  • 2
IP cameras compatible with Fibaro - list
Guest sztywniak
I'm creating a thread in which it proposes to collect information about the IP cameras that work with Fibaro.
Please Throw below the IP camera and the path to the streams that you act and I will update this first post.
ACTI
E52
D32
JPG PATH
cgi-bin/encoder?USER=Admin&PWD=123456&snapshot
MJPG PATH
cgi-bin/encoder?USER=admin&PWD=123456&channel=2&GET_STREAM
AirLive
AirLive OD-325HD (non PTZ, Firmware version 5.0.2.6495):
JPG URL: image.cgi?resolution=1280x1024
MJPG stream URL: video.cgi?resolution=1280x1024
AXIS
Axis 207W
Axis 241Q video server
Axis Q7404 encoder
COOLCAM
All no-HD models (PL : wszystkie modele bez HD)
D-LINK
DCS-930L
DCS-932L
DCS-933L
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
MOBOTIX
M12
PANASONIC
Panasonic BL-C131 (PTZ, Firmware version 3.60R00):
JPG URL: SnapshotJPEG?Quality=Standard
MJPG stream URL: nphMotionJpeg?Quality=Standard
Turning left URL: nphControlCamera?Direction=PanLeft
Turning right URL: nphControlCamera?Direction=PanRight
Turning up URL: nphControlCamera?Direction=TiltUp
Turning down URL: nphControlCamera?Direction=TiltDown
VIVOTEK
CC8130
IP8135H
IP8330
IP8332
YUDOR
YDS-04RA-D - video server analog
YDS-09HA - video server hybrid (IP & analog)
YDS-04NA - video server IP
ZAVIO
F312A
Jpg/mjpg stream details of many IP cameras are there in this link, check manufacturer and model
That same topic in polish section
14 hours ago, mhuhn said:
Any idea why this does not work?
Was anybody successful by implementing a Sunba Cam?
Best regards
Martin
Sunba is oem from Hikvision, a cheap version without mjpg and some features. The best is to stay away from such cheap models.
You will be not able to add it now. There will be, at leats for HC3, support for cams with H264, later this year. For now you can only re-encode h264 to mjpeg
Best regards
Martin
W dniu 12.04.2017 o 18:43, Yngve napisał:
Motorola Focus 73 works fine on HCL 4.120:
I used IPcam generic plugin.
User name and passord must be entered.
Added IP addess without port.
JPG URL: cgi-bin/jpg/image.cgi
MJPG URL: axis-cgi/mjpg/video.cgi
Left URL: ?action=command&command=move_left
Right URL: ?action=command&command=move_right
Up URL: ?action=command&command=move_backward
Down URL: ?action=command&command=move_forward
Hi what do you mean by "User name and passord must be entered"?
I'm trying to get my Motorola MTB855 to work with HC3 and don't exactly know what password should I provide...
Up to now I've been using the camera with the Hubble software and only have a login and password here.
I have to replace my Foscam PTZ camera FI9828P with new one. Since this camera is not available anymore I was thinking to purchase Foscam PTZ FI9928P, but can't find anywhere if this camera is still compatible with Fibaro HC2?
My question:
Does anyone knows if camera Foscam PTZ FI9928P is compatible with Fibaro and if not any suggestions for similar PTZ camera that can work with Fibaro?
Thank you!
I am planning to buy camera's for surveillance (garden) and as baby monitor / babyphone. I want to store the recordings in the cloud (i.e. google drive). Does anyone has suggestions which camera brand works the best with Fibaro HC3?
Cheers,
Chiel
Dlink DCS 935L works smoothly on HC3
A czy ktoś próbował z kamerami Xiomi?
Hallo
i have 2 cams, but it not works in HC2, please help!!!!!
1. IPC-HDBW5431E-ZE i need the url stream for HC2
2. D´Link DCS-4605EV
please help
On 5/26/2021 at 5:07 PM, netago said:
Hallo
please help
is here no HELP ;-(
My question:
Thank you!
Hi
Sorry I saw your post only now: I have a FI9928P and it works in HC2 just like the 9828, also with a SmartImplant to report beaches and with API to arm/disarm...
Hope it helps!
R
There will soon be Nice MyEye cameras:
For those who are looking how to integrate Ubiquiti UniFi cameras to HC3 please check this post:
Above solution should work with G5 series cameras (tested).
