Showing results for tags 'hc3 lite'.
Found 5 results
  1. Hello, I would like to set different temperatures at Fibaro heat controller depend on actual chosen profile. When I try to set it at profiles configuration page I don't see any device (see the picture bellow). How can I set the different values for devices depend on chosen profile? Is there any other way to do this? Many thanks
  2. I have a project with 1 hc3 acting as master and 2 hc3l acting as slaves gateways. I had a problem recently with 1 of slaves and tries to replace it. All trials result in fail which led me at the end to get a new slave and do the whole work again. Is there any clear step by step guide for the replacing procedure that include all required pre-requists and how to replace a damaged slave hc3L??? @m.roszak
  3. Hi, Can anyone help with setup siren 6? When is alarm activated and triggered, the sound play for only a few second, how to make the sound play all the time? Screen is not in English language.
  4. I have some device connected to z-wave plugs that can measure the energy consumption and aeon labs plugs are used. Now I would like every month a report how many kWh, all summary of consumption. Best would be to get that report by email. Is something like this possible in the HC3 lite with LUA? Can anybody help me to get started: - how to get all consumption summary - how to send an email - how to run the script only once per month Thanks
  5. Hi, Before I start with adult HC3 I bought HC3 Lite to do some testing. I bought also few devices (Fibaro only) and replaced part of my outdated Eaton Xcomfort. The problem which I noted very quickly is that integration with Philips Hue went OK only in Web App. In Android App I can turn on Hue device as a on/off switch but tying to enter more settings app informs me only which version od HC3 soft should I have. Of course my version is higher than mentioned in the app after recent update. Can someone help me? It is a problem of HC3 Lite?
