  • 2
IP cameras compatible with Fibaro - list
Guest sztywniak
I'm creating a thread in which it proposes to collect information about the IP cameras that work with Fibaro.
Please Throw below the IP camera and the path to the streams that you act and I will update this first post.
ACTI
E52
D32
JPG PATH
cgi-bin/encoder?USER=Admin&PWD=123456&snapshot
MJPG PATH
cgi-bin/encoder?USER=admin&PWD=123456&channel=2&GET_STREAM
AirLive
AirLive OD-325HD (non PTZ, Firmware version 5.0.2.6495):
JPG URL: image.cgi?resolution=1280x1024
MJPG stream URL: video.cgi?resolution=1280x1024
AXIS
Axis 207W
Axis 241Q video server
Axis Q7404 encoder
COOLCAM
All no-HD models (PL : wszystkie modele bez HD)
D-LINK
DCS-930L
DCS-932L
DCS-933L
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
MOBOTIX
M12
PANASONIC
Panasonic BL-C131 (PTZ, Firmware version 3.60R00):
JPG URL: SnapshotJPEG?Quality=Standard
MJPG stream URL: nphMotionJpeg?Quality=Standard
Turning left URL: nphControlCamera?Direction=PanLeft
Turning right URL: nphControlCamera?Direction=PanRight
Turning up URL: nphControlCamera?Direction=TiltUp
Turning down URL: nphControlCamera?Direction=TiltDown
VIVOTEK
CC8130
IP8135H
IP8330
IP8332
YUDOR
YDS-04RA-D - video server analog
YDS-09HA - video server hybrid (IP & analog)
YDS-04NA - video server IP
ZAVIO
F312A
Jpg/mjpg stream details of many IP cameras are there in this link, check manufacturer and model
That same topic in polish section
I have foscam FI9821 it working fine. However it is suffered from HUGE delays!!
And what is the different between checking the MPGJ or JPG?
Hi Fibaro,
Have you seen the new Parrot Mini Drones?
How cool would it be if you guys can integrate controls for these drones to use them as inhouse movable security cams while not at home!
This would really change the use of cam security.
Any plans?
Best,
Thijs
thijs,
Configuring mobile robot signals (camera view also) with HC2 through virtual device is already possible, however it depends on robot's software and it's limited to VD functionality.
Regards
Y-cam Cube also compatible with HC2. Stream commandos are available in the camera under settings stream
Camera model: Trendnet A
JPEG-path: cgi/jpg/image.cgi
MJPG stream path: cgi/mjpg.cgi
Left: admin/ptctl.cgi?move=left
Right: admin/ptctl.cgi?move=right
Up: admin/ptctl.cgi?move=up
Down: admin/ptctl.cgi?move=down
Stop:
Hello there,
I am struggling with my FOSCAM FI9821W V2, I managed to get it to work on HC2 however the image is static in the live stream when I open the camera view.
Symptoms:
- In the computer, the camera does not show.
- In iPhone & iPad, the little thumbnail updates each 2 to 3 seconds, while the main window the view is static. If I close and come back it refreshes the frame once.
The rest of the things are working just fine, the movement, the JPG, everything is working fine.
Any suggestions.
I really appreciate your support.
Mohammed
Seems that you are using Firefox (Mozilla) or Chrome on OSX. Try safari, video from cameras works better.
With Chrome I see no video at all, Firefox gives something sometimes after huge delay, with Safari I see the video without any problems.
Actually I use Fluid, with Fluid I have made own browser app (with Safari engine) for HC2. That way I can quit the process when HC2 browser window starts taking ridiculously huge amounts of processor time.
IP camera Hikvision DS- 2CD2632F can be supported with HC2?
Trendnet TV-IP310PI
JPG URL. = /image/jpeg.cgi
MJPG Stream URL. = /Streaming/channels/2/httpPreview
AXIS M3025-VE
JPG URL. = jpg/image.jpg
MJPG Stream URL. = axis-cgi/mjpg/video.cgi
Is the Mobotix D25 compatible with fibaro?
[ Added: 2014-10-07, 15:47 ]
Whats about ABUS Cameras??
