Showing results for tags 'node-sonos-api'.
Implement Sonos VD using node-http-API running on raspberry PI The following should help if you want to implement an sonos VD that leverages the node sonos http api by jishi The post consists in two parts Setting up the API on a raspberry pi Creating the VD and summary of other uses of the API and some sample code I use **I'll structure this in a better format in the coming weeks but for now it should be sufficient** I have tested this with Play1, 3, 5 (older version) ZP100, ZP80, ZP90. I don’t have a sonos soundbar or sub but from reading other forums it should work fine for those I intend to use this more in ‘Press Button’ mode rather than directly as a remote control but it should be good either way. You can also select what appears in HC2 UI by clicking the ‘main’ checkbox on the appropriate VD button ( I think you can have one button, one label and one slider) Credit & Reuse: This work draws on the work of many many people from both this forum as well as other forums. Without these people and the work they have done as well as what they have helped me learn over the last 12 months this wouldn't have been created. Like all VD’s please feel free to constructively criticise or modify it to meet your needs STEP1: Setup api on node.js device: This VD requires jishi’s node-sonos-http-api to be installed on a node.js capable device. This can be a RPi, a NAS or something similar. Details on where to get the code and install can be found on Git - https://github.com/jishi/node-sonos-http-api You will also find an excellent blog/issue tracker at the link above for any issues you encounter I have mine installed on a Rpi Added Feb 5th The fastest way I found to get up and running on a PI if you're unsure and just want to try it (takes about 15 minutes) Use the sonos-api precompiled rpi image at http://jishi.github.io/node-sonos-http-api/ (apply to blank sd card) when you login over SSH (with something like putty) the password is root Map a network drive or Start Run to \\<IP of Pi>\flash click apps folder and you'll see the sonos-http-api folder Get an API from VoiceRSS and create a settings.json file (details in the post) and drop it into the sonos-http-api folder reboot and that's it - test through browser with something like http://<ip-of-Pi:5005/<playername>/Say/Hello If you want to upgrade to the latest api release Download the latest zip from https://github.com/jishi/node-sonos-http-api (green button on right) In the flash folder rename the sonos-http-api to -old Rename what you downloaded to to sonos-http-api Drop in your settings.json file SSH into the Pi - login = root cd /flash/apps cd sonos-http-api npm install --production when finished reboot DOCKER from @riemers (thanks ) You could also use docker Some nas systems include docker too (synology) from the gui. Using docker is easy and simple to give to someone else too, work on Pi3 too. For node-sonos-api there is a docker image https://github.com/chrisns/docker-node-sonos-http-api saves you the hassle of installing all dependency's, assuming you have some knowledge with linux. # Edit - additional observation - I like the Synology NAS option but mine doesn't reboot in the event of a power outage. The Rpi does reboot. If you use a NAS it might be good to use a UPS or find a way to reboot after an outage Once you have this setup you are ready to move on to Step 2 STEP 2 : Import the VD, you will need one VD per sonos zone node-sonos-api VD.vfib Name - The zone name needs to be the same as what it is in native Sonos (try and avoid chars such as /,etc) Spaces are okay IP Address: This is the IP of the device where the api is installed (This is NOT the IP address of the sonos zone) Port: Leave at 5005 (can be changed it needed, see git above) STEP 3 : Configure Play, Stop, Repeat, Shuffle, etc – this should work as is The parts you may want to modify are as follows => Volume I opted for the vol + / vol – as opposed to the slider as I find the sliders difficult to use on a tablet Vol + / - operates in increments of 2%. This is easy to change in the url string. The Vol 10% button is also easy to change => Favourites You will need to modify this to your favourites and how they are named in your sonos setup I would advise simplifying these names in the native Sonos setup as much as you can. Spaces are okay, you just need to use %20 where you have a space in a name If you need more of less favourites, please add/delete buttons as