Showing results for tags 'energy measurement'.
  1. This Quickapp retrieves energy consumption, energy production and gas usage from the Toon Energy meter version 1 or 2. This QuickApp has Child Devices for Consumption (Watt), Production (Watt), Consumption High (kWh), Consumption Low (kWh), Production High (kWh), Production Low (kWh), Production Actual (Watt), Gas Usage (l/h) and Total Gas (m³) The Energy Usage from the Child devices Consumption High, Consumption Low, Production High and Production Low can be used for the HC3 Energy Panel Your Toon Energy Meter needs to be rooted, see: https://github.com/JackV2020/Root-A-Toon-USB-Stick. This is the recommended all in one solution with a one time boot from USB stick, 10 minutes of work and done. After rooting you don't need a subscription anymore and you have access to a ToonStore with a growing number of apps. For more technical people there is a possibility to ssh into the Toon if they want with username root and password toon. Rooting is at your own risk, look here for further support and info: See also: https://github.com/ToonSoftwareCollective/Root-A-Toon (if you already have a running Linux environment) See also: https://toonforum.nl/ See also: https://www.domoticaforum.eu/ Version 1.3 (20th February 2022) Solved issue with "NaN" responses or other bad responses from Toon Energy Added child device voor actual solar production Version 1.2 (27th December 2021) Solved code error with toonVersion Version 1.1 (27th December 2021) Added support for Toon version 1 Added Simulation notice in labels Version 1.0 (3th October 2021) Ready for download Version 0.2 (30th September 2021) Gas from m³/h to l/h Splashed a bug Version 0.1 (29th September 2021) Initial version Variables (mandatory): IPaddress = IP address of your Toon Meter toonVersion = Version 1 or 2 (default) Interval = Number in seconds debugLevel = Number (1=some, 2=few, 3=all, 4=simulation mode) (default = 1) Download the QuickApp here (download the file and un-zip): https://github.com/GitHub4Eddy/toon_energy/archive/refs/tags/toon_energy-13.zip How to install: Open the Configuration Interface Go to Settings > Devices Click + Choose Other Device Choose Upload File Choose file from your computer with .fqa
  2. Hi, I need a clarification related to the energy panel. In the attached image there are a number of spikes in energy measurement readings, and in between each spike, there is a return to a much lower energy consumption level. Now, I need to make sure that I am interpreting this correctly. I assume in my current thinking that values are cached/stored by the HC software when they come in. When asked by the panel, the value returned from the system is the last known value reported buy the device (or last known relative to the time points of interest). So, if my device observes a change in power consumption that is larger than the threshold set internally in the device for power reports, then it is sent to the HC. And, if I then ask 15 minutes later I will get this value back, if values observed in the device in-between this time is smaller than the threshold, so that no additional reports are sent to the HC. I just need to make sure that this is the case, so that what I am observing in the image are true drops in REPORTED small values, not the effects of reports coming in very seldom and than substituted for a calculated average or something from a interpolation of the time series where there are no actual data due to a high threshold in the device. Hope it is somehow clear what I mean here..
