motion Hal sensor [24.06.2026] [02:46:17] [WARNING] [QUICKAPP92]: /eventstream parse: ./include/HueTransport.lua:55: attempt to index a nil value (global 'debug') (retry in 1000ms) [24.06.2026] [02:46:20] [DEBUG] [QUICKAPP92]: Event: geofence_client [24.06.2026] [02:46:32] [DEBUG] [QUICKAPP92]: Event: light Hal [24.06.2026] [02:46:33] [DEBUG] [QUICKAPP92]: Event: grouped_light /groups/0 [24.06.2026] [02:46:35] [DEBUG] [QUICKAPP92]: Event: motion Overloop sensor [24.06.2026] [02:46:36] [WARNING] [QUICKAPP92]: /eventstream parse: ./include/HueTransport.lua:55: attempt to index a nil value (global 'debug') (retry in 1000ms) [24.06.2026] [02:46:44] [DEBUG] [QUICKAPP92]: Event: motion Overloop sensor [24.06.2026] [02:46:45] [WARNING] [QUICKAPP92]: /eventstream parse: ./include/HueTransport.lua:55: attempt to index a nil value (global 'debug') (retry in 1000ms) [24.06.2026] [02:46:47] [DEBUG] [QUICKAPP92]: Event: temperature Voordeur sensor [24.06.2026] [02:47:06] [DEBUG] [QUICKAPP92]: Event: light Hal [24.06.2026] [02:47:07] [DEBUG] [QUICKAPP92]: Event: grouped_light /groups/0 [24.06.2026] [02:47:07] [DEBUG] [QUICKAPP92]: Event: grouped_light Hal [24.06.2026] [02:47:07] [DEBUG] [QUICKAPP92]: Event: table: 0xaaaaf7b06b00 [24.06.2026] [02:47:07] [DEBUG] [QUICKAPP92]: Event: grouped_light Staircase [24.06.2026] [02:47:07] [DEBUG] [QUICKAPP92]: Event: scene Dimmed [24.06.2026] [02:47:07] [DEBUG] [QUICKAPP92]: Event: light overloop lamp [24.06.2026] [02:47:20] [DEBUG] [QUICKAPP92]: Event: geofence_client [24.06.2026] [02:47:49] [DEBUG] [QUICKAPP92]: Event: temperature Tuin sensor [24.06.2026] [02:47:56] [DEBUG] [QUICKAPP92]: Event: motion Overloop sensor [24.06.2026] [02:47:57] [WARNING] [QUICKAPP92]: /eventstream parse: ./include/HueTransport.lua:55: attempt to index a nil value (global 'debug') (retry in 1000ms) [24.06.2026] [02:47:59] [DEBUG] [QUICKAPP92]: Event: light_level Overloop sensor [24.06.2026] [02:48:00] [WARNING] [QUICKAPP92]: /eventstream parse: ./include/HueTransport.lua:55: attempt to index a nil value (global 'debug') (retry in 1000ms) [24.06.2026] [02:48:06] [DEBUG] [QUICKAPP92]: Event: motion Overloop sensor [24.06.2026] [02:48:07] [WARNING] [QUICKAPP92]: /eventstream parse: ./include/HueTransport.lua:55: attempt to index a nil value (global 'debug') (retry in 1000ms) [24.06.2026] [02:48:08] [WARNING] [QUICKAPP92]: Hue bridge 429 from SSE, pausing all traffic for 5s (recent 429s: 1) [24.06.2026] [02:48:08] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 5000ms)[24.06.2026] [02:48:13] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 5000ms)[24.06.2026] [02:48:18] [WARNING] [QUICKAPP92]: Hue bridge 429 from SSE, pausing all traffic for 10s (recent 429s: 3) [24.06.2026] [02:48:18] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 10000ms) [24.06.2026] [02:48:28] [WARNING] [QUICKAPP92]: Hue bridge 429 from SSE, pausing all traffic for 20s (recent 429s: 4) [24.06.2026] [02:48:28] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 20000ms) [24.06.2026] [02:48:48] [WARNING] [QUICKAPP92]: Hue bridge 429 from SSE, pausing all traffic for 40s (recent 429s: 5) [24.06.2026] [02:48:48] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 40000ms) [24.06.2026] [02:49:29] [WARNING] [QUICKAPP92]: Hue bridge 429 from SSE, pausing all traffic for 40s (recent 429s: 2) [24.06.2026] [02:49:29] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 40000ms)[24.06.2026] [02:50:09] [WARNING] [QUICKAPP92]: Hue bridge 429 from SSE, pausing all traffic for 40s (recent 429s: 2) [24.06.2026] [02:50:09] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 40000ms)[24.06.2026] [02:50:49] [WARNING] [QUICKAPP92]: Hue bridge 429 from SSE, pausing all traffic for 40s (recent 429s: 2) [24.06.2026] [02:50:49] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 40000ms)- 259 replies