required => Playlists I don’t really use them but these are easily enough added in a similar way to the favourites above. => Line-in selection You can create one button for each line in option on your setup for any connect/connect amp or Zp unit.. (I have 4 on my setup) You will need to get the UUID for the zone that has the line in physically connected to it. You can get the UUID of that zone by viewing the topology of the zone with the topology url. (drop it into chrome/ff) http://[IP of any of your zone]:1400/status/topology The format of the url http://192.168.1.89:5005/kitchen/setavtransporturi/x-rincon-stream:RINCON_000E5832B85401400 and you will need to change the last numerical string for your own UUID. => Grouping Zones I have included two examples of grouping and ungrouping The url format is simple and easy to read. below are two examples that were setup on the kitchen zone where I wanted to group the Playroom zone two it and play what was playing on the kitchen zone Group - [playroom joining kitchen and playing kitchen music] http://192.168.1.89:5005/playroom/join/kitchen Ungroup - [playroom leaving kitchen zone] http://192.168.1.89:5005/playroom/ungroup/kitchen You could also include a group all and an ungroup all by stacking the commands from each zone under one button. There are also options to control volume of grouped zones if you like but I haven't explored that yet Beyond this… The api is very extensive and still undergoing development. There are other functions in the api that could be used and might be worth a glance depending on your system and patterns of use I'll update the post this evening with the actual VD as I can't seem to export it remotely. The node.js api will need to be installed first before the VD will be of any use. Hopefully it will be of use to some people Thanks -Frank Update: Adding VD file Adding some extra information The api is very extensive and seems to keep growing I use it for mainly behind the scenes control rather than me clicking the vd/scenes buttons manually If you look at http://zone_ip:5005/room_name/state for any of your players you’ll see all the state json info and what’s possible to control/trigger from Pretifying the json will show it's structure better { "currentTrack": { "title": "x-sonosapi-stream:s2846?sid=254&flags=32", "albumArtUri": "\/getaa?s=1&u=x-sonosapi-stream%3as2846%3fsid%3d254%26flags%3d32", "duration": 0, "uri": "x-sonosapi-stream:s2846?sid=254&flags=32", "type": "radio", "absoluteAlbumArtUri": "http:\/\/192.168.1.63:1400\/getaa?s=1&u=x-sonosapi-stream%3as2846%3fsid%3d254%26flags%3d32" }, "nextTrack": { "artist": "", "title": "", "album": "", "albumArtUri": "", "duration": 0, "uri": "" }, "volume": 10, "mute": false, "trackNo": 1, "elapsedTime": 651, "elapsedTimeFormatted": "00:10:51", "playbackState": "PLAYING", "playMode": { "repeat": "none", "shuffle": false, "crossfade": false } } I have a VD that shows me the status of all my players (attached) main scene code (just add labels local device = fibaro:getSelfId(); local zonename = fibaro:getName(device); local ipaddress = fibaro:getValue(device, "IPAddress"); local port = fibaro:getValue(device, "TCPPort"); sonos = Net.FHttp(ipaddress, port); local jS = json.decode(fibaro:getGlobalValue("StateTable")) -- zero the counter for each loop local zoneCount = 0 -- LANDING response = sonos:GET("/Landing/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.Landing_Stairs.isPlaying = 1 else jS.Landing_Stairs.isPlaying = 0 end jS.Landing_Stairs.volPlaying = jsonTable.volume jS.Landing_Stairs.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblLanding.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- TWINS BEDROOM response = sonos:GET("/Bed_LE/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.lau_eth_bedroom.isPlaying = 1 else jS.lau_eth_bedroom.isPlaying = 0 end jS.lau_eth_bedroom.volPlaying = jsonTable.volume jS.lau_eth_bedroom.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblBedLE.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- FRANK BEDROOM response = sonos:GET("/Bed_Frank/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.frank_bedroom.isPlaying = 1 else jS.frank_bedroom.isPlaying = 0 end jS.frank_bedroom.volPlaying = jsonTable.volume jS.frank_bedroom.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblBedFrank.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- GUEST BEDROOM response = sonos:GET("/Bed_Guests/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.guest_bedroom.isPlaying = 1 else jS.guest_bedroom.isPlaying = 0 end jS.guest_bedroom.volPlaying = jsonTable.volume jS.guest_bedroom.