Showing results for tags 'energy measuring'.
This QuickApp monitors your Solax managed Solar Panels The QuickApp has (child) devices for Solarpower/m², Today production, Total production, Total Power to Grid, Total Energy to Grid, Energy from Grid, Total Power/m², Battery Energy, AC Power R, AC Power S, AC Power T, Battery Power, Power DC1, Power DC2, Power DC3 and Power DC4 The rateType interface of child device Today Energy is automatically set to "production" The readings from the child device Today Energy will be shown in the new energy panel The readings from the child device Total Energy is automatically set to the right Wh unit (Wh, kWh, MWh or GWh) See API documentation on https://www.eu.solaxcloud.com/phoebus/resource/files/userGuide/Solax_API_for_End-user_V1.0.pdf User can get a specific range of information through the granted tokenID. Please obtain your tokenID on the API page of Solaxcloud for free. The tokenID can be used to obtain real-time data of your inverter system. The obtain frequency need to be lower than 10 times/min and 10,000 times/day. Version 3.0 (19th February 2023) Changed the descriptions of the Solax Cloud values Converted the feedinpower value from positive to negative or from negative to positive Added translation for English, Dutch and Portugese Added child device for consumeenergy Version 2.1 (4th December 2022) Prevented almost empty responses like these: {"success":false,"exception":"Query success!","result":"this sn did not access!"} Added log text to main device if no data from Solax Cloud Version 2.0 (16th April 2022) Added Child Devices for feedinpower, feedinenergy, consumeenergy, feedinpowerM2, soc, peps1, peps2, peps3, batPower, powerdc1, powerdc2, powerdc3, powerdc4 Added all values returned from the Solax Cloud to the labels Changed all the device types to the most current ones Changed the handling of bad responses from the Solax Cloud Replaced null values in responses with 0.0 Optimized some code Version 1.0 (17th November 2021) Tested, ready for release Version 0.2 (15th November 2021) Changed json response Version 0.1 (13th November 2021) First (test) version Variables (mandatory): tokenId = token ID of your Solax Inverter, obtain your tokenID on the API page of Solaxcloud for free inverterSN = Unique identifier (Serial No.) of your Solax inverter solarM2 = The amount of m2 Solar Panels (use . for decimals) for calculating Solar Power m² (default = 0) interval = The default is 300 seconds (5 minutes), the daily API limitation is maximum 10 times/min and 10,000 times/day debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1) API items: Description (Accuracy) (Unit) inverterSN: Unique identifier of inverter (Serial No.) sn: Unique identifier of communication module (Registration No.) acpower: Inverter.AC.power.total (1) (W) yieldtoday: Inverter.AC.energy.out.daily (0.1) (KWh) yieldtotal: Inverter.AC.energy.out.total (0.1) (KWh) feedinpower: Grid.power.total (1) (W) feedinenergy: Grid.energy.toGrid.total (0.01) (KWh) consumeenergy: Grid.energy.fromGrid.total (0.01) (KWh) feedinpowerM2: Inverter.Meter2.AC.power.total (1) (W) soc: inverter.DC.battery.energy.SOC (1) (%) peps1: Inverter.AC.EPS.power.R (1) (W) peps2: Inverter.AC.EPS.power.S (1) (W) peps3: Inverter.AC.EPS.power.T (1) (W) inverterType: Inverter type, details refer to Table 4 in appendix inverterStatus: Inverter status, details refer to Table 5 in appendix uploadTime: Update time (format 2016-10-26 17:33:01) batPower: Inverter.DC.Battery.power.total (1) (W) powerdc1: Inverter.DC.PV.power.MPPT1 (1) (W) powerdc2: Inverter.DC.PV.power.MPPT2 (1) (W) powerdc3: Inverter.DC.PV.power.MPPT3 (1) (W) powerdc4: Inverter.DC.PV.power.MPPT4 (1) (W) Download the QuickApp here (download the file and un-zip): https://github.com/GitHub4Eddy/solax_monitor/archive/refs/tags/solax-monitor-30.zip or from the Fibaro Marketplace: https://marketplace.fibaro.com/items/solax-monitor How to install: Open the Configuration Interface Go to Settings > Devices Click + Choose Other Device Choose Upload File Choose file from your computer with .fqa
- 66 replies
- 3
