IP cameras compatible with Fibaro - list
Guest sztywniak
Guest sztywniak
I'm creating a thread in which it proposes to collect information about the IP cameras that work with Fibaro.
Please Throw below the IP camera and the path to the streams that you act and I will update this first post.
ACTI
E52
D32
JPG PATH
cgi-bin/encoder?USER=Admin&PWD=123456&snapshot
MJPG PATH
cgi-bin/encoder?USER=admin&PWD=123456&channel=2&GET_STREAM
AirLive
AirLive OD-325HD (non PTZ, Firmware version 5.0.2.6495):
JPG URL: image.cgi?resolution=1280x1024
MJPG stream URL: video.cgi?resolution=1280x1024
AXIS
Axis 207W
Axis 241Q video server
Axis Q7404 encoder
COOLCAM
All no-HD models (PL : wszystkie modele bez HD)
D-LINK
DCS-930L
DCS-932L
DCS-933L
FOSCAM
F18620
F18904W
F18905W
FI8907W
FI8910W
F18918W
F19805W
F19821W
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
MJPG stream URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=USER&pwd=PASSWORD
Turning left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=USER&pwd=PASSWORD
Turning right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=USER&pwd=PASSWORD
Turning up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=USER&pwd=PASSWORD
Turning down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=USER&pwd=PASSWORD
Stop movement URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=USER&pwd=PASSWORD
MOBOTIX
M12
PANASONIC
Panasonic BL-C131 (PTZ, Firmware version 3.60R00):
JPG URL: SnapshotJPEG?Quality=Standard
MJPG stream URL: nphMotionJpeg?Quality=Standard
Turning left URL: nphControlCamera?Direction=PanLeft
Turning right URL: nphControlCamera?Direction=PanRight
Turning up URL: nphControlCamera?Direction=TiltUp
Turning down URL: nphControlCamera?Direction=TiltDown
VIVOTEK
CC8130
IP8135H
IP8330
IP8332
YUDOR
YDS-04RA-D - video server analog
YDS-09HA - video server hybrid (IP & analog)
YDS-04NA - video server IP
ZAVIO
F312A
Jpg/mjpg stream details of many IP cameras are there in this link, check manufacturer and model
That same topic in polish section
Hi, I am looking for a wireless IP camera to integrate with my Fibaro system.  Can anyone suggest something which def works?  I have tried a Foscam FI9851P which I cannot get to connect after trying a lot of settings.
thank you
Ianinw, Have you looked the overview I got from Foscam (
) ? FI9851P should work fine
I just added to the HC2 system FOSCAM FI9828P camera. It was quite easy even default settings are not working when FOSCAM is selected from dropdown list. I used commands from Roy's post:
[iPADDRESS:PORT] -> your camera IP, and port is 88
JPG URL: cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=ADMIN&pwd=ADMIN
MJPG URL: cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=ADMIN&pwd=ADMIN
Turn left URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft&usr=ADMIN&pwd=ADMIN
Turn Right URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveRight&usr=ADMIN&pwd=ADMIN
Move up URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveUp&usr=ADMIN&pwd=ADMIN
Move down URL: cgi-bin/CGIProxy.fcgi?cmd=ptzMoveDown&usr=ADMIN&pwd=ADMIN
Stop moving URL: cgi-bin/CGIProxy.fcgi?cmd=ptzStopRun&usr=ADMIN&pwd=ADMIN
I replaced ADMIN with my user & password info. I have stream on iPhone and iPad application and can take snapshots but not in Safari web interface even I installed H264 IPC web plugin. This is still to be investigated. I know, H264 has nothing to do with MJPEG
/emoticons/default_biggrin.png" alt=":D" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />, but I'm going to experiment with HD stream.
Anyway, I still missing possibility to change zoom and focus from applications or arm, disarm motion detection. It would be nice to have these options included in camera device instead of having to use original FOSCAM application and/or write VD to activate motion detection.
thank you
YES D-LINK (DCS-930L)    IT WORKS PERFECTLY
+ Robin SmartView SIP C02050 (door ip phone)
JPG path: /camera/frame.jpeg
MJPEG:  /pbhelper/stream.mjpeg
in addition works great  Robin to Fibaro Rest API and Fibaro to Robin Rest Api
Anyone knows any IP camera which works with HC2 and is able to send towards HC2 HTTP GET request?
I know some of them has sound/movement detection function. Would be nice if such action would be reported to HC2.
I just ordered Netatmo Welcome which is capable to recognize faces. I have heard about very userfriendly API so I hope I will be able to achieve what I am looking for.
When my mother in law will appear at the front door HC2 will warn me
BR
Marcin
Hi Marcnin.  Did you integrate your Netatmo Welcome camera?  I am interested in buying one.  I have seen sites that have integrated status indicators with HC2.
You can connect any IP camera if you know jpg/mjpg video stream details over Http.
Try below link to know IP camera video stream details
We tested dlink,foscam,Zavio
It was great source.Thanks zwaveindia
Elro C903IP (WiFi camera, non PTZ)
Set manufacturer on Foscam
JPG URL: snapshot.cgi
MJPG URL: video.cgi
Foscam FI9903P
Still not working well
2N Helios Vario (IP Video intercom)
As a intercom not working (well), but as a (very expensive) camera it works.
JPG URL:
MJPG URL:
Hi, does anybody has experiences with the camera HiKam S5 ?
She is ONVIF und RTSP compatible...via VLC with rtsp://:@IP-ADRESSE:554/onvif1 works well
but I don't know the fibaro config...
Thanks in advance!
Siqura CD820F Dome camera also works
JPG: cgi-bin/jpg/image.cgi
MJPG: video.jpg?ch=[0]
BCS-DMIP5200AIR (works fine, path to main stream-HQ. No path to Low Q mobile stream):
Jpg:
cgi-bin/snapshot.cgi
MJPG::
axis-cgi/mjpg/video.cgi
BCS-DMIP2130AIR-M :
JPG path failed
MJPG:
As I wrote before, no paths to extra stream (or i didn't found) so picture on mobile phone is still, no practical use of realtime video.
On 19-12-2015 at 8:53 PM, razzano said:
Ho anche comprato fotocamera Hikvision modello ds-2cd2312-i
 non so il  percorso jpg e MJPEG per la telecamera
English please ?
For the Jpeg stream I use : Streaming/channels/2/picture
For the Mpeg stream I use :Streaming/channels/102/httppreview
Hi all,
the settings for Foscam FI9821W V2 doesn't works for me:
Foscam FI9821W V2 Firmware version : 1.5.3.19 :
I have already set:
IP:port/cgi-bin/CGIProxy.fcgi?cmd=setSubStreamFormat&format=1&usr=USER&pwd=PASSWORD
Any hints?
25-01-2017 - I have deleted and added again to network, now it works properly.
Edited by ferra1980
I install Foscam Fi9828p. Picture appears in the browser application on the phone but I do not picture appears. I use iphone app.
Can you help me please ?
Edited by colvs
replace picture
Hi, can anyone help with connection of QVIS IP cameras please??  I have tried the stream urls given on ispyconnect.com but no joy.
Dnia 10.02.2015 o 21:17, D-Vine napisał:
I have a new HD Foscam IP camera FI9853EP
Just ad this camera on my HC2 and get things working
These steps I made with the following settings
Ad device - Camera
Select IP Cam  (no username and password)
advanced settings:
Ad your IP adres with port number
JPEG path:
MJPG path
select JPG
and your cam is rolling.
When selected MJPG it does not work, even the link is working on vlc.
And with selecting JPG with 6 seconds interval you still see camera as roling video - no snapshots.
hope it helps others...
Thank you very much for this instruction. I didn't thougth that login and password should be blank.
Now it's time to make repay for you. To make MJPG start working you have to change source from h.264 to MJPG.
To do this you have to go with this link:
Format = 0 is H264
Format = 1 is MJPG
After that MJPG work under browser and mobile aplication.
Edited by Wildel
Hi guys,
I can not find info on the net about the compatibility between HC