  2. I've added nr and basicAuthorization support to v0.1.49 that I just pushed. It was left out from ER5. The third issue with temperature looks syntacticly correct. The error suggests that the variable temperature is a table...? Do you set the variable in some other rule?
  3. Today
  4. Yesterday
  5. Dear Jan, all other Eventrunners, Two more things (in addition to the node-red integration) I struggle with whilst moving my rules from 5 to Eventrunner7 are the following: rule([[@13:07 & wday('fri') => _creds = fibaro.basicAuthorization('user','password'); log('#C:red#Restart HC3'); hc3api.post('/service/reboot',{recovery=false}) ]]) [24.07.2026] [13:07:00] [ERROR] [QUICKAPP859]: ❌ RULE4: attempt to call a nil value _creds = fibaro.basicAuthorization('user','password'); ^^^^^^^^^^^^^^^^^^ src: @13:07 & wday('fri') => _creds = fibaro.basicAuthorization('user','password'); log('#C:red#Restart HC3'); hc3api.post('/service/reboot',{recovery=false}) [24.07.2026] [13:07:00] [ERROR] [QUICKAPP859]: ❌ RULE4: Disabled src: @13:07 & wday('fri') => _creds = fibaro.basicAuthorization('user','password'); log('#C:red#Restart HC3'); hc3api.post('/service/reboot',{recovery=false}) and another one that works in 5 but not in 7: rule("vloerverwarming:isOff & (temperature:value < 17.0 ) & 08:00..23:00 & $Profile == 'Home' => vloerverwarming:on ") OUTPUT: 24.07.2026] [13:39:35] [DEBUG] [QUICKAPP572]: 🎬 RULE25: #device{"id":535,"value":22.0,"old":21.8,"property":"value"} [24.07.2026] [13:39:35] [ERROR] [QUICKAPP572]: ❌ RULE25: attempt to compare table with number vloerverwarming:isOff & (temperature:value < 17.0 ) & 08:00..23:00 & $Profile == 'Home' => vloerverwarming:on ^^^^^^^^^^^ Thanks for any guidance anyone might have. Wishing you all a great summer.
  6. Last week
  7. That is SolarEdge Live (ModBus), see also here for more tips and setup option: It is quit common to get "Socket CONNECT errors". It all depends on your WiFi connection and behaviour of your inverter. You can prevent the quickapp going into offline mode by raising the quickapp variable "maxResponseTime". My setting is 240 seconds.
  8. Now it's working again. Thank you!
  9. That was a strange bug... the problem seems to have been there for a long time... Try v1.3.14
  10. Hi @reso007 could be anything. But what SolarEdge quickapp are you talking about?
  11. Hi solaredge quick app goes offline at least once a day. until last week it worked OK.
  12. please contact support for the assistance.
  13. Good morning, I've noticed that: fibaro.getValue(1, "sunsetHour") stopped working on plua emulator (up to date version) - returns nil. With sunriseHour - the same. Sooner it's working on the emulator. On real box - it's working as well.
  14. Thank you @Sankotronic for your comment and improvements. We will verify what we can implement
  15. same here, it's mark as solved but I have no way to select and so to connect my elero product, if there is no solution I have to return the hub
  16. Sorry was asking Ical is not in QA-Dist manager. Jan, perhaps a good idea to add it??
  17. Hi, We can confirm that there is a problem with refreshing the selection after updateView calls, and it requires reopening the devices preview. It acts the same way in web UI and Yubii Home APP. A bug has been reported. Web part should be fixed in the next beta update (5.212). I agree that the naming of what needs to be used in updateView may not be clear, and does not match the actual naming of properties in the view. I've attached simple examples of how to use single and multi-selects single_select_demo.fqa multi_select_demo.fqa I'll also try to clarify the naming and usage: selection in single select, use "selectedItem" and provide a string value. eg self:updateView("modeSelector", "selectedItem", "auto"). You can clear it out by providing an empty string. eg self:updateView("modeSelector", "selectedItem", ""). selection in multi select, use "selectedItems" and provide an array of string values. eg. self:updateView("modeSelector", "selectedItems", {"auto", "manual"}). You can clear it out by providing an empty array. eg. self:updateView("modeSelector", "selectedItems", json.array()). Why json.array() and not {}? An empty Lua table ({}) is a bit ambiguous. By default, it's encoded as an empty object since Lua tables are associative arrays (https://www.lua.org/pil/2.5.html). Of course, non-empty Lua tables are encoded correctly depending on the content. You can try it by printing this print(json.encode({})) print(json.encode(json.array())) print(json.encode({"array element"})) print(json.encode({object = "element"})) after updating selector options, you don't need to update the selection. Those properties are independent, and selected options are preserved. So update the selection only if you need to. I know that right now the web UI clears the selection when options are updated, but that will also be fixed. Selection will disappear only if the selected option is not present in the new options list. I don't see any way to force the refresh of the device preview, but I'll look into it a bit more. Hope this helps edit: I forgot to mention - old view ("Use the new views in mobile application" checkbox unchecked) already works fine with provided code samples.
