This QuickApp monitors your Solax managed Solar Panels
The QuickApp has (child) devices for Solarpower/m², Today production, Total production, Total Power to Grid, Total Energy to Grid, Energy from Grid, Total Power/m², Battery Energy, AC Power R, AC Power S, AC Power T, Battery Power, Power DC1, Power DC2, Power DC3 and Power DC4
The rateType interface of child device Today Energy is automatically set to "production"
The readings from the child device Today Energy will be shown in the new energy panel
The readings from the child device Total Energy is automatically set to the right Wh unit (Wh, kWh, MWh or GWh)
See API documentation on https://www.eu.solaxcloud.com/phoebus/resource/files/userGuide/Solax_API_for_End-user_V1.0.pdf
User can get a specific range of information through the granted tokenID. Please obtain your tokenID on the API page of Solaxcloud for free.
The tokenID can be used to obtain real-time data of your inverter system. The obtain frequency need to be lower than 10 times/min and 10,000 times/day.
Version 2.1 (4th December 2022)
Prevented almost empty responses like these: {"success":false,"exception":"Query success!","result":"this sn did not access!"}
Added log text to main device if no data from Solax Cloud
Version 2.0 (16th April 2022)
Added Child Devices for feedinpower, feedinenergy, consumeenergy, feedinpowerM2, soc, peps1, peps2, peps3, batPower, powerdc1, powerdc2, powerdc3, powerdc4
Added all values returned from the Solax Cloud to the labels
Changed all the device types to the most current ones
Changed the handling of bad responses from the Solax Cloud
Replaced null values in responses with 0.0
Optimized some code
Version 1.0 (17th November 2021)
Tested, ready for release
Version 0.2 (15th November 2021)
Changed json response
Version 0.1 (13th November 2021)
First (test) version
Variables (mandatory):
tokenId = token ID of your Solax Inverter, obtain your tokenID on the API page of Solaxcloud for free
inverterSN = Unique identifier (Serial No.) of your Solax inverter
solarM2 = The amount of m2 Solar Panels (use . for decimals) for calculating Solar Power m² (default = 0)
interval = The default is 300 seconds (5 minutes), the daily API limitation is maximum 10 times/min and 10,000 times/day
debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1)
Download the QuickApp here (download the file and un-zip):
https://github.com/GitHub4Eddy/solax_monitor/archive/refs/tags/solax_monitor-21.zip
or from the Fibaro Marketplace: https://marketplace.fibaro.com/items/solax-monitor
How to install:
Open the Configuration Interface
Go to Settings > Devices
Click +
Choose Other Device
Choose Upload File
Choose file from your computer with .fqa
