Fibaro Bugtracker - ALL BUGS REPORT HERE
Dear Members,
I want to announce that for our users convenience we've released bugtrucker service:
Fibaro Bug Tracker is software application that is designed to help quality assurance and
Fibaro System programmers keep track of reported software bugs and issues in their work. It
may be regarded as a type of issue tracking system.
Please report all new bugs and issues there. We will gradually try to place all the issues in this designed platform.
EDIT:
We have released also Manual for our Bugracker:
Guest dsilletti
Hi Fibaro team, 50 issues solved! Please make a a new beta!
we all can help testing during bugfixes, we can't wait for all bugs to be fixed!
regards
Domenico
    Thank you for good words - we will note to polish users to make their tickets in english
    Thank you for all the informations
    A public organised bug tracker. great news at last.
    Guest skyhooper
    @ Fibaro team Just one little question ,when bugs are fixed ,do you live update the beta release or you just keep fixes in your internal release.
    It would be wise to share fixed free bugs beta with users if it's not the case.
    Thank you,
    Guest jrkalf
    Krystian,
    I've also posted it here (
    ), but it's specifically related to bugs in the bugtracker.
    When your developers close a bug in the list, please make sure they update the note on what the fix is. Simply closing a bug by putting it on "solved" does not fix the bug and gives the bug reporter no ability to actually verify that the solution is in place.
    communications is very important and bug report feedback is as well.
    [ Added: 2013-03-07, 19:33 ]
    Please update the bugzilla to allow for creating bugs against the new beta version of the firmware
    Guest mivd
    NorhQ Power Meter
    Still a unknown device...
    If I switch a AD142 Dimmer Plug on. The light will go on. But this is never updated in the Home center...
    But the device is not shown as dead... So does it never poll the device or does the device never send the changed value to the home center.
    Im not sure im on this version becuase after the last beta upgrade (I think it said it was upgrade from beta to stable in the info) i cant login to my HC2. I get to the login screen, enter my login and after that i just get rotating dots, like if its trying to load the page. It goes on forever, as for now approx. 2-3 weeks. Today i tried to unplug the power and wait for 15 min but still the same error
    EDIT: I only get the "power-led" and the "circle with squares" lit up after a reboot
    storskogen, try recovery to 1.038-> 1040-> 1047 -> beta
    Thanks! Now running Beta 3.506, hope it´s more stable than earlier beta
    please, fix AEOTEC MultiSensor!! that is nice device but works not correctly.
    Using beta 3.516 and 4-1 sensor works perfectly....
    /emoticons/default_icon_cool.gif" alt="8-)" />
    Lauri,
    works good, but by me all sensors goes dead after each updates.. Is there special trick to solve it?
    olegarhas, maybe in adv setting check never mark as a dead?
    A.Socha,
    in this case aeon dont mark "as dead" but still has no connection ("transfer failed" if I arm/disarm for example ) till I wake up aeon. Before 3.516 it works normal with one sensor.
    HC2 ver 3.517. A lot of adding/deleting and restarting..
    Nobody has problem with AEON 4in1 like this? if no try to delete and add again )
    [ Added: 2013-03-24, 15:14 ]
    may be after changing some parameters or after updates aeon.. but now it works.. ok
    APPLICATION ERROR #2800
    Invalid form security token. This could be caused by a session timeout, or accidentally submitting the form twice.
    Please use the "Back" button in your web browser to return to the previous page. There you can correct whatever problems were identified in this error or select another action. You can also click an option from the menu bar to go directly to a new section.
    Guest Sjandu
    Hi
    Initially after the upgrade I could see the HC2 and devices were performing faster, however after 3 days the performance is very slow. Approximately 8 second delay from switching a light on or off from my iphone before it happens. A couple of attempts have to be made before it actually works.
    I dont see any rooms in the 'Energy' tab. Only see the option for 'The whole house'
    I have dead nodes appearing where there were not previously for both wired and battery.
    Hi Sjandu,
    This is what I had with one of the Beta releases but it did settle down.
    I believe it is worse until all of the devices are properly synced with the new version of z-wave. HC2 then becomes brilliant and this is a non-issue if you have the global do not mark nodes as dead option selected. All you don't get is nodes marked as dead when they are truly dead e.g. you turn the power off on them.
    I managed to get my HC2 out of this really bad state by going to each device's advanced properties and selecting configure to default values. You have to wake sleeping devices. There is now an option to set default for all devices on the z-wave page but I have not tested.
    I still have a minor underlying problem but the system is great now if I have the option selected.
    Hope this works for you
    It shows only configured devices.
    I can't control my devices (FG211) from the "your house" page. Can't turn on/off dimmers, adjust dimmer on already turned on devices (FG211). Can't turn on/off switches (FGS211). Well it seems that nothing is working from that page. Sometimes i can control them from the actual device page.
    V3.525
