  • 2
IP cameras compatible with Fibaro - list
Guest sztywniak
I'm creating a thread in which it proposes to collect information about the IP cameras that work with Fibaro.
Please Throw below the IP camera and the path to the streams that you act and I will update this first post.
ACTI
E52
D32
JPG PATH
cgi-bin/encoder?USER=Admin&PWD=123456&snapshot
MJPG PATH
cgi-bin/encoder?USER=admin&PWD=123456&channel=2&GET_STREAM
AirLive
AirLive OD-325HD (non PTZ, Firmware version 5.0.2.6495):
JPG URL: image.cgi?resolution=1280x1024
MJPG stream URL: video.cgi?resolution=1280x1024
AXIS
Axis 207W
Axis 241Q video server
Axis Q7404 encoder
COOLCAM
All no-HD models (PL : wszystkie modele bez HD)
D-LINK
DCS-930L
DCS-932L
DCS-933L
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
MOBOTIX
M12
PANASONIC
Panasonic BL-C131 (PTZ, Firmware version 3.60R00):
JPG URL: SnapshotJPEG?Quality=Standard
MJPG stream URL: nphMotionJpeg?Quality=Standard
Turning left URL: nphControlCamera?Direction=PanLeft
Turning right URL: nphControlCamera?Direction=PanRight
Turning up URL: nphControlCamera?Direction=TiltUp
Turning down URL: nphControlCamera?Direction=TiltDown
VIVOTEK
CC8130
IP8135H
IP8330
IP8332
YUDOR
YDS-04RA-D - video server analog
YDS-09HA - video server hybrid (IP & analog)
YDS-04NA - video server IP
ZAVIO
F312A
Jpg/mjpg stream details of many IP cameras are there in this link, check manufacturer and model
That same topic in polish section
Hi all, Dlink dcs5020l remote control not working ....
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />.
I have Hik Vision Camera, compresion: H.264
Model No: DS-2CD2032-I
Can I connect it to HC2?
Foscam 9831W working!
foscam fi9821w and fi9821w v2 is ok but stop command does not work after movement... only stop button fibaro issue?
The Foscam FI9821W V2 works fine with me... Remember to enable the stop command and add the CGI command:
(Use USER and PASSWORD from your camera)
So when you stop pressing arrow ptz stops? Because mine does not on three cameras I have to press stop button!
Yes... It works. when I click on an arrow button is moves a small distance. Are you absolutely sure that you enabled this function?
I noticed when having large network traffic to/from the IP-cam, the stop-command sometimes is not processed by the camera, or a while later. Do you use multiple streams over wireless? Check if you can decrease networktraffic.
EDIT: probably you need to use a IP-cam admin useraccount? I use a separate one.
EDIT 2: Some info about CGI commands:
I confirm that D-Link DCS-5222L ip-cam works fine since v3.580 of HC2 software.
@Fibaro:
Isn't it possible to put a document on your documentation site that contains a list of all supported ip-cameras.
That's much more handy than having to browse a complete thread where everything is mixed.
Zavio F1105 (wired and wireless):
Image URL: /cgi-bin/jpg/image
Video URL: /video.mjpg
axis 212ptz is working, but needs more buttons to use alle features (zomm in and out for example...
We've got two UCAM247 and I managed to get them to work with HC2 but only with the intranet streaming credentials. Therefore, If I am not using the house WLAN/LAN then it wont work.
Anyone using the same camera?
Any thoughts on how to sort that out?
Cannot get video stream from Foscam FI9826W - unfortunately. Cool cam with better video quality compared to dlink 5222L.
I have two LevelOne FSC-0071
anyone haven JPG path and MJPG path
[ Added: 2014-03-01, 22:25 ]
"IP Address (including port if needed):" is this your local IP eg. 192.168.0.....
Axis M1054
Axis M5014
2N Helios IP Vario (ONVIF profile)
All those are working just fine with firmware 3.590
Still looking for camera settings of the brand new Linksys IP Camera.
LCAD03VLNOD 1080p 3M Outdoor Night Vision Dome Camera.
It has 3 streams. first 2 are h.264 streams and third is MJPEG.
Tried Aviosys Kamera 9060 I/O/MP settings from as that works in my IOS app IP Camviewer.
Also EDIMAX H264 settings
My other ACTI Camera's works fine D32 and D11
TRENDnet - TV-IP672WI/PI
JPG Path:
image/jpeg.cgi
MJPG Stream Path:
video/mjpg.cgi
Left:
cgi/ptdc.cgi?command=set_relative_pos&posX=-1&posY=0
(increase the value -1 to -10 to move more per button press)
Right:
cgi/ptdc.cgi?command=set_relative_pos&posX=1&posY=0
(increase the value 1 to 10 to move more per button press)
Up:
cgi/ptdc.cgi?command=set_relative_pos&posX=0&posY=1
Down:
cgi/ptdc.cgi?command=set_relative_pos&posX=0&posY=-1
Stop:
command=stop
I also bought Hikvision DS-2CD2532F-IWS camera
Does anybody know the jpg and mjpeg path for Hikvision cameras?
It seems it uses rtsp .. Is this compatible with HC2 ?
Is Foscam FI8906W compatible with fibaro?
Yes, it is compatible
is there somewhere a ranking of the best (pan/tilt-) cameras working with HC2?
/emoticons/default_icon_eek.gif" alt=":shock:" />
Depends of what you need... (indoor/outdoor, PoE, resolution, wired/wireless, bucks to spend)