@jgab Thank you very much for your work on YahueV2. I'm new to HC and also discovered that the stock Hue app did not communicate with the bridge pro. So I found your work, installed it and got it up and running. Added one light and in the Preview tab I played with the colours and toggled it on and off. All worked. Until I created a Block scene for the light. I connected the Block scene to trigger on a Walli Controller button 1 press to turn on the light and a second scene to connect to button 2 to turn it off. Nothing happened when I pressed either button on the Controller; the light did not respond. Removed and readded the same light (not a room, just the light itself), again played with color in Preview, all working, connected it back in the Scene/Action and ... nope, no action. Maybe once or twice the Hue light responded to a Controller button press, but no more. I found the Console and selected the QUICKAPP92, the Yahue_Proxy and it reported this: [24.06.2026] [01:22:31] [WARNING] [QUICKAPP92]: Hue bridge 429 from GET refresh, pausing all traffic for 60s (recent 429s: 3) [24.06.2026] [01:22:31] [WARNING] [QUICKAPP92]: /clip/v2/resource HTTP error: 429 [24.06.2026] [01:22:31] [WARNING] [QUICKAPP92]: Retry in 60s [24.06.2026] [01:22:31] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 60000ms) [24.06.2026] [01:23:32] [WARNING] [QUICKAPP92]: Hue bridge 429 from GET refresh, pausing all traffic for 60s (recent 429s: 1) [24.06.2026] [01:23:32] [WARNING] [QUICKAPP92]: /clip/v2/resource HTTP error: 429 [24.06.2026] [01:23:32] [WARNING] [QUICKAPP92]: Retry in 60s [24.06.2026] [01:23:32] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 60000ms) [24.06.2026] [01:24:32] [WARNING] [QUICKAPP92]: Hue bridge 429 from GET refresh, pausing all traffic for 60s (recent 429s: 3) [24.06.2026] [01:24:32] [WARNING] [QUICKAPP92]: /clip/v2/resource HTTP error: 429 [24.06.2026] [01:24:32] [WARNING] [QUICKAPP92]: Retry in 60s [24.06.2026] [01:24:32] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 60000ms)[24.06.2026] [01:25:32] [WARNING] [QUICKAPP92]: Hue bridge 429 from GET refresh, pausing all traffic for 60s (recent 429s: 3) [24.06.2026] [01:25:32] [WARNING] [QUICKAPP92]: /clip/v2/resource HTTP error: 429 [24.06.2026] [01:25:32] [WARNING] [QUICKAPP92]: Retry in 60s [24.06.2026] [01:25:32] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 60000ms)[24.06.2026] [01:26:29] [TRACE] [QUICKAPP92]: onAction: {"manual":true,"args":[],"deviceId":99,"actionName":"turnOn"} [24.06.2026] [01:26:29] [DEBUG] [QUICKAPP92]: huePUT dropped (bridge cooldown 3s left): /clip/v2/resource/light/cce96469-7fd2-4f7e-8415-e23c59f4bd98 [24.06.2026] [01:26:32] [WARNING] [QUICKAPP92]: Hue bridge 429 from GET refresh, pausing all traffic for 60s (recent 429s: 3) [24.06.2026] [01:26:32] [WARNING] [QUICKAPP92]: /clip/v2/resource HTTP error: 429 [24.06.2026] [01:26:32] [WARNING] [QUICKAPP92]: Retry in 60s [24.06.2026] [01:26:32] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 60000ms) [24.06.2026] [01:26:35] [TRACE] [QUICKAPP92]: onAction: {"manual":true,"args":[],"deviceId":99,"actionName":"turnOff"} [24.06.2026] [01:26:35] [DEBUG] [QUICKAPP92]: huePUT dropped (bridge cooldown 57s left): /clip/v2/resource/light/cce96469-7fd2-4f7e-8415-e23c59f4bd98 [24.06.2026] [01:27:20] [DEBUG] [QUICKAPP92]: Health-check: refreshing Hue resources [24.06.2026] [01:27:33] [WARNING] [QUICKAPP92]: Hue bridge 429 from GET refresh, pausing all traffic for 60s (recent 429s: 1) [24.06.2026] [01:27:33] [WARNING] [QUICKAPP92]: /clip/v2/resource