This QuickApp retrieves power consumption, solar production, energy usage, gas and water usage from the Iungo Monitor, Solarpanel Analog Gasmeter and Watermeter. (Child) Devices for Consumption, Production, Solar Power, Gas usage, Water Flow, Consumption High, Consumption Low, Production High, Production Low, Total Netting, Total Gas, Total Water FLow, Ampere L1-L2-L3, Voltage L1-L2-L3, Import L1-L2-L3 (in kW) and Export L1-L2-L3 (in kW). The QuickApp works with the standalone Iungo or Iungo with BreakOutBox (max. extra 3 devices for Solar, Water and Gas analog). Version 2.0 (3rd January 2024) Added support for the newest API Changed device types to the newest powerSensor --> powerMeter, multilevelSensor --> gasMeter or waterMeter Added Child devices for Total Netting, Gas usage, Ampere L1-L2-L3, Voltage L1-L2-L3, Import L1-L2-L3 (kW), Export L1-L2-L3 (kW) Added extra values to the labels: Total Netting, Ampere L1-L2-L3, Voltage L1-L2-L3, Import L1-L2-L3 kW, Export L1-L2-L3 kW, Cost consumption low and high, Cost production low and high, Cost gast, metername, type, version and serial number Improved the calculations of grid consumption and house consumption Changed the Gas en Water labels to L/min Changed to multi-file Added translations for English, Dutch, French and Polish Added a separate Gas analog meter for those who have an Analog Gas Meter and Iungo addon Added support for the Iungo Modbus addon Added the ability to change the OID's Meter measurement now can also be used for adding up the readings for Consumption High and Low, Production High and Low, Gas and Water to reset the measurements also upwards Version 1.1 (11th September 2021) Changed the Child Devices Consumption High, Consumption Low, Production High and Production Low to device type energyMeter to facilitate the new Energy Panel Added automaticaly change rateType interface of Child device Consumption High and Low to "consumption" and Production High and Low to "production" Changed the Main Device to device type powerSensor to show the power graphs Added Net Consumption to the value of the Main Device Changed the Child Devices Consumption, Production and Solar Power to device type powerSensor to show the power graphs Changed the Water Flow unit text from m³ to Litre Added the amount of m2 Solar Panels to the log text ot the Child Device Solar Power and to the labels Changed meterreading to automatically kWh, MWh of GWh Moved tarif informatie to main device log text Added Meter measurement for Consumption High, Consumption Low, Production High, Production Low, Gas and Water to reset the measurements Added Meter measurement Date for Consumption High, Consumption Low, Production High, Production Low, Gas and Water Removed Refresh button Added some extra debug information when debug level = 3 Version 1.0 (6th February 2021) Now also supports Iungo Solarpanel and Iungo Watermeter Added a lot of Child devices Added QuickApp Variable for user defined icon Mother Device Added QuickApp Variable for Solar Power m2 Removed calculation and storage of energy consumption of Fibaro devices Version 0.6 (22nd January 2021) Now also supports Iungo basic version Version 0.5 (21 January 2021) Initial version QuickApp variables (mandatory, they will be automatically added with the default values): IPaddress = IP address of your Iungo Monitor interval = Number in seconds, the Lungo Monitor normally is updated every 10 seconds (the interval gets devided by the amount of addons you have (next to the Iungo monitor, solarpanel, gasmeter analog or water meter)) debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1) language = Preferred language (default = en) (supported languages are Engish (en), French (fr), Polish (pl) and Dutch (nl)) solarPanel = true or false for use of the SolarPanel module (default is false) gasMeterAnalog = true or false for use of the analog Gasmeter module (default is false) waterMeter = true or false for use of the Watermeter module (default is false) monitorOID = monitor objectID (default is 538d72d9 or if you have the Modbus version: 06f6c748) solarOID = solar objectID (default is 95778a43) gasAnalogOID = analog gas meter objectID (default is 0, but if you have one, use 06e869e1) waterOID = water meter objectID (default is 82ec52ad or use 40c3afff) solarM2 = The amount of m² Solar Panels (use . (dot) for decimals) for calculating Solar Power m² meterConsHigh = Last meter measurement Consumption High (kWh) meterConsLow = Last meter measurement Consumption Low (kWh) meterProdHigh = Last meter measurement Production High (kWh) meterProdLow = Last meter