Showing results for tags 'lc-13'.
  1. When I temporarily want to change the temperature of the Thermostat for a specific amount of time in the Fibaro app, it doesn't set the temperature in the HC3 UI nor on the thermostat (Danfoss / Popp). When I look in the app, nothing changed. When I change the temperature for an amount of time in the HC3 UI, it changes almost immediately on the thermostat. Is the app not working, or am I doing something wrong? I did set up zones for controlling temperature. (If I change the temperature of a zone, it works!) It seems that the HC3 UI is not getting any information from the heater control in the Fibaro app.
  2. A friend is looking into automating his radiators using the Danfoss LC-stuff. I've searched the forums but I can't seem to figure out if the Home Center Lite works properly with this unit. I don't hav the Lite and I don't have any LC-13's and I don't want to give crappy advice as I've sold this whole HA-thing to him and shoved how nice my own system works... Can someone spread some light on this issue?
