Showing results for tags 'range extender'.
First of all apologies if this has been already asked but I did do some searching but was unable to locate. I am installing a Fibaro Home Center 2 into a friends house however his house is bigger than the Fibaro's range can a extender be purchased to capture all the devices and if so can any recommend which extender to use. Thanks in advance
Hi, Can someone explain to me how to correctly set-up a HCL as a secondary controller. I have a large house and noticed that some of the devices which are farthest from my HC2 have connectivity issues so i bought a HCL when i heard i could use it as a sort of range extender. Both of the devices are connected to my LAN and i have their IP adresses. I have fiddled around with it and now see the HCL as a Slave device in my HC2 settings => Gateways Connections. However i have no idea how to check if it is now working? I also noticed the functionality: add secondary controller controll
Hi, Everyone , how it's possible i add my VERAEDGE as a secondary Z-wave gateway or Z-wave range extender , I tried to add VERA in my Z-wave network by "Copy Z-Wave network from a primary controller" and add new device in HC2, it's working , but after that ,i can't add any z-wave device in HC2 (latest Firmware version) , so i guess i need to program LUA and IP , would you please help me how i can do that, i do appreciate for quick response
