  • 2
IP cameras compatible with Fibaro - list
Guest sztywniak
I'm creating a thread in which it proposes to collect information about the IP cameras that work with Fibaro.
Please Throw below the IP camera and the path to the streams that you act and I will update this first post.
ACTI
E52
D32
JPG PATH
cgi-bin/encoder?USER=Admin&PWD=123456&snapshot
MJPG PATH
cgi-bin/encoder?USER=admin&PWD=123456&channel=2&GET_STREAM
AirLive
AirLive OD-325HD (non PTZ, Firmware version 5.0.2.6495):
JPG URL: image.cgi?resolution=1280x1024
MJPG stream URL: video.cgi?resolution=1280x1024
AXIS
Axis 207W
Axis 241Q video server
Axis Q7404 encoder
COOLCAM
All no-HD models (PL : wszystkie modele bez HD)
D-LINK
DCS-930L
DCS-932L
DCS-933L
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
MOBOTIX
M12
PANASONIC
Panasonic BL-C131 (PTZ, Firmware version 3.60R00):
JPG URL: SnapshotJPEG?Quality=Standard
MJPG stream URL: nphMotionJpeg?Quality=Standard
Turning left URL: nphControlCamera?Direction=PanLeft
Turning right URL: nphControlCamera?Direction=PanRight
Turning up URL: nphControlCamera?Direction=TiltUp
Turning down URL: nphControlCamera?Direction=TiltDown
VIVOTEK
CC8130
IP8135H
IP8330
IP8332
YUDOR
YDS-04RA-D - video server analog
YDS-09HA - video server hybrid (IP & analog)
YDS-04NA - video server IP
ZAVIO
F312A
Jpg/mjpg stream details of many IP cameras are there in this link, check manufacturer and model
That same topic in polish section
"are you using 4,032 software ? i still can`t get this to work
/emoticons/default_icon_eek.gif" alt=":shock:" /> "
Yes, its working in 4.033 aswell.
What is the firmware in your cams?
Also, try with much higher bitrate than 512kb.
I use 4096kb.
MJPG uses alot of bandwidth compared to h.264 so hopefully Fibaro will implement support for h.264 soon..
I have a new HD Foscam IP camera FI9853EP
Just ad this camera on my HC2 and get things working
These steps I made with the following settings
Ad device - Camera
Select IP Cam  (no username and password)
advanced settings:
Ad your IP adres with port number
JPEG path:
MJPG path
select JPG
and your cam is rolling.
When selected MJPG it does not work, even the link is working on vlc.
And with selecting JPG with 6 seconds interval you still see camera as roling video - no snapshots.
hope it helps others...
Hello Charly, can you tell me your exact setup with the foscam fi9828w, because mine isnt working at all.
thx
Ad device - Camera
advanced settings:
JPEG path:
MJPG path
select JPG
Thanks for the info.
Hope mine FI9853EP PoE coming this week.
Cross my fingers that it works as good as yours
@ D-Vine my cam is working.
Except that I can't see video in the android fibaro app on my mobile.
The optie for cam is now free. When I go to that tab I see 1 cam with video.
But when I click on that cam, to zoom in. I get a bigger, but black screen.
Same is on my PC in the HC2 device overview, I see my cam with live video as a device thumbnail.
Do you have your cam integrated completely ?
So you can see de video  in de app from fibaro on your mobile.
If so can you give me some advice ?
I saw you message now, i did not follow the topic
The HD Foscam IP camera FI9853EP doesn't have zoom in my opinion.
But my cam is working on webbased as on the app.
Sometimes in the fibaro home screen web you see black , but with refresh is okay again.
with the up / down string i did a test, so you can ignore that.  FI9853EP is not able to do that
I am testing motion on/ off, but want it work on VD.  On cam device the string is working, on VD not.
anybody a idea how get the motion on- off working on a simple VD switch.  Arm/ Disarm button ?
+ Vivotek IP7131
JPEG = cgi-bin/video.jpg
MJPEG = No
Hi everyone,
I have a problem with a Foscam FI9803P
It is seted with this string cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=xx&pwd=xx
and model selected is IPCAM no user no password
It not responde correctly
it works only in preview, but if you tap the thumbnail enlarges the image of the cam and get stuck .
Preview ok , but stuck open cam on ipad
Someone please tell me the cause ?
How about to include the iPad's camera into the Fibaro app for iPad? Is this possible?
How i can add parameter 37?
In advance tab is not present some button
hi everybody . i have a hikvision ip camera and i can't find video stream of this camera . in this list
i can't found my ip camera model. can you help me to find video stream url ?
I suspect too late for you, but for the archives:
Hikvision DS-2CD2432F-IW video stream is over RTSP on port 554 - there is no HTTP URL. Fibaro v3 cannot handle RTSP video.
Does anybody know whether the Samsung SNH-P6410BN WLAN Smartcam HD Pro IP works with HCL? If yes, which URLs are requested to run the camera via the HCL?
Foscam 9831W working!
is the cam with the latest firmware of both foscam and Fibaro still working?
If yes could you post the uls for jpg en mpeg stream please?
Robert
Hi, I have 3 cameras from Foscam that doesn’t show the image from the cameras in HC2, but if I press the camera boton, fibaro sends me a sopose image but empty, I have tried the software from Foscam and now I have tried the software IPcamera, that also doesn work. My cameras are FI8910W - FI8906W - FI9821W_V2.Dis any one had the same problem?
Thanks!
Guest MrDTS
    Hi
    I have image but can not control it ? it is a foscam FI8910W and use this for video ( videostream.cgi?user=xx&pwd=xx&resolution=32&rate=13 )
    I have firmware 4.048, what is it to control the camera ? Left, Right, up,............
    MrDTS
    Hi again
    Found this and works ; )
    only problems the stop, if I choose to tick stop in menun the camera dont move, without stop, it works but have to press the pause button to stop camera move.
    Solved, works fine with Android Tabel and mobil app
    Finally I got the Foscam FI8910W and FI8904W with latest firmware working (11.37.2.59 resp. 11.35.2.59).
    Since Foscam removed Basic Authentication you need to set up the IP camera's with a workaround:
    Camera Model: IPCam (Not Foscam!, won't work)
    User:
    Password:
    JPG path: snapshot.cgi?user=&pwd=
    MJPG path: videostream.cgi?user=&pwd=
    Turn Left: decoder_control.cgi?command=6&user=&pwd=
    Turn Right: decoder_control.cgi?command=4&user=&pwd=
    Move Up: decoder_control.cgi?command=0&user=&pwd=
    Move Down: decoder_control.cgi?command=2&user=&pwd=
    Move Stop: decoder_control.cgi?command=5&user=&pwd=
    Good luck!
    Guest MrDTS
    Hi
    Looking for cheap Outdoor bullet camera with PoE and a PTZ outdoor to with PoE, that works with HC 2
    MrDTS
    Hi everyone,
    Does anyone has cgi commands for Foscam fi8919w ? I can get the mjpeg stream but couldn't turn anyway.
    Thanks in advance.
    Hi is there anybody using a D-LINK
    DCS-2330L?
    Does it work with the same setting of 933?
    For DCS-2330L you can try this settings:
    /image/jpeg.cgi
    /video/mjpg.cgi
    Or you can try plugin for DCS-2332L.
    Guest MrDTS
    Hi
    anyone got zmodo ipcam to work, it has onvif
    model is ZP-IBI13-W
    MrDTS
