Showing results for tags 'fgrgb-101'.
I already read this previous topic dealing with classical in-wall rotary dimmers and the Fibaro dimmer2 module, but I think the following combination would work better. Your advice would be very much appreciated. The RGBW dimmer (FGRGB-101 / FGRGBWM-441) accepts 0-10V analog voltage input to control 12/24V DC low voltage lamps (LEDs or halogens): 1/ Can a cost-effective classical 0-10V rotary dimmer pilot the RGBW module which would then dim the lights accordingly to the input rotation? Like this one for example: 2/ If it works that way, h
- 24 replies
- fgrgb-101
- fgrgbwm-441
(and 5 more)
Sync LED dimming with RGBW and Dimmer 2 association
flux_capacitor posted a question in Dimmer and Bypass
Hi, Is there a way to associate a RGBW controller (FGRGB-101) as a master, with a Dimmer 2 module (FGD-212) as a slave, either as a Z-Wave direct association or with a LUA script on the main controller? My goal is to dim LEDs connected to 110-240V AC, with a distant low voltage RGBW module. LEDs are connected to a Dimmer 2 module. 30 feet away, a 12V DC RGBW controller interprets the variable output of an analog sensor. I'd like to dim the distant LEDs accordingly to the level the RGBW module would set if it was directly connected to equivalent 12V DC LEDs. In other wo