HTTP error: 429 [24.06.2026] [01:27:33] [WARNING] [QUICKAPP92]: Retry in 60s [24.06.2026] [01:27:33] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 60000ms) Something is flooding the Hue Bridge Pro. Note the "huePUT dropped". Do I need to turn off or disable a refresh setting? A few minutes later it pulled all devices from the hub, so it seems: [24.06.2026] [01:30:33] [WARNING] [QUICKAPP92]: Hue bridge 429 from GET refresh, pausing all traffic for 60s (recent 429s: 3) [24.06.2026] [01:30:33] [WARNING] [QUICKAPP92]: /clip/v2/resource HTTP error: 429 [24.06.2026] [01:30:33] [WARNING] [QUICKAPP92]: Retry in 60s [24.06.2026] [01:30:33] [WARNING] [QUICKAPP92]: /eventstream: HTTP 429 (retry in 60000ms)[24.06.2026] [01:31:02] [TRACE] [QUICKAPP92]: UIEvent: {"elementName":"dump","values":[],"deviceId":92,"eventType":"onReleased"}[24.06.2026] [01:31:03] [DEBUG] [QUICKAPP92]: ------------------------ [device:066ee960-736a-42d2-a873-0e160d10aa75,Keuken spot 3,LTG002] Meanwhile, I am able to turn the same lights on/off via Home Assistant with Hue integration. What could be causing the "Hue bridge 429 from GET refresh, pausing all traffic for 60s" message? The "Apply selection" button resets the 429 error somehow. I removed the Hue light from Devices and only clicked the "Apply selection" to have it re-added. The bridge is scanned, the light is added. No more errors in the console after that: [24.06.2026] [02:09:27] [DEBUG] [QUICKAPP92]: Setup 8304f2d9-6269-4ce1-96d2-28ce3ac48df1 'zone' Staircase [24.06.2026] [02:09:27] [DEBUG] [QUICKAPP92]: Setup 9567e3da-51e0-4581-8dfe-9bae0c09ceb5 'zone' Eettafel [24.06.2026] [02:09:27] [DEBUG] [QUICKAPP92]: Setup cf7c045d-960f-4b32-a853-9cdd298604fb 'zone' TV wand [24.06.2026] [02:09:27] [DEBUG] [QUICKAPP92]: Setup e58bf2b1-952d-4b57-a2c8-9ed062b1bfe6 'zone' TV Ambilight [24.06.2026] [02:09:27] [DEBUG] [QUICKAPP92]: Setup f3ce6d30-a99c-4576-a423-ac77b62ea142 'zone' Lichtbak [24.06.2026] [02:09:27] [WARNING] [QUICKAPP92]: Variable sseHeartbeat not found [24.06.2026] [02:09:27] [DEBUG] [QUICKAPP92]: Defining QA classes [24.06.2026] [02:09:27] [DEBUG] [QUICKAPP92]: Loading existing child UID:'ColorLight:d0ef34e2-85e9-4806-8b04-5c884306b30d' [24.06.2026] [02:09:27] [DEBUG] [CHILD95]: status connected [24.06.2026] [02:09:27] [DEBUG] [CHILD95]: [diag v0.2.65] on=true -> state:=true, value:=100 (lastVal=nil) [24.06.2026] [02:09:27] [DEBUG] [CHILD95]: color xy 255,189,87 [24.06.2026] [02:09:27] [DEBUG] [CHILD95]: [diag v0.2.65] dimming raw=56.13 state=true lastVal:nil->56 value:=56 [24.06.2026] [02:09:27] [DEBUG] [CHILD95]: color_temperature 446 [24.06.2026] [02:09:27] [DEBUG] [QUICKAPP92]: Creating missing child UID:'ColorLight:beabb96c-de54-46a1-a938-d9e0461b635d' [24.06.2026] [02:09:28] [DEBUG] [CHILD100]: status connected [24.06.2026] [02:09:28] [DEBUG] [CHILD100]: [diag v0.2.65] on=false -> state:=false, value:=0 (lastVal=nil) [24.06.2026] [02:09:28] [DEBUG] [CHILD100]: color xy 255,189,86 [24.06.2026] [02:09:28] [DEBUG] [CHILD100]: [diag v0.2.65] dimming raw=1.19 state=false lastVal:nil->1 (state=false, value not written)[24.06.2026] [02:09:28] [DEBUG] [CHILD100]: color_temperature 446 [24.06.2026] [02:09:28] [DEBUG] [QUICKAPP92]: Created new child ID:100, UID:'ColorLight:beabb96c-de54-46a1-a938-d9e0461b635d' [24.06.2026] [02:10:11] [DEBUG] [QUICKAPP92]: Event: temperature Hal sensor [24.06.2026] [02:10:12] [DEBUG] [QUICKAPP92]: Event: geofence_client [24.06.2026] [02:10:39] [DEBUG] [QUICKAPP92]: Event: temperature Fietsenhok sensor [24.06.2026] [02:11:13] [DEBUG] [QUICKAPP92]: Event: geofence_client ... No more "Hue bridge 429 from GET refresh, pausing all traffic for 60s" events. Hue Bridge Pro v1.77.2071353020 YahueV2 v0.2.65- 259 replies
