Showing results for tags '4.510'.
Found 3 results
  1. Version: 4.510 HC2 REST API Hi guys, since update to version 4.510 i get sometimes this email: "Suspicious Login Attempts Prevented: We noticted 5 failed login attempts to your HC2 that seemed suspicious. For your security, the following IP address xxx has been locked for 30 min" Why? The REST Auth are right. At start status code 200 with successful result and a little bit later 401 bad user and pass. All request, in the previous version, ran flawlessly...
  2. Hi All, I did download the following Virtual Device from the Fibaro Marklet place to create Backup's and reboot my device. https://marketplace.fibaro.com/items/reboot-and-create-update-based-on-virtual-device For some reason both, the backup and the reboot doesn't work for me. I'm using HC2 Ver 4.510 I'm not sure what I'm doing wrong. Username:Password ([email protected]:Password) was converted to Base64. Here my string: Backup: POST /api/service/backups HTTP/1.1 Host: 192.168.0.3 Connection: keep-alive Content-Length: 50
  3. Hi there, My hc2 keeps on reminding me that the backups that i have made so far are incompatible and that I have to make new ones. But in the backup screen is says that the backups that I made so far are compatible. Is it a bug, and/or do more people experience this? Let me know. hc2.pdf
