Showing results for tags 'time duration'.
  1. Hi all I have a simple scene that says that if the night variable is set and if the Porch and Driveway lights are off and if front door is breached, it should switch the Porch and Driveway light on for 300 seconds. I have put the 300 as a value in the device.. however, when I opened the door in the morning, the lights didn't switch on at 6AM but when I returned home at 7AM, they were on. That would mean that what I thought was a setting to keep the lights on for 300 seconds is not really that but is a delay of 300 seconds. Am I correct in understanding this ?? Haven't touched the scenes for a while and need to get back into this. I have attached a screenshot of the scene and also the LUA code it generated. How can I change the code to keep the lights on for 300 seconds and then switch off? Thanks in advance. FibaroTestSceneLua.txt
