  2. Hi @Brytho I have never had an active reconfigure button on my HC3. Fibaro's version/installation of Zigbee has always been 'Beta' even after all these years. Here in Australia, we don't have the variety of Zwave devices like in Europe so I am a heavy user of Zigbee as well. I have found that a lot of the time when my items drop off the network, like you are seeing, if i put my HC3 into pairing mode for Zigbee and wake up the Zigbee item, it usually will rejoin the network. I THINK the issue for me is when a battery powered device drops that it breaks the mesh connection, leading to further dropouts - then I go through the process as described; I'll be solid again for a long period of time until it happens again. I know it's far from a perfect solution, but we have all been sold down the river on the HC3 and its multi-protocol capabilities or lack there of (marketing material in Aust said Zigbee and 433mhz) It's my opinion that Zigbee will never be a full, stable component of my HC3 set up. so we either need to put up with these workarounds or bite the bullet and rebuild on another platform. just my $0.02c worth
  3. Yesterday
  4. I have an old FGMS001 (firmware 3.3) motion sensor that works perfectly which I use to control my blinds on one side of my house. My sun sensor (from Somfy) stopped working and I thought that I would replace it with another Fibaro motion sensor. But the new one dosn't work as expected (and differently from the old one). It reports lux up to ~15000 but above that it starts to report 0? I thought that the fsensor was broken and got a repalement for. But is does exactly the same?! The new one has frimware 3.4. I have tried the old one besides the new one and the old one reports lux above 15000 while the new one is at zero when there are to much light. Any configuration I can do to help this situation? (I don't think setting 40/42 will help for this and I have tried to alter them but without any improvement)
  5. I noticed today that the Tedee lock plugin no longer works - neither scenes nor direct interaction via device preview. It neither locks nor unlocks anymore. Locking/unlocking directly from the Tedee app works - as well as via the Home Assistant integration. Can you please have a look into that issue? Thanks!
  6. I've tried it this way, and it's working: local QuickApp_trace = QuickApp.trace function QuickApp:trace(val1, ...) if val1 == "onAction: " then return end QuickApp_trace(self, val1, ...) end
  7. I forgot the val1 in hub.trace(QUICKAPP..self.id,val1,...)
  8. This is clearly not a 3rd-party device issue. It is a crash of the HC3 internal Zigbee coordinator. The fact that the "Reconfigure" button is grayed out in your own UI proves that the internal backend process is dead or unresponsive. Please escalate this ticket to the R&D. This is an internal firmware bug, not an external vendor issue. Regards
  9. Thank you very much, of course it works! I can’t believe I didn’t think of such a simple idea. I was sure it was going through some internal hub mechanism, and yet here we are.
  10. Redefine the trace function in your QuickApp: function QuickApp:trace(val1,...) if val1 ~= "onAction: " then hub.trace(QUICKAPP..self.id,...) end end
  11. aner
    Home Center 2
  12. Hi, Unfortunately, we are unable to resolve this issue on our side. This functionality relies on integrations and services provided by third-party vendors, and therefore its operation is outside of our direct control. As a result, we are unable to make changes to it or guarantee its proper functionality. Best regards
  13. After upgrading to ZW engine 3.0, I cannot change param on other device by scene, like color of the ring on Scene Controller, not even able to turn it the backlight on/off from block scene. Only the options enable/disable local protections are shown. At least via LUA scene the parameter setting works, however it is very annoying to find out, how to call the parameters properly. Definitely UX fail.
  14. Currently, all actuators (switches, outlets) are offline. Surprisingly, the sensors have come back online. Unfortunately, the option to reconfigure all devices in the Zigbee settings is disabled (HC3). I have about 30 Zigbee devices. Manually adding everything again is pointless.
  15. I am on 5.210.12 and have been for a few weeks. My Zigbee network is working just about the same as previous version. What issues are you seeing?
  16. Last week
  17. However, after a few minutes, Zigbee also stopped working after the downgrade! Probably the same issue as: WHAT DID YOU GUYS DO!?
  18. TRAGEDY! With this new update, you’ve completely broken Zigbee! The power-off workaround—doesn’t work. Soft reset—doesn’t work. Only rolling back to version “5.200.13” helped. On 5.210, Zigbee doesn’t work at all. What a piece of junk you’re releasing!
  19. Hi vitruv, (1) correct, though there might be a range problem (2) correct, if you use the old bridge version (not the Pro one) and the Fibaro plugin.
  20. Here are the screenshots 1 = the one with updated Firmware 3.4 2 & 3 = Firmware 3.3
  21. Good morning, I would like to ask whether it is possible to disable the generation of trace-type messages in the HC3 console. I do not mean filtering them out in the console, but preventing them from being generated at all. In particular, such messages are generated by api.post and hub.call, starting with "onAction = {...}", which is very inconvenient for me with the current architecture of my QuickApps. Perhaps it is possible to disable this for a specific application - that would be ideal. I remember that in posts about one of the firmware updates there was a mention of being able to limit or adjust the message level, but I cannot find it now.
  22. I don't understand either, I didn't even suspect it at first. But when I reinstalled version 20.8, it worked again as before and everything is fine.
  23. Don't understand that, the Geofence code is exactly the same.
  24. Hi! I restored version 20.8 and it is working properly again. I use an Iphone 12 ProMax and an Iphone 16. Both had the same problem.
  25. I have a basic beginner question and would appreciate if someone could confirm my understanding. As I understand it, there are currently at least two ways to integrate a Philips Hue LED light with Yubii Home Pro: Include the Hue light directly in Yubii Home Pro as a Zigbee device. In this case, only the basic functions are available. For example, I can switch the light on/off, dim it, and perhaps change colors, but I cannot access Hue-specific settings such as the power-on behavior (e.g., after a power outage, return to 25% brightness and blue color instead of 100% brightness and white). Use a Hue Bridge, include the Hue light in the Hue Bridge first, and then integrate the Hue Bridge with Yubii Home Pro. In this case, the full range of Hue functions and settings is available. At the moment, there is no way to access the full set of Hue functions by connecting the Hue light directly to Yubii Home Pro without a Hue Bridge. Have I understood this correctly? My particular requirement is to have the light return to a predefined favorite setting (for example, 25% brightness and blue color) after the power has been interrupted and restored. Thank you very much for your help.
  26. I have no problems with geofencing with AOQ, using an iPhone 14 Pro.
  27. for now all you can do is: - send Fibaro coffee cup @m.roszak - switch back to ZW2 - change temporairy the way you using it, e.g. use the code still to unlock the panel, and then once unlocked two scenes to do something based on "user clicked on lock" and "user clicked on unlock". Lock key is 11, unlock is 12, e.g.
  28. Thank you for reporting this. We've forwarded your report to the appropriate department for review and analysis. If we need more information for analysis, we'll contact you via private message.
