Showing results for tags 'manual mode'.
Found 3 results
  1. Why aren't there any block scene for manual heating and vacation mode? Seems to me to be elementary to a home automation to have easy access to the temperature control.
  2. I am new to LUA and have been automating my heating. I wanted to be able to create a scene that triggered the manual mode for some of the heating panels. I wanted to share the code with this forum - I am aware there is a similar thread but I found copying the code (and modifying) did not work. The LUA code below works for three rooms (just copy the section to a new section for another room), sets the Temperature to 21 for 3 hours from the current time --[[ %% properties %% events %% globals --]] local ManualTemp = 20 local ManualTime = (os.time()+3*60*60) -- 3 hours -- Repeat for each room that you want to set a manual temperature in. -- Office local IdPanel = 21 local panel = api.get("/panels/heating/" .. IdPanel) panel.properties.handTemperature = (ManualTemp) panel.properties.handTimestamp = (ManualTime) api.put("/panels/heating/" ..IdPanel, panel) -- Kitchen ID 18 local IdPanel = 18 local panel = api.get("/panels/heating/" .. IdPanel) panel.properties.handTemperature = (ManualTemp) panel.properties.handTimestamp = (ManualTime) api.put("/panels/heating/" ..IdPanel, panel)
  3. Dear colleagues, does anybody know how to create scene in LUA for switching a heating panel to the manual mode?
