Showing results for tags 'fibaro app'.
Hi, Before I start with adult HC3 I bought HC3 Lite to do some testing. I bought also few devices (Fibaro only) and replaced part of my outdated Eaton Xcomfort. The problem which I noted very quickly is that integration with Philips Hue went OK only in Web App. In Android App I can turn on Hue device as a on/off switch but tying to enter more settings app informs me only which version od HC3 soft should I have. Of course my version is higher than mentioned in the app after recent update. Can someone help me? It is a problem of HC3 Lite?
- 3 replies
- hc3 lite
- fibaro app
Hi All, is there any way to disable the intuitive favourite icons order in the new Fibaro app? I would like to choose my favourites , or would like to delete some, and don't want the icon order I see now. What can I do? The problem is that the first "favourite device" can accidentally be tapped by finger, and that in my case is a critical switch... Thank you!
Hello ; I installed the fibaro app to control my HCL remotely it works but the problem is the app is always pushing notification on my phone's saying " location " I have already set up the right location on my HCL using the computer and the fibaro dashboard but unfortunately the app is always sending succesives push notifications check attached image please
I"m new to fibaro i have installed and created the main Fibaro user account and succefully registred my fibaro HCL . I can acces it from my computer with no problem but from the phone via mobile app .. i cannot acces and i get the image attached refusing the acces even if i have enables remote access... and tryin to connect from the main account remotely the app is not accepoting me it say" ask for permission from the home administrator why he's asking for home administrator as i'm trying to connect user the home main credentials Thanks
- 1 reply
- hcl
- remote access
Hello to all, I recently added two Fibaro Roller Shutter 2 in a Fibaro HCL system. On the web application of HCL I can open/close the blinds with up/down buttons in the blind interface which is what I want because I have toggle buttons. However on the Fibaro app on Android I only see a slider to control the open/close blinds and no up/down buttons. 1.- How can I set on Fibaro app only up/down buttons instead of the slider to open/close the blinds? 2.- I added the Roller Shutter 2 for blinds with positioning, toggle buttons and were calibrated for the limits. With the slider I can only set the up movement (clicking on the right side of the slider) and the down movement (clicking on the left side of the slider) but I can not set any position of the blind. How can I set it up? Thanks in advance. hurricanet
- fibaro app
- blind open/close
Missing room with foscam generic plugin in Fibaro App (android)
hurricanet posted a question in FIBARO Mobile
Hi everyone! I have an issue regarding the rooms' appareance in Fibaro mobile app (android). The thing is that I created a room (i.e. bedroom) and only the foscam device was assigned to it. In the web UI I can see this room as same as others, although no feature is highlighted on it such as with lighting devices. However, in the Fibaro mobile app, I can not see this room under "rooms tab". For the device inside this room I use a generic plugin (Foscam generic) and in the advanced tab there is no information about ID, Device Type and so on. I think the problem is due to this plugin which is not properly recognized by the Fibaro app but I want to ask you to be sure and if there is any solution to solve it. With this plugin I can not set many more parameters except those related directly to the cam device. So my questions: 1. Is due to the Foscam generic plugin? 2. What can be done in order to see this room in the fibaro mobile app with only the foscam device? By the way, the Foscam device is 9826P. Thanks so much in advance. Best regards
