Showing results for tags 'brightness level'.
  1. Hi all, just to be clear, I'm a new user of Fibraro product, I bought yesterday the Fibaro FGBHMS-001 HomeKit con Multi-Sensor, and I would like to use it through the homekit app with Apple tv 4th gen. At the moment I paired the multi sensor with the philips Hue lamp in my kitchen, and I have created the 1st scene (through Fibraro app) in order to turn on the light when the sensor finds a movement and turn off the light after 30 second without any movement, and everything works fine.... What want to do now is trigger the turn on and turn off the light accordingly with the light sensor.... can you please confirm that is not yet possible??? Thanks in advance for your help. Fabio
  2. Hi, I would like to configure a setup where my lamps automatically swiches on if a defined brightness level is measured by the Light Sensor of the HomeKit-Version of the Fibaro Motion Sensor. Normally this can be done by using the Light sensor as a trigger. But I was not able to configure such a setup sucessfully. Did anyone tried to use the Light sensor of the HomeKit-Version of the Fibaro Motion Sensor sucessfully as trigger? I configured that the lamps should be switched on if the Light sensor measures a brightness level under 100 Lux. What I experienced so far was, that even if the Light sensor measures a value that was under 100 Lux the lamps were not switched on. Only if the brightness level was 0 Lux (absolutly dark environment) the lamps were switched on. But no other setup was sucessful. Can the Light Sensor in the HomeKit-Version only be used for triggers that measures brightness levels of 0 Lux or did I something wrong? Hope you can help me! Luke11
