Showing results for tags 'light sensor'.
Hi all, just to be clear, I'm a new user of Fibraro product, I bought yesterday the Fibaro FGBHMS-001 HomeKit con Multi-Sensor, and I would like to use it through the homekit app with Apple tv 4th gen. At the moment I paired the multi sensor with the philips Hue lamp in my kitchen, and I have created the 1st scene (through Fibraro app) in order to turn on the light when the sensor finds a movement and turn off the light after 30 second without any movement, and everything works fine.... What want to do now is trigger the turn on and turn off the light accordingly with the light sensor.... can you please confirm that is not yet possible??? Thanks in advance for your help. Fabio
- 10 replies
- brightness level
- motion sensor
(and 3 more)
I'm using Apple HomeKit for my smart home. Just bought 2 x Fibaro Motion Sensor - HomeKit with the intent to use the light (and perhaps temp) sensor to control my shades. However it seems that only the motion sensor showing up in the Apple HomeKit Automatization. Can see this has been an issue in older threads but seems to still be an issue - is that correct and is there a solution on this? I do not want to use other application like Eve or Fibaro App - Sensors should be fully compatible with Apple HomeKit without use of any other applications etc (or am I wrong?) Also saw in an old thread that it only report changes if Lux value change more that 200 Lux - which of cause is unusable. Is that still the case or has that been solved as well? Let me if you can help to solve this fast as I'll have to return the products within 10 working days to get the payment back... Also - if this is still an issue - do you have an alternative to make automatization based on Lux? All the best, Cheers, Steen
- 3 replies
- automatision
- light sensor
- (and 5 more)
Hi, I would like to configure a setup where my lamps automatically swiches on if a defined brightness level is measured by the Light Sensor of the HomeKit-Version of the Fibaro Motion Sensor. Normally this can be done by using the Light sensor as a trigger. But I was not able to configure such a setup sucessfully. Did anyone tried to use the Light sensor of the HomeKit-Version of the Fibaro Motion Sensor sucessfully as trigger? I configured that the lamps should be switched on if the Light sensor measures a brightness level under 100 Lux. What I experienced so far was, that even if the Light sensor measures a value that was under 100 Lux the lamps were not switched on. Only if the brightness level was 0 Lux (absolutly dark environment) the lamps were switched on. But no other setup was sucessful. Can the Light Sensor in the HomeKit-Version only be used for triggers that measures brightness levels of 0 Lux or did I something wrong? Hope you can help me! Luke11
- 19 replies
- brightness level
- motion sensor
(and 3 more)
Could you please support the fibaro motion sensors read 692lux while the room is dark It can detect the motion but it read high light intensity while the room is dark and not responded for changing light intensity
- 3 replies
- Motion sensors
- Lux
(and 8 more)
Hi all, I have a problem: when the motion sensor is breached( the eye is opening ), its light sensor couldn't send the current data to the server, the "lux" is updated until the eye closed. So, how could I get the lux data when the eye is opening by use only one motion sensor? this should be possible? Thanks a lot!
- montion sensor
- light sensor