Type: TVIP41500
Answer please about Hikvision DS- 2CD2632F ? Be work?
[ Added: 2014-10-10, 13:41 ]
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
Finally I got the Foscam FI8910W and FI8904W with latest firmware working (11.37.2.59 resp. 11.35.2.59).
Since Foscam removed Basic Authentication you need to set up the IP camera's with a workaround:
Camera Model: IPCam (Not Foscam!, won't work)
User:
Password:
JPG path: snapshot.cgi?user=&pwd=
MJPG path: videostream.cgi?user=&pwd=
Turn Left: decoder_control.cgi?command=6&user=&pwd=
Turn Right: decoder_control.cgi?command=4&user=&pwd=
Move Up: decoder_control.cgi?command=0&user=&pwd=
Move Down: decoder_control.cgi?command=2&user=&pwd=
Move Stop: decoder_control.cgi?command=5&user=&pwd=
Good luck!
Does the HC2 or HCL currently only accepts IP camera with MJPEG stream ? What about H264 based IP Camera ? Would it be able to be shown on the iPad or iPhone Fibaro App correctly ?
JPG Path = snapshot.cgi?user=USERNAME&pwd=PASSWORD
MJPEG Stream = videostream.cgi?user=USERNAME&pwd=PASSWORD
Turn LEFT = decoder_control.cgi?command=6&onestep=5&user=USERNAME&pwd=PASSWORD
Turn RIGHT = decoder_control.cgi?command=4&onestep=7&user=USER&pwd=PASSWORD
Move UP = decoder_control.cgi?command=0&onestep=1&user=USER&pwd=PASSWORD
Move DOWN = decoder_control.cgi?command=2&onestep=3&user=USER&pwd=PASSWORD
STOP Camera = decoder_control.cgi?command=5&user=USER&pwd=PASSWORD
Feedback on the camera -
I purchased 6 cameras, 3 connected via wifi 3 didnt. Good picture, quality is good, but Fibaro now needs to step up to H.264.
The biggest disappointment with the camera was the field of vision i.e not a wide angle lens.
I got camera Foscam FI9851P mostly working (besides looking at it via home.fibaro.com, see other thread).
Model: "Other model"
IP-Address:
(<--88)
JPG-Url:
MJPEG-Stream-URL:
There is no movement.
Has any body got TENVIS IP391W HD camera working with HC2/HCL?
I have been trying to Connect With a hik vision 2032 bullet camera .
the mjpeg stream is acsessible With this adress :
+ user /password.
when put into the hc2 nothing happens
Can anyone help me With a setup that Works With this camera .
also tryed With a shitty foscam cam and that worked offcourse..
Somebody has managed to get the withings baby camera to work with HC2?
Thank you.
I have these two working great:
Wanscam AJ-C2WA-C118:
MJPEG: videostream.cgi?user=USERNAME&pwd=PASSWORD&resolution=64&rate=0
JPG: snapshot.cgi
LEFT: decoder_control.cgi?command=4&onestep=5
RIGHT: decoder_control.cgi?command=6&onestep=7
UP: decoder_control.cgi?command=2&onestep=1
DOWN: decoder_control.cgi?command=0&onestep=3
STOP: decoder_control.cgi?command=5
Wanscam HW0021:
MJPEG: videostream.cgi?user=USERNAME&pwd=PASSWORD&resolution=64&rate=0 (640x480 resolution but camera is 720p Fibaro can't handle this somehow)
JPG: snapshot.cgi
LEFT: decoder_control.cgi?command=6&onestep=5
RIGHT: decoder_control.cgi?command=4&onestep=7
UP: decoder_control.cgi?command=0&onestep=1
DOWN: decoder_control.cgi?command=2&onestep=3
I have this Anran camera that i have problem setting up.
IP: 192.168.10.103
Port is: 34567
I put this in the MJPG. But it does not work. If i use VLC this link works fine. But not in HC2.
rtsp://192.168.10.103/user=admin_password=xxxx_channel=1_stream=0.sdp
The JPG colum im not sure, is this needed?
I found this site:
There i found the MJPG that is working in VLC. but if i use this it will not work.
Any idea on this? thanks.
