I've tried it this way, and working: local QuickApp_trace = QuickApp.trace function QuickApp:trace(val1, ...) if val1 == "onAction: " or val1 == "onAction:" then return end QuickApp_trace(self, val1, ...) end Sure, one 'if' condition can be eliminated.
Esdeem joined the community
Irene joined the community
applepie joined the community
Lech joined the community
Anders2b joined the community
Vgantz joined the community
anrdili joined the community