  18. try this API. http://[HCL_IP]/api/devices/[device-ID]/properties/dead You should see last value - in your case is true and last modified timestamp An example: { "value": true, "modified": 1781734611 } Convert the "modified" timestamp to find out exact date and time. example print(os.date("!%Y-%m-%d %H:%M:%S", 1781734611)) output -> 2026-06-17 22:16:51
  19. Hi, If you use QA Dist Manager from Jgab, you will see that: So the latest is 0.1.48 BTW, I dont know what means the digit and arrow inside brackets...
  20. Jan, I want to reintroduce ICal. What's the latest version?
  21. Earlier
  22. Here's the test result after over a day of continuous use. As we can see the hub.call communication can be assumed to be very reliable. None of 65k calls was lost. It was not so clear for me - this is the box who decide about broadcast the call. It can be seen how many events is generated in ~100 devices installation.
  23. Hello everyone, I need some help finding specific historical data in my Home Center Lite (HCL). One of my smart plugs (used for energy metering on a TV) was unplugged/disconnected from the wall by someone, and the power line was bypassed. I can see the "X" icon on the device dashboard showing it is currently dead. However, I need to find the exact date and time when this device lost power/connection to know when it was physically removed. Is there a way to extract this specific "Device marked as dead" timestamp from the HCL Event Panel or via an API call? Any guidance on how to track this down would be greatly appreciated. Thanks in advance!
  24. Let me answer at some length, because it may indeed seem strange that I have been showing off various ideas, but somehow never include the code. The programs I write, and in general the area of programming that interests me, are not particularly popular in our community. For example, I am not interested at all in creating integrations with various devices, which are desired by the community, and rightly so. What I do interests, I think, only a handful of people, who nevertheless provide me with a certain amount of support and satisfaction through their likes. Before I sit down to program, I spend many hours constructing the contract, deciding how it is all supposed to work. I am not a professional programmer, only an amateur, but this is what the DNSfD project taught me: a concept that is wrong in one small but crucial place means either throwing the code away or going through the torments of Tantalus while trying to “repair” it. You should also know that this is not a simple program, such as a controller for blinds or a fireplace. It is around 3,000 lines of code. It would have to be tested thoroughly, because bugs and failures in a server-based model can be mysterious and difficult to track down. I didn't do this to the end, yet. Creating client-server software requires a particular kind of experience. It is an area which, it seems to me, really follows its own rules. Something always appears that you had not anticipated, even after spending a long time thinking about how everything should work. TableMan happens to be a relatively simple project, although it has quite an extensive “construction language.” But even there I have already added things I had not expected. Another project, DNSfD, showed very clearly how difficult it is to explain to the community a concept that is systemic, tool-oriented. It also showed that more sophisticated, automated and elegant solutions do not necessarily win. Not because they are bad, but because first you still have to explain why they exist at all and how they are supposed to be used. Documentation would also have to be written. AI would probably help with that, but it would not do everything. I simply cannot find the time for it anymore. It would probably be a solid 20 to 30 pages in two languages. On the other hand, the era of sweet idleness in my life came to an end, suddenly and unexpectedly, and I had to turn programming into an additional source of income. In short, in my situation these would have to be paid solutions, so that I could be fully available to users. That, in turn, creates other problems which I am not actually in a position to deal with. I will think some more about this particular project, but for now I have to admit that, as a general rule, I had no intention of publishing these programs. I only intended to publish information about them, which may also be valuable in some way. I apologize for this somewhat chaotic and, as usual, long reply, but I am simply writing what I think.
  25. I will think about it and answer soon.
  26. Will you share your code when finished?
  27. Thank you very much. In my particular case this will not help - measurig points incomes "at it's will", instead of one-after-one stream. I heard about socket.gettime but not here... Basically, the need for this arose because, for a new idea of mine, I wanted to check how reliable a hub.call to another QuickApp actually is. By the way, I am attaching these two little programs, the sender and the receiver. This may be an interesting experiment for some of you, showing just how much is happening inside that black box. Before start, you need to enter the correct IDs of both programs in the sender (SENDER and RECEIVER constants), so that it can filter out the communication between them. The sender sends a call to the receiver every single event in the system. It's data contain own counter value . The receiver receives it, but also maintains its own counter, which must match the value it received. In addition, the average number of events per hour is calculated over a twelve-hour rolling window. Once the window has been filled, the minimum and maximum events-per-hour values will also be updated. Number of missing hub.calls will also be shown. I also wanted to measure the sender-receiver-sender round-trip time “in real life”, but unfortunately, that cannot be done... EV_sender.fqa EV_receiver.fqa
  28. Yep, this is only solution. Lua does not support natively ms.
