Showing results for tags 'power outage'.
Hi all, after a lot of time, finally I was able to complete a guide to send push notifications from HC2 when Power Outage occurs without using expensive tools or complicated configuration. You need only an android device that need to be always plugged in to the electricity. Hope this is useful, I'm available if you need more information regards, Leo Step-by-Step Guide for HC2 notification on Power Outage.pdf
- power outage
- push notification
(and 5 more)
FGR-222 v2.5 power consumption & calibration lost after each power outage
Guest posted a topic in FIBARO Products
FGR222 roller shutter 2 is loosing power consumption and calibration after power outage so I have to recalibrate it every time after power is back. Is there anything I can do regarding that or it is just faulty device with memory in banana Here is a screenshot: As you can se the one on the right have 0,00kWh. I live in Croatia and purchased it from one of the Fibaro resellers but to be honest don't remember which one. I don't know if sending it to Poland would be at the end more expensive than just throw it to garbage and order new one? Anyw-
- power outage
- lost calibration