fiosfiend joined the community
Today, the connection to my ZigBee devices magically came back all of a sudden. I wonder how long it will last. Of course, this is on the older firmware version (5.200). With 5.210 installed, I waited over a week hoping that the HC3 would restore the connection. You’re right @MAC71 They added ZigBee support five years ago, and since then, almost no fixes or improvements have been made. Unfortunately, it’s not even possible to replace everything with Z-Wave devices. And even if it were possible, their design and performance leave a lot to be desired (for example, I have great ZigBee motion sensors that have been running on a single watch battery for two years now!). Sometimes, when I’m at friends’ houses, I look jealous at their Home Assistant setups but I know it would take a lot of time to migrate over 100 devices and scenes to Home Assistant.
Hello again and thx tinman, I have done some testing and found the following: accessControlEvent does NOT work as a scene trigger on ZW3 (as you mentioned) centralSceneEvent works fine for both buttons (11 and 12) when parameter 1 = 2 (central scene mode) So for now I can using centralSceneEvent for both ARM (button 11) and DISARM (button 12) without PIN code The only thing I am missing is the PIN security for DISARM, which was possible with accessControlEvent on ZW2. Do you know if Is there any plan to fix accessControlEvent as a scene trigger on ZW3? Or is there any other workaround to use PIN + button for DISARM on ZW3? Thanks!
Tedee Plugin stopped working
As a first measure, I did recreate the token - no change for the better! -
karlheinz joined the community
Jack1969 joined the community
marczu_83 replied to awlieser's question in Other Devices / Third-party devices
I also experience the same issue from time to time – the Tedee plugin stops working. Removing and re-adding the plugin fixes the problem, but it would be nice if it worked continuously without requiring any intervention. While quickly searching the Tedee API documentation for the word “expired”, I found some references to token expiration. So perhaps the token expires after some time and the plugin is unable to refresh it properly? -
Documentation showing differences on the API side (like parameters) is here: @Smarti as for the logs, yeap - those are mostly cutted out due the fact that in most cases those did not do anything worth mentioning. The errors of any action ( ex. issue with setting the association or the parameter is reported right away with the red toast in the interface).
There is also build-in log level setting in the quickapps: function QuickApp:onInit() self.logLevel = ERROR self:debug("this debug should not be visible in console") self:error("this error should be visible in console") end self.logLevel one of following constants: NONE, ERROR, WARNING, DEBUG, TRACE
Finzzownt joined the community
Sincity74 joined the community
Some devices doesnt work as expected after Z-wave engine update
747 replied to 747's topic in Update 5.202 BETA
Hi, I have enabled remote access now. HC3-00000454 Im not home at the moment but please check if you can resolve the issue without having to go back to ZW2 engine. Br Jimmie -
Support FIBARO replied to 747's topic in Update 5.202 BETA
Hi, We'd like to get back to the topic we discussed earlier and take a closer look at it. Would it be possible for you to share the hub with us for analysis? Please also let us know which device (deviceId) we can use for testing. Enable full remote access as well so that we can investigate the issue thoroughly. Thanks, and we'll be waiting for your update. BR -
