Showing results for tags 'yr weather'.
Hello, Did someone know if its possible to get outside temperature in garden (Tuin) room? I have installed YR weather. Can i do it with a scene or is it not possible? Thanks.
- 60 replies
- yr weather
- outside temperature
YR Weather dla pomieszczenia Ogrod jako czujnik temp. i wilgotnosci
gariz posted a question in Home Center 2
Witam. chciałbym by dane z yr weather wpadały jak z czujnika fizycznego w pola temp. i wilgotność...- 2 replies
- pogoda temp
- wilgotność
Hi, I can't remove the YR weather plugin. I have the HCL configure to use Yahoo plugin. Is it normal? The HCL has a limit of 5 plugins and I don't use this plugin. Why can I remove? Thanks.
