  • 2
IP cameras compatible with Fibaro - list
Guest sztywniak
I'm creating a thread in which it proposes to collect information about the IP cameras that work with Fibaro.
Please Throw below the IP camera and the path to the streams that you act and I will update this first post.
ACTI
E52
D32
JPG PATH
cgi-bin/encoder?USER=Admin&PWD=123456&snapshot
MJPG PATH
cgi-bin/encoder?USER=admin&PWD=123456&channel=2&GET_STREAM
AirLive
AirLive OD-325HD (non PTZ, Firmware version 5.0.2.6495):
JPG URL: image.cgi?resolution=1280x1024
MJPG stream URL: video.cgi?resolution=1280x1024
AXIS
Axis 207W
Axis 241Q video server
Axis Q7404 encoder
COOLCAM
All no-HD models (PL : wszystkie modele bez HD)
D-LINK
DCS-930L
DCS-932L
DCS-933L
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
MOBOTIX
M12
PANASONIC
Panasonic BL-C131 (PTZ, Firmware version 3.60R00):
JPG URL: SnapshotJPEG?Quality=Standard
MJPG stream URL: nphMotionJpeg?Quality=Standard
Turning left URL: nphControlCamera?Direction=PanLeft
Turning right URL: nphControlCamera?Direction=PanRight
Turning up URL: nphControlCamera?Direction=TiltUp
Turning down URL: nphControlCamera?Direction=TiltDown
VIVOTEK
CC8130
IP8135H
IP8330
IP8332
YUDOR
YDS-04RA-D - video server analog
YDS-09HA - video server hybrid (IP & analog)
YDS-04NA - video server IP
ZAVIO
F312A
Jpg/mjpg stream details of many IP cameras are there in this link, check manufacturer and model
That same topic in polish section
rtsp is not working , you need to use http
Det skal ikke være lett.
Well i can't seem to find the damn link to use
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Seems like my camera is useless then. So saying all IP camera works with Fibaro is wrong.
Who said all Ip Camera's are working with Fibaro ?? , that's wrong .
Until now only mpeg and jpg motion Stream are working
Hope that will change sooner or later.
"Compatibility and the Z-Wave technology
Fibaro offers full freedom of control and communication, as it is compatible with majority of mobile phones available on the market.
Fibaro is compatible with wireless products from nearly 300 independent manufacturers and with all other devices, which may be controlled using systems manufactured by our competitors.
It is compatible with all IP cameras available on the market - upon detecting an incident, the system will send a picture or a video to your mobile phone."
Guest Charly
    + Foscam FI9821EP
    + Foscam FI9828W
    Work both must must set the stream cmd=setSubStreamFormat&format=1 before all works perfectly
    I have 2 Hikvision DS-2CD2132-I that works perfect in HC2, but not in Android phone or tablet.
    MJPG = Streaming/channels/1/httppreview
    Streaming/channels/1/httppreview where do you add user /password ?
    could you also tell me what resolution and settings you use on the camera `s sub stream ?
    640*480, 25 fps.
    User and pass you write in user/pass boxes, above IP and port
    640*480, 25 fps.
    arrg !! i do not get this to work... i do not have the 640x480 option either
    have tried with DS-2CD2032-I and DS-2CD3132D-I should be the same as yours i think.
    See attached pics - see anything that stands out ?
    Are you using port 80 for the camera? If not then you need to specify the port after IP.
    IP:PORT.
    i use port 80 ...
    tnx for trying ..
    Strange..
    Have you tried with lower resolution and quality medium?
    Use ispy to check if you can catch the MJPG stream.
    I use the app "IP Webcam" on my old Android phones and tablets. Works like a charm
    App link:
    Settings:
    IP address: IPaddress:port
    JPG URL: shot.jpg
    MPEG URL: videofeed
    Display camera image at Your House, advanced options:
    JPG activated, Refresh time: 15 seconds
    This is a good way to save money and activate your old devices again
    Got it working for the Hikvision cams now.
    Works in HC2, tablet and phone.
    jpg path: Streaming/channels/1/picture
    Mjpg path: Streaming/channels/1/preview (and not httppreview)
    Anybody have ANY idea which camera plugins use RTSP? a Fibaro developer states on another thread (some plugins use it) I am not buying 127+ cameras to find out which! And they could not afford a 10 second response to me...
    App link:
    Settings:
    JPG URL: shot.jpg
    MPEG URL: videofeed
    Thanx for a great tip. Its good way to start with IP cam to test the possibiities.
    does anyone know if this camera works with HCL ?
    DBPOWER HD023P 720P Camera
    Total pixels 1.3MP
    Video Resolution 1280*720/640*360/320*180
    Compressionformats H.264/MJPEG
    Got my Foscam F19826W working:
    Used Foscam Generic plugin
    Network: IPaddress:port
    Filled the fields username and password
    Control configuration:
    JPG stream path: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=xx&pwd=xx
    MJPG stream path: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=xx&pwd=xx
    Move left path: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=xx&pwd=xx
    Move right path:cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=xx&pwd=xx
    Move up path: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=xx&pwd=xx
    Move down path:cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=xx&pwd=xx
    Stop path:cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=xx&pwd=xx
    this will do until next update were zoom, mic and speaker can be added!
    are you using 4,032 software ? i still can`t get this to work
    /emoticons/default_icon_eek.gif" alt=":shock:" />
    Merit LILIN LR6022
    Firmware: 1.4.36
    JPEG URL: snap1vga
    MJPEG URL: getimage?camera=1&fmt=vga&delay=200
    Merit LILIN IPR6122 (ePTZ)
    Firmware: 1.4.36
    JPEG URL: snap2vga
    MJPEG URL: getimage?camera=2&fmt=vga&delay=200
    LEFT: control?rpan=-7&stop=1&camid=2
    RIGHT: control?rpan=7&stop=1&camid=2
    UP: control?rtilt=7&stop=1&camid=2
    DOWN: control?rtilt=-7&stop=1&camid=2
    STOP: control?home=1&stop=1&camid=2
    ZOOM IN: control?rzoom=-7&stop=1&camid=2
    ZOOM OUT: control?rzoom=7&stop=1&camid=2
    PRESET 1: ptzpreset?goto_preset=1&camid=2 (not tested with this camera)
    Tested:
    Fibaro Home Center HC2 4.032
    Firefox 35.0.1
    Fibaro Android app for Phones 1.4.1
    Samsung Galaxy S4, Android version 4.4.2
    [ Added: 2015-01-29, 12:33 ]
    Also tested with the setup above:
    CP Plus CP-UNC-D1011L2
    Software Version: 3.000.AT00.0.T, build : 2014-11-2
    JPEG URL: cgi-bin/snapshot.cgi
    MJPEG URL (substream): cgi-bin/mjpg/video.cgi&subtype=1
    Would be nice to add these to the supported cameras list as these work perfectly.
