Showing results for tags 'fibaro motion sensor'.
  1. I'm using Apple HomeKit for my smart home. Just bought 2 x Fibaro Motion Sensor - HomeKit with the intent to use the light (and perhaps temp) sensor to control my shades. However it seems that only the motion sensor showing up in the Apple HomeKit Automatization. Can see this has been an issue in older threads but seems to still be an issue - is that correct and is there a solution on this? I do not want to use other application like Eve or Fibaro App - Sensors should be fully compatible with Apple HomeKit without use of any other applications etc (or am I wrong?) Also saw in an ol
  2. Guest
    Zwave plus UPDATE
    I bought a Fibaro motion sensor zwave plus. (looks very cool btw I tought your controller has to support that protocol. By trying out that sensor i saw a big improvement in range. None of my devices are reaching that far as the motionsensor does. I tried it out and they all fail to connect to HC but this motionsensor zwaveplus works like a charm at that distance. I've been reading an article from mr. @T.Konopka about the difference between zwaveplus and next Gen5 zwavechip. So..what is the truth behind this ? UPDATE !! So to b
