Showing results for tags 'apple homekit'.
Found 3 results
  1. I am planning to buy an assistant. Which one is best to use with HC3? 1- Amazon Echo 2- Google Nest Mini 3- Apple Home Pod Mini
  2. I have had Fibaro 2 system for a while, and I have integrated the motion sensor easiliy with the system. Recently I wanted to integrate the sensor to Apple Homekit. And I hade no code, so I even bought a new sensor to be sure I hade code. But there is no code in the box, and there is no longer a works with apple homekit written in the box. It has been impossible to find anything describing what i experience, the documentation on net is different from the one in the box, which dont adress the integration at al. So, is this no longer possible ti integrate to homekit, or is there another way to do it?
  3. I am currently re building a house and I want to make it fully automated. I started using insteon and I have set up din rail dimmer modules to control my lights hoping to use it with apple home kit eventually ?. However I have decide to ditch all the equipment as this couldn't be done and re design using Fibaro. All I want to do is connect all my lights to z wave dimmer modules and I hope to use apple homekit to control my lights with SIRI and I would hope that my house will know when I am coming home and turn on scenes etc. I am about to buy Quibino Dimmer modules to replace my insteon dimmer modules ,which are about to go into the bin. Am I doing this correct or am I about to waste more money. How do I control the Quibino Dimmer modules with apple home kit ? or would it be easier just to buy a shed loads of PHILIPs HUE LED bulbs and ditch the whole thing ?? Please could someone provide some guidance
