  • 2
IP cameras compatible with Fibaro - list
Guest sztywniak
I'm creating a thread in which it proposes to collect information about the IP cameras that work with Fibaro.
Please Throw below the IP camera and the path to the streams that you act and I will update this first post.
ACTI
E52
D32
JPG PATH
cgi-bin/encoder?USER=Admin&PWD=123456&snapshot
MJPG PATH
cgi-bin/encoder?USER=admin&PWD=123456&channel=2&GET_STREAM
AirLive
AirLive OD-325HD (non PTZ, Firmware version 5.0.2.6495):
JPG URL: image.cgi?resolution=1280x1024
MJPG stream URL: video.cgi?resolution=1280x1024
AXIS
Axis 207W
Axis 241Q video server
Axis Q7404 encoder
COOLCAM
All no-HD models (PL : wszystkie modele bez HD)
D-LINK
DCS-930L
DCS-932L
DCS-933L
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
MOBOTIX
M12
PANASONIC
Panasonic BL-C131 (PTZ, Firmware version 3.60R00):
JPG URL: SnapshotJPEG?Quality=Standard
MJPG stream URL: nphMotionJpeg?Quality=Standard
Turning left URL: nphControlCamera?Direction=PanLeft
Turning right URL: nphControlCamera?Direction=PanRight
Turning up URL: nphControlCamera?Direction=TiltUp
Turning down URL: nphControlCamera?Direction=TiltDown
VIVOTEK
CC8130
IP8135H
IP8330
IP8332
YUDOR
YDS-04RA-D - video server analog
YDS-09HA - video server hybrid (IP & analog)
YDS-04NA - video server IP
ZAVIO
F312A
Jpg/mjpg stream details of many IP cameras are there in this link, check manufacturer and model
That same topic in polish section
I always use Reolink for my clients. Very good picture.
There are also 1-2 models where smaller in shape and possibly Waf factor. :) Reolink Argus.
The Netatmo I think synonymous not bad. Believe, there is also a fibaro plugin
4 hours ago, Danielos said:
@Braun-Tristan Hmmm, that doesn't make me feel better. ;-)
But is there a "nice looking" (waf factor ;-) ) indoor / outdoor cam you can recommend?
@Braun-Tristan Thank you very much. The Reolink Argus 2 looks really nice... and this one works perfect with Fibaro? Hmmm, unfortunately, no IFTTT, no Zapier, No Alexa, Nothing.. :-(
Thank you!
Dan
Edited by Danielos
CTRONICS  IP-CAM (CTIPC-246CWS720PAN),
CTRONICS IP-CAM (CTIPC-224C720PWS) works with following commands
9 hours ago, Danielos said:
@ Braun-Tristan  Vielen Dank. Der  Reolink Argus  2 sieht wirklich gut aus ... und dieser funktioniert perfekt mit Fibaro? Hmmm, leider kein IFTTT, kein Zapier, kein Alexa, nichts ..:-(
Vielen Dank!
Dan
Hi Dan, because the camera is so much of the time in standby, the battery is so about 3-4 months. Less if a lot is recorded. But since in the battery case 4 * batteries are in it, you can get grad which with more power. Believe 123a batteries are in it. So far, I have not tested this model if it is embeddable in Fibaro. I ordered the camera + solar panel. Think it is 1-2 weeks, then I can give you more info.
Danke Tristan, Video Bild ist vorhanden auf meinem HC2 - mit der RLC423 - hättest Du noch einen Tip, wie ich diese über Fibaro zum drehen und neigen bekomme  ? Hätten wir auch über Facebook machen können ;D
Hi @Braun-Tristan
And, is it working as you thought? What about the fibaro integration?
Dan
Reolink 5MP High Quality
(integrate in FIBARO Marketplace)
Works perfect. Video quality 2560x1920
Reolink RLC-420 5MP
Integrate in HC2 & HC Lite
Model = Other Cameras
Name = Empty
Password = Empty
Protokol = http
IP = IP-Adresse (no port)
jpeg & mjpeg   (same Url)
http://ip-adresse/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=&user=admin&password=123456
Hook at mjpeg & Update 2 seconds
Encoding in Reolink software
Stream Type = Clear
Resolution = 2560x1920
Frame Rate = 25
Maximum bitrate = 6144
H.264 profiles = high
On 1/20/2019 at 11:58 AM, Danielos said:
Hi @Braun-Tristan
Dan
Hi, sorry that I am only now maile. Had a lot to do and was on vacation ...
Have not tested battery operated. sorry
Can anyone confirm if this camera D-Link DCS-8300LH will work with Fibaro by D-Link Generic Camera plugin ?
IMHO, If we can see the image return from the IP cam through its IP by using webpage, then we can include that IP Cam into Fibaro?
Not always. It also needs settings in the camera software fit and some cameras work only the login data: admin & 12345 ... In general, this is a big topic ... What kind of cameras do they have?
Hello, I have a Hikvision DVR. Is there any way I can integrate the individual analog cameras into fibaro?
I will Ask again, D-Link DCS-8300LH will work with Fibaro by D-Link Generic Camera plugin
I don´t know. I only work with Reolink Cameras
Do anyone know, how to call Presets from Reolink 423 camera in fibaro "Scene" or "VD"?
Dlink DCS 2330L works on HC2 (I have 3 cameras installed)
But i allready have the Reolink 423 at Home
Do you know if Reolink C1 Pro works ?
On 1/12/2019 at 12:52 AM, Braun-Tristan said:
Integration of the Reolink camera. Displayed as 2 sec video, update. Tested on Browser & Android Smartphone Fibaro App. Video quality 2560x1440
Reolink RLC-410WS
Modell = Other Cameras
Name = Empty
Password = Emp
ty
Protokoll = http
Stream Type = Clear
Resolution = 2560x1440
Frame Rate = 15
Maximum bitrate = 3072
@Braun-Tristan
I have the 429 (dome 4mp) but the settings below don't seem to work..
On their website they have
The URL should be:
http://(ip address)/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=(any combination of numbers and letters)&user=(user name)&password=(user password)
For example, if your IP address is 192.168.2.119, the username is admin and the password is 123456, then the URL should be:
http://192.168.2.119/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=admin&password=123456
You may refresh the website to get a new snapshot of your live image.
but they don't say what the rs setting in the middle of the url is ?
any suggestions ?