measurement Production Low (kWh) meterGas = Last meter measurement Gas (m³) meterWater = Last meter measurement Water (L/min) meterEnergyD = Date last Energy meter measurement meterGasD = Date last Gas meter measurement meterWaterD = Date last Water meter measurement Tested with: Iungo version 1.5, revision 4444, date Nov 17 2023 with the help of @twanve (thanks) Download the QuickApp here (download the file and un-zip): https://github.com/GitHub4Eddy/iungo_monitor/archive/refs/tags/iungo_monitor-20.zip or Fibaro Marketplace: https://marketplace.fibaro.com/items/iungo-monitor How to install: Open the Configuration Interface Go to Settings > Devices Click + Choose Other Device Choose Upload File Choose file from your computer with .fqa
- 62 replies
QuickApp - P1 Monitor power consumption version 2.0⚡️
SmartHomeEddy posted a question in Home Center 3
This Quickapp retrieves energy consumption, energy production, gas and water usage from the (P1 Monitor) energy, gas and water meter. This Quickapp uses the software of ztatz.nl to get the values from your smart energymeter. The ztatz plug-and-play software can run on a Raspberry Pi or in a Docker container. The Energy consumption and energy production are added to the HC3 energy panel. Use the child devices Todays Consumption and Todays Production to store energy data (kWh) in the Energy Panel. And use the child devices Consumption and Production for instantaneous power (Watt) in the Energy Panel calculations. Child Devices for: Consumption (Watt) (input for instantaneous power in Energy Panel calculations) Production (Watt) (input for instantaneous power in Energy Panel calculations) Todays Consumption (kWh) (input for energy panel) Todays Production (kWh) (input for energy panel) Waterflow (Liter) Consumption High (kWh) Consumption Low (kWh) Production High (kWh) Production Low (kWh) Consumption L1 (Watt) Consumption L2 (Watt) Consumption L3 (Watt) Production L1 (Watt) Production L2 (Watt) Production L3 (Watt) Ampere L1 (Amp) Ampere L2 (Amp) Ampere L3 (Amp) Voltage L1 (Volt) Voltage L2 (Volt) Voltage L3 (Volt) Total Gas (m³) Total Waterflow (m³) Interval: It is possible to process messages from the smart meter every second. Of course, this is only possible if the smart meter actually sends a message every second. This can be turned on via the ztatz software P1 port configuration page via the "maximum processing speed" option. Note that this gives a higher load on the Rpi (or Docker). It has been tested on the Rpi3/Rpi4 and works well on it. Older or other RPIs have not been tested. The P1 Monitor QuickApp uses 2 API calls each cycle, and if you also use Waterflow, 3 API calls each cycle. With an interval setting of 10 seconds there is an API call every 5 seconds (and with Waterflow enabled, every 3.33 seconds). So the fastest interval setting will probably be 3 seconds with Waterflow and 2 seconds without Waterflow. Ztatz software: https://www.ztatz.nl Docker container based on the ztatz.nl software: The container version has the same functionality as the full version for the Raspberry Pi. Docker container: https://hub.docker.com/r/mclaassen/p1mon I use a Raspberry Pi Smart Meter Cable Starter Kit Raspberry Pi 4 Model B Rev 1.1 2GB 32GB Micro SDHC Smart Meter cable P1 Monitor software from: https://www.ztatz.nl Water Flow Sensor (M18 8mm sensing DC 5V NPN NO LJ18A3-8-Z/BX-5V cylinder inductive proximity sensor switch work voltage 5VDC special for MCU) Version 2.0 (8th January 2023) Changed child device types for optimal support of the Energy Panel: kWh -> com.fibaro.energyMeter ampere/voltage -> com.fibaro.electricMeter Watt -> com.fibaro.powerMeter gas -> com.fibaro.gasMeter water -> com.fibaro.waterMeter Removed Power device calculation Removed child devices for gross consumption and device consumption Changed code to multi file Added for translations for English, French, Polish and Dutch Version 1.6 (8th January 2022) Changed the waterflow algoritme to show more stable and more acurate measurements Small change in the code for checking existance of waterflow sensor Changed the Waterflow unit from Liter to L/min Added experimental net consumption to power Added Lasthour gas to labels Changed the API request for status to json output Version 1.5 (4th September 2021) Support of new Energy Panel: Changed Child device Net Consumption to Main