IP cameras compatible with Fibaro - list
Guest sztywniak
Guest sztywniak
I'm creating a thread in which it proposes to collect information about the IP cameras that work with Fibaro.
Please Throw below the IP camera and the path to the streams that you act and I will update this first post.
ACTI
E52
D32
JPG PATH
cgi-bin/encoder?USER=Admin&PWD=123456&snapshot
MJPG PATH
cgi-bin/encoder?USER=admin&PWD=123456&channel=2&GET_STREAM
AirLive
AirLive OD-325HD (non PTZ, Firmware version 5.0.2.6495):
JPG URL: image.cgi?resolution=1280x1024
MJPG stream URL: video.cgi?resolution=1280x1024
AXIS
Axis 207W
Axis 241Q video server
Axis Q7404 encoder
COOLCAM
All no-HD models (PL : wszystkie modele bez HD)
D-LINK
DCS-930L
DCS-932L
DCS-933L
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
MOBOTIX
M12
PANASONIC
Panasonic BL-C131 (PTZ, Firmware version 3.60R00):
JPG URL: SnapshotJPEG?Quality=Standard
MJPG stream URL: nphMotionJpeg?Quality=Standard
Turning left URL: nphControlCamera?Direction=PanLeft
Turning right URL: nphControlCamera?Direction=PanRight
Turning up URL: nphControlCamera?Direction=TiltUp
Turning down URL: nphControlCamera?Direction=TiltDown
VIVOTEK
CC8130
IP8135H
IP8330
IP8332
YUDOR
YDS-04RA-D - video server analog
YDS-09HA - video server hybrid (IP & analog)
YDS-04NA - video server IP
ZAVIO
F312A
Jpg/mjpg stream details of many IP cameras are there in this link, check manufacturer and model
That same topic in polish section
Hikvision DS-2DE5174-A is more or less ok, but I can't find commends for movements (left, righ, zoom etc), anyone can help? (I have tried many options from other cameras but without succes. I coudn't find it in manufacturer documentation also)
Below paths are working, but not perfect:
/Streaming/channels/1/picture
/Streaming/channels/2/preview
I can see on mobile app fibaro everything fine, but on laptop only on fibaro mine page, but when I click on camera I can't see view. Anyone has it better?
Hi
i am looking for a good PoE outdoor camera! Any recommendations?
Cheers
King
I use the app "IP Webcam" on my old Android phones and tablets. Works like a charm
App link:
Settings:
IP address: IPaddress:port
JPG URL: shot.jpg
MPEG URL: videofeed
Display camera image at Your House, advanced options:
JPG activated, Refresh time: 15 seconds
This is a good way to save money and activate your old devices again
working ok, when you are on the same wifi network as the android phone is.
Does this suppose to work  from the outside network (like 4g) or other wifi network?  Does the fibaro app/controller does something to the video signal.
anyone has configured an LINKWIL AR701 with HC2?
 720P (1280x720 pixels) HD wireless IP camera  ●  H.264 video compression ●  Support onvif ●  P2P (plug and play),with built-in free Manufacturer's DDNS ●
has anyone had any success with a Foscam FI9803P?
thanks in advance......
 I ask the same, Foscam FI9803, please only need the jpg and mpeg paths, I have tried more than 20 paths and neither give me video.
Thanks.
I just got the FI9800P en R2 (Foscam), but I can't get them to work.
When I use the settings:
t=1
I should be getting this as an result
<CGI_Result>
<result>0</result>
</CGI_Result>
But I get the following as an result
<CGI_Result>
<result>-1</result>
</CGI_Result>
I Can take a snapshot with my FI9800P (no live streaming), which HC2 sends to my email. But this does not work with the R2.
I use the following settings
[iPADRESS:POORT]
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=ADMIN&pwd=ADMIN
MJPG URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=ADMIN&pwd=ADMIN
Turn left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=ADMIN&pwd=ADMIN
Turn Right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=ADMIN&pwd=ADMIN
Move up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=ADMIN&pwd=ADMIN
Move down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=ADMIN&pwd=ADMIN
Stop moving URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=ADMIN&pwd=ADMIN
t=1
<CGI_Result>
<result>0</result>
</CGI_Result>
<CGI_Result>
<result>-1</result>
</CGI_Result>
[iPADRESS:POORT]
What works:
-Camera are added in the fibaro app.
-Snapshots are send to my email
What does not work:
-Live stream when login IE Fibaro
-Live stream on app (When clicking on camera in fibaro app, notification state: "Check MJPG settings - using JPG image now")
Also when I go to advanced settings and change it to MPJG, nothing changes.
To add a substream I use this link:
As an result in firefox I got the following results
FI9800P
R2
<CGI_Result>
Does anyone know how I can solve my livestreaming problem?
anyone knows how to set up the camera inside 2n helios intercom??
I'm having it working fine thru my ipcam app on the iphone...but cant find the right path to configure it as a ip cam on fibaro!!
Hi Calza,
You can add the Helios as a normal cam, try this:
Camera model: Other
fill in you username and password
fill in the ip adress of the Helios
jpg url: http://[ip adress]/api/camera/snapshot?width=640&height=480&source=internal
mjpg url: http://[ip adress]/api/camera/snapshot?width=640&height=480&fps=5
sent stop command: Yes
Good luck
Hi all, i have a big project coming along and was wondering if anyone can advise on the below.
Can anyone recommend some outdoor IP cameras (POE) that have PTZ functionality, obviously ones that have been intergrated with Fibaro.
Thanks!
Kyle
Dear All,
I have a problem with D-Link DCS-5222L rev. B...
I've added the camera in HC2 without problem but I don't see any image.
From iPhone App works perfectly also pan and tilt.
The camera works properly both local and remotely (from d-link admin page).
I've tried with the two latest firmware but same result.
Very strange...
Any suggestion?
Thanks in advance
/public/style_images/master/attachicon.gif" alt="attachicon.gif" />
What works:
What does not work:
FI9800P
R2
<CGI_Result>
Today I got a response from Foscam tech support. unfortunately my camera's don't support Mjpeg.
zie pic below
Hi, I am looking for a wireless IP camera to integrate with my Fibaro system.  Can anyone suggest something which def works?  I have tried a Foscam FI9851P which I cannot get to connect after trying a lot of settings.
thank you