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblGuests.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- OFFICE response = sonos:GET("/Bed5_Office/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.office.isPlaying = 1 else jS.office.isPlaying = 0 end jS.office.volPlaying = jsonTable.volume jS.office.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblOffice.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- MASTER BED response = sonos:GET("/Bed_MasterL/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.master_bedroom.isPlaying = 1 else jS.master_bedroom.isPlaying = 0 end jS.master_bedroom.volPlaying = jsonTable.volume jS.master_bedroom.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblMaster.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- HALL response = sonos:GET("/Hallway/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.hall.isPlaying = 1 else jS.hall.isPlaying = 0 end jS.hall.volPlaying = jsonTable.volume jS.hall.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblhallway.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- KITCHEN response = sonos:GET("/Kitchen/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.kitchen.isPlaying = 1 else jS.kitchen.isPlaying = 0 end jS.kitchen.volPlaying = jsonTable.volume jS.kitchen.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblkitchen.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- PLAYROOM response = sonos:GET("/playroom/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.playroom.isPlaying = 1 else jS.playroom.isPlaying = 0 end jS.playroom.volPlaying = jsonTable.volume jS.playroom.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblplayroom.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- GARAGE response = sonos:GET("/Garage/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.garage.isPlaying = 1 else jS.garage.isPlaying = 0 end jS.garage.volPlaying = jsonTable.volume jS.garage.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblgarage.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- PIZZA BBQ response = sonos:GET("/PizzaBBQ_Area/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.pizza_bbq_area.isPlaying = 1 else jS.pizza_bbq_area.isPlaying = 0 end jS.pizza_bbq_area.volPlaying = jsonTable.volume jS.pizza_bbq_area.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblpizza.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- LIVING response = sonos:GET("/Living_Room/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.living_room.isPlaying = 1 else jS.living_room.isPlaying = 0 end jS.living_room.volPlaying = jsonTable.volume jS.living_room.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lblliving.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); -- GARAGE response = sonos:GET("/DiningRoom/state") jsonTable = json.decode(response); if jsonTable.playbackState == "PLAYING" then zoneCount = zoneCount + 1 jS.dining_room.isPlaying = 1 else jS.dining_room.isPlaying = 0 end jS.dining_room.volPlaying = jsonTable.volume jS.dining_room.nowPlaying = jsonTable.currentTrack.artist jStateTable = json.encode(jS) fibaro:setGlobal("StateTable", jStateTable) fibaro:call(device,"setProperty","ui.lbldining.value",""..jsonTable.playbackState.." | "..jsonTable.volume..""); fibaro:setGlobal("ActiveMusicZones", zoneCount); fibaro:call(device,"setProperty","ui.activeZones.value",zoneCount); Three of my zones use power amps (the are sonos connects) and I use the ‘playstate’ to turn the amp on / off when required. That’s the code at the bottom of the vd At one stage I was even displaying the image (radio station, music album) on an openremote UI using the uri part of the state json. I use the VoiceRSS TTS on teh http api but there are others. That all that was there when I found it and it worked well I have TTS to tell me “welcome home”, “good night”, "gate opening/closing", "garage door opening/closing" and all the usual stuff but I vary the volume it at night so it doesn’t wake everybody up. I intend this expand this feedback out so If we come home and the alarm went off it would tell me or that the washing machine has finished, the humidity is still too high in the bathroom and I should open the window (or that a fan was turned on) or some HC2 system info like the available memory went beyond certain thresholds, temp in a room rose or dropped, My siemens alarm is