  • 2
IP cameras compatible with Fibaro - list
Guest sztywniak
I'm creating a thread in which it proposes to collect information about the IP cameras that work with Fibaro.
Please Throw below the IP camera and the path to the streams that you act and I will update this first post.
ACTI
E52
D32
JPG PATH
cgi-bin/encoder?USER=Admin&PWD=123456&snapshot
MJPG PATH
cgi-bin/encoder?USER=admin&PWD=123456&channel=2&GET_STREAM
AirLive
AirLive OD-325HD (non PTZ, Firmware version 5.0.2.6495):
JPG URL: image.cgi?resolution=1280x1024
MJPG stream URL: video.cgi?resolution=1280x1024
AXIS
Axis 207W
Axis 241Q video server
Axis Q7404 encoder
COOLCAM
All no-HD models (PL : wszystkie modele bez HD)
D-LINK
DCS-930L
DCS-932L
DCS-933L
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
MOBOTIX
M12
PANASONIC
Panasonic BL-C131 (PTZ, Firmware version 3.60R00):
JPG URL: SnapshotJPEG?Quality=Standard
MJPG stream URL: nphMotionJpeg?Quality=Standard
Turning left URL: nphControlCamera?Direction=PanLeft
Turning right URL: nphControlCamera?Direction=PanRight
Turning up URL: nphControlCamera?Direction=TiltUp
Turning down URL: nphControlCamera?Direction=TiltDown
VIVOTEK
CC8130
IP8135H
IP8330
IP8332
YUDOR
YDS-04RA-D - video server analog
YDS-09HA - video server hybrid (IP & analog)
YDS-04NA - video server IP
ZAVIO
F312A
Jpg/mjpg stream details of many IP cameras are there in this link, check manufacturer and model
That same topic in polish section
+ Foscam FI8907W is OK
+ Foscam FI8910W is OK
Axis 207W
can be both added is working devices
Guest b95_lun
    Vivotek IP8332 (firmware: 0300e)
    JPG
    cgi-bin/viewer/video.jpg
    MJPG
    video2.mjpg
    Guest hotrot_net
    D-Link
    DCS-933L
    DCS-932L
    You can connect any IP camera if you know jpg/mjpg video stream details over Http.
    Try below link to know IP camera video stream details
    We tested dlink,foscam,Zavio
    Useful thread, but for cameras that are not part of the general HC2 camera template it would be a great thread if you included the jpg and mjpg stream url that works with that camera
    + Vivotek IP8332
    + Vivotek FD8136
    This thread can be really usefull for all the users. Can you please add mjpg and jpg paths for the tested cameras? Lets create bigger IP cameras database.
    Foscam FI9821W V2 (PTZ, Firmware version (system): 1.4.1.5):
    (Change 'USER' and 'PASSWORD' with your camera login data)
    EDIT 19-01-2014: When a firmware is updated the GetMJStream command may fail. You have to 'setup' the MJStream function first by using this URL command in your webbrowser:
    hi everybody . i have a hikvision ip camera and i can't find video stream of this camera . in this list
    i can't found my ip camera model. can you help me to find video stream url ?
    Guest imparator
    Dahua IP camera's
    Working model for me IPC-HDW2100P
    Trendnet TV-IP572WI
    JPG URL. = /image/jpeg.cgi
    MJPG Stream URL. = /video/mjpg.cgi
    AXIS M3025-VE
    JPG URL. = jpg/image.jpg
    MJPG Stream URL. = axis-cgi/mjpg/video.cgi
    Guest MitchellOnline
    Foscam FI8906 is also OK.
    Y-Cam Ok
    foscam fi9821w and fi9821w v2 is ok but stop command does not work after movement... only stop button fibaro issue?
    Dahua IP camera's
    I've bought a dahua IP Camera model IPC-HFW2100 (w/o P)
    CAMERA version
    Tipo device IPC-HFW2100
    Versione software 2.100.0001.0.R, build : 2012-10-31
    WEB Version 3.0.0.0
    Camera Settings
    Max Connection : 10
    TCP Port : 37777
    UDP Port : 37778
    HTTP Port : 9989
    RTSP Port : 554
    HC2 Settings
    IP Address (including port if needed): IP:9988 (please note that TCP port is different from HTTP port in Camera Settings)
    MJPG stream path : /onvif/media_service/snapshot?channel=1&subtype=0
    What about drink 5222L IP-cam? Work?
    novos, yes
