Fibaro Bugtracker - ALL BUGS REPORT HERE
Dear Members,
I want to announce that for our users convenience we've released bugtrucker service:
Fibaro Bug Tracker is software application that is designed to help quality assurance and
Fibaro System programmers keep track of reported software bugs and issues in their work. It
may be regarded as a type of issue tracking system.
Please report all new bugs and issues there. We will gradually try to place all the issues in this designed platform.
EDIT:
We have released also Manual for our Bugracker:
My House auto turn ON all Device SWITCH and RGB (INPUT/OUTPUT) after press button..Only sometimes happened this phenomenon..How do i fix this..thank
Check that any spooky devices that are switching on especially sirens etc on plugs are not defined as "lighting"
i noticed my sunset scene switched on my siren 2 nights one after the other... i changed tyhe type correctly to "other" and it stopped!
very odd... cannot explain why it happened to much traffic in one scene as it enables 6 lights? and due to polling it was excessive?
Bugzilla is in such a state that I think it would be best to purge ALL current entries and start again. They are not effectively managed and starting from scratch would give Fibaro a change to do it right from now on.
That would, however, assume that the assign resources to actually MANAGE the cases. Heck, start by actually create a working document on which workflow to use..
After upgrading to 4.0.24/30/31 the temperature of all HSM100's are not registering correctly. Anyone else with the same problem and possible solution.
Regards, Joost.
At the most basic search level, i.e. Open records, there are 1244 at time of this post. My question to fibaro is what they plan to do about addressing these.
No dates in event panel. Not new, just never thought about it.
[ Added: 2015-01-16, 11:08 ]
I know that "used memory" is a bit of a religious topic on unix powered systems, and i know the diff between in use, paged, non paged, shared, cache etc..
But, should it really do this just because i queue a parameter change for a device?
And I just got another 503. I get the prompt to restart services and request for login credentials but it doesn't help. This is the fourth time now on 4.031/4.032.
Ver : 4.302
Impossible save my change in "temperature panel"
Value : expected double
My Everspring AN157 cannot be configured (change room and name etc) since upgrading to 4.032. When clicking on the wrench icon I get "Access denied 403".
AN158 seems to work as supposed to though
/emoticons/default_icon_neutral.gif" alt=":-|" /> .
Same with benext dimmer.
Hi!
Just realized that ASR-ZW are not getting updated in the web page and neither in the App. Fortunatly it Works with the HRT4-ZW and when needed, it opens but i see this units always in off mode when they are on.
Just upgraded to 4.031, deleted and added all of them (ASR-ZW and HRT4-ZW)
IS also imposible to follow its state in the event panel, simply they dont appear.
Guest matie
2 bugs and 1 remark.
Don't know if they haven been filed before, but can not find them (easily) on this forum or on bugzilla:
1. On Mac OSX Google Chrome: I'm not able to remove a device by clicking the cross (remove button) on the device. When using safari it removes the devices,  but after clicking home (refresh page) for example, they re-appear.
2. My own uploaded device icons on Mac OSX Safari are not there. I cleared my cache, but no difference. They are there when using Google Chrome.
My remark: I had problems upgrading to 4.070. I ended up with a non-responding HCl2, also after one hour. I revived it via the recovery mode.
Mathijs.
Guest matie
I've 2 templates (Qubino) which don't have templates according to Fibaro.
I've sent them before an will sent them again. Although they are working, could you fix this? You are so busy adding new templates lately
/emoticons/default_icon_smile.gif" alt=":-)" />, please fix this too
/emoticons/default_icon_smile.gif" alt=":-)" />.
Mathijs.
Dear Members,
EDIT:
good idea,
bad implementation.
you need more people to manage bugzilla guys. so i approve of the gesture and facepalm at state this is in.
i honestly wish very best of luck to whomever will try to work on those issues at bugzzila (alot of the times its merely users helping one another instead of fibaro trying to fix things). if someone at some point manages to fix it ill be quite impressed
I find it ridiculous complicated to report something on Bugzilla Fibaro!!
i personaly find it quite simple.
can you tell me more specifically what do you conssider complicated on this process plese?
Just want to make a post about the unsupported Qubino modules... and I am not used to sites like that