device with type com.fibaro.powerSensor (value can be positive or negative) Added Child device Todays Consumption to show the daily energy consumption in kWh Added Child device Todays Production to show the daily energy production in kWh Changed Child device Consumption High and Low to com.fibaro.energyMeter (kWh in property "value"; "rateType" = consumption). These values will be shown in the new energy panel. Changed Child device Production High and Low to com.fibaro.energyMeter (kWh in property "value"; "rateType" = production). These values will be shown in the new energy panel. Added automaticaly change rateType interface of Child device Consumption High and Low to "consumption" and Production High and Low to "production Changed Child device Consumption and Production to type com.fibaro.powerSensor (Watt) to show power graphs Changed Child device Consumption L1, L2 and L3 and Production L1, L2 and L3 to type com.fibaro.powerSensor (Watt) to show power graphs Additional changes: Added todays Maximum consumption and todays Maximum production and timestamp to the label text and Child device log text Added todays Maximum consumption and todays Maximum production automatic format measurement to W, Kw, MW or GW Added todays Consumption low and high (kWh) and todays Production low and high (kWh) to the label text and Child devices log text Added todays Consumption of gas in the label text and Child device log text Added Timestamp in format dd-mm-yyyy hh:mm:ss to log of Main device and labels Placed production below consumption in the labels Solved bug when Production is higher than Consumption with calculation of Gross Consumption (Gross Consumption = Net Consumption minus or plus Device Consumption) Version 1.4 (11th April 2021) Added Child Devices Waterflow and Total Waterflow Version 1.3 (13th February 2021) Added Child Devices for Voltage L1 L2 L3 Version 1.2 (6th February 2021) Added a lot of Child Device Version 1.1 (18th January 2021) Solved a bug when powerID = 0 Version 1.0 (15th Januari 2021) Changed routine te get Energy Device ID's fast (no more maxNodeID needed) Added "Update Devicelist" button to update the Energy devicelist Added Tarifcode High and Low (and empty for flat fee) Rounded Consumption and Production to zero digits Watt Added Quickapp variable for debug level (1=some, 2=few, 3=all). Recommended default value is 1. Re-aranged the labels Cleaned up some code Version 0.3 (16th August 2020) Added Quickapp variables for easy configuration Added Power Production Changed method of adding QuickApp variables, so they can be edited Tested on P1 Monitor version: 20221105 V2.1.0 Raspberry Pi model: Raspberry Pi 4 Model B Rev 1.1 Linux-5.15.74-v7l+-armv7l-with-glibc2.31 Python version: 3.9.2 QuickApp variables (mandatory, they will be automatically added with the default values): IPaddress = IP address of your P1 monitor interval = Number in seconds, the P1 Monitor normally is updated every 10 seconds, sometimes even faster debugLevel = Number (1=some, 2=few, 3=all) (default = 1) waterMeter = Existance of watermeter true or false (default = false) language = Preferred language (default = en) (supported languages are Engish (en), French (fr), Polish (pl) and Dutch (nl)) Download the QuickApp here (download the file and un-zip): https://github.com/GitHub4Eddy/p1_monitor/archive/refs/tags/p1_monitor_20.zip or Fibaro Marketplace: https://marketplace.fibaro.com/items/p1-monitor How to install: Open the Configuration Interface Go to Settings > Devices Click + Choose Other Device Choose Upload File Choose file from your computer with .fqa- 108 replies
- 3
- energy
- power meter
(and 8 more)
HC-and a benext P1 dongle for energy measuring not updating
RobVeenis posted a question in Home Center 2
Dear Members, I recently bought a benext P1 dongle and conncted it to my intelligent electricity and gas meter. Both Landis & Gyr models E350 SMR 5.0 and G350 SMR 5.0 When I include the P1 dongle in the HC-2 I get an overview of the current powerconsumpyion an the current total usage of gas and electricity. However this figures never update. When I exclude and include the dongle or when I make a hard reset the same situation. New figures that are up to date and after no updates anymoer. Anyone a suggestion how to get constant updates from the dongle?- 11 replies
- benext
- energy measuring