connected to my HC2 and I keep track of all the status of the alarm zones and when we press the “Leaving Home” button it checks the alarm zones and if one or many are open, it will TTS the open alarm zones in the hall sonos so we know where to go and close. Same thing when we go to bed at night. I found that each of my zones have different volume levels that work at night and during the day. I’ll be using my HomeTable (different topic) to store this info for each zones but it can written directly into the scene/vd. (This is what the the following code is for) I also plan on using a central TTS engine (simple a scene that take a zone/message and vol) so I can TTS more easily to any player. For now I have specific TTS code on a per player basis. I leverage the global variables that @Sankotronic Weather Basic VD populates and a scene that allows me to send the current weather (temp, humidity, wind speed direction, etc) as a TTS to our bedroom in the morning as well as the temp of the house as part of our wake up routine The API has a presets concept. This allows the user to pre-define a set of grouped players, source and volume. This is a file on the rpi and is referenced by a single command rather than starting one zone and grouping other zones. An example of its structure is as follows ... { "players": [ { "roomName": "Landing", "volume": 0 }, { "roomName": "Bed_MasterL", "volume": 0 }, { "roomName": "Bed_LE", "volume": 0 }, { "roomName": "Bed_Frank", "volume": 0 } ], "pauseOthers": false, "favorite": "96FM" } You may notice that the volume is set as 0 because I use another scene to slowly raise the volume so we are not woken to the sharp shock to a loud song. This simple vd button code is what I use to slowly raise the volume slowly local device = fibaro:getSelfId(); local zonename = fibaro:getName(device); local ipaddress = fibaro:getValue(device, "IPAddress"); local port = fibaro:getValue(device, "TCPPort"); sonos = Net.FHttp(ipaddress, port); for v = 1, 10 do response = sonos:GET("/Bed_Frank/volume/"..v.."") fibaro:debug("vol= "..v.."") fibaro:sleep(1000) end I use this for morning music upstairs and downstairs as well as when the kids go to bed. (changing the presets on the rpi requires a restart of the api - i normally just reboot the pi ) Watch out for radio favorites and playlists - try and not have spaces in the names on sonos and you should have no issue calling them ADDED - Jan 21st Creating a single button on a VD to cycle through favorites or playlist instead of using 1 per favorite. Every time you click the button it selects the next favorite. I have it limited to 5 favorites but this is easily adjusted. I store the favorite in my HomeTable but it could also be a global variable. I use an array to decode the numerical value stored globally into the actual favorite so I can append to the sonos api call. This will need to be adjusted to suit your system VD button code .... local device = fibaro:getSelfId(); local ipaddress = fibaro:getValue(device, "IPAddress"); local port = fibaro:getValue(device, "TCPPort"); local jT = json.decode(fibaro:getGlobalValue("HomeTable")) -- Get the current favorite number stored, increment by 1 and if > 5 set back to 1 local f = tonumber(jT.Landing_Stairs.RadFav) + 1 if f > 5 then f = 1 end -- Store the new favorite jT.Landing_Stairs.RadFav = f fibaro:setGlobal("HomeTable", json.encode(jT)) -- Array for the favorites fav = {[1] = "4FM", [2] = "96FM", [3] = "Calm", [4] = "Heart", [5] = "Red_FM"} -- Execute the sonos conmmand sonos = Net.FHttp(ipaddress, port); response = sonos:GET("/Landing/favorite/"..fav[f]..""); I also reflect this on a status label on the VD. -- Get favorite stored globally local f = tonumber(jT.Landing_Stairs.RadFav) -- Translate into favorite name to be displayed fav = {[1] = "96FM", [2] = "4FM", [3] = "Calm", [4] = "Heart", [5] = "Red_FM"} -- fav[f] represents the name. I apppend to otehr date and display in one label local status = " "..fav[f].." | "..jTS.playbackState.." | Volume "..jTS.volume.."%" fibaro:call(device,"setProperty","ui.status.value", status); This display at the top of the VD doesn't account is somebody changes the favorite from the native sonos app. I'll add code later to keep alignment between what is selected and what is stored in the global variable, This is what it looks like on my setup that is still a work in progress x Please see post 163 on this topic on how to get the VD icons dynamic for radio station or line in
- 255 replies
