Showing results for tags '4.057'.
More search options
Found 3 results
  1. Hi all, I have a HCL with 4.057 Software Running. I have an Aeon DSB28 that is giving me some real problems. The Aeon has been added successfully to the HCL and the template loaded. However there are several slaves that are giving out data that I don't want. If I delete them, they just come back. I only have Clamp No.1 installed (230VAC, UK Single Phase), so Clamp 2 and Clamp 3 are non-existent. The data found on the Meter Total updates regularly and seems to keep track of usage. However, the Clamp No.1 actual reading is static, never updates and just gets added to the Meter Total meaning the power usage shown on the top of the screen is way out from what I'm actually using. The problems started on upgrading to 4.057 so I'm guessing its probably a software bug that I'm stuck with? Anybody else had issues?
  2. I wonder where I can find the firmware update button, if there is one? I have two fibaro wall plugs, the old one has software version 22.22 and the new one 25.25. If there is no hardware difference this firmware update option should be available according to the information given on http://www.fibaro.com/en/the-fibaro-system/wall-plug One additional question: On the mentioned site there is a picture showing "Change Icon" under the device properties. Is this option removed or how can I change the icon on the wall plug device? I am using HCL with firmware 4.057 BETA. Thanks in advance.
  3. We decided to try the beta version of the HC2, upgrading to 4.057, we used a Windows 7 PC, everything run corectly , but when we tried to access via a Mac with captain IOS we stuck on the blue circles and cannot access the HC2, but with any windows system works fine. Also when it was 4.051 we could access fine using the mac. Any thoughts?
