Showing results for tags 'toon from eneco'.
  1. Hi, In Holland and Belgium we have the oppertunity to controle our temperature + sun colectors + Z-Wave Products. So it's possible to control your Home situation on your way. The system is called Toon from the company Eneco , an enegry distributor. NOw this month the API has come out so it could be connected to any system that's handling Z-Wave, and/ or by developers to provide with new oppertunities. NOw,.. IS it possible to connect a system like TOON with a available APQI to connect to Fibaro HC2? If yes,.... How?? See link:http://www.toonapi.com
  2. This Quickapp retrieves energy consumption, energy production and gas usage from the Toon Energy meter version 1 or 2. This QuickApp has Child Devices for Consumption (Watt), Production (Watt), Consumption High (kWh), Consumption Low (kWh), Production High (kWh), Production Low (kWh), Production Actual (Watt), Gas Usage (l/h) and Total Gas (m³) The Energy Usage from the Child devices Consumption High, Consumption Low, Production High and Production Low can be used for the HC3 Energy Panel Your Toon Energy Meter needs to be rooted, see: https://github.com/JackV2020/Root-A-Toon-USB-Stick. This is the recommended all in one solution with a one time boot from USB stick, 10 minutes of work and done. After rooting you don't need a subscription anymore and you have access to a ToonStore with a growing number of apps. For more technical people there is a possibility to ssh into the Toon if they want with username root and password toon. Rooting is at your own risk, look here for further support and info: See also: https://github.com/ToonSoftwareCollective/Root-A-Toon (if you already have a running Linux environment) See also: https://toonforum.nl/ See also: https://www.domoticaforum.eu/ Version 2.0 (22th April 2023) Changed to multifile Changed powerSensor to powerMeter and multiSensor to gasMeter Added translation for English and Dutch Added support for Toon version 2v6 (for example firmware version V5.49.19) Added support for Toon version 2v5 Added support for Toon version 2v4 Added support for Toon version 2v3 Improved debug messages Version 1.3 (20th February 2022) Solved issue with "NaN" responses or other bad responses from Toon Energy Added child device voor actual solar production Version 1.2 (27th December 2021) Solved code error with toonVersion Version 1.1 (27th December 2021) Added support for Toon version 1 Added Simulation notice in labels Version 1.0 (3th October 2021) Ready for download Version 0.2 (30th September 2021) Gas from m³/h to l/h Splashed a bug Version 0.1 (29th September 2021) Initial version Variables (mandatory): IPaddress = IP address of your Toon Meter toonVersion = Version 1 or 2 (default) Interval = Number in seconds debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1) Download the QuickApp here (download the file and un-zip): https://github.com/GitHub4Eddy/toon_energy/archive/refs/tags/toon_energy-20.zip or from the Fibaro Marketplace: https://marketplace.fibaro.com/items/toon-energy How to install: Open the Configuration Interface Go to Settings > Devices Click + Choose Other Device Choose Upload File Choose file from your computer with .fqa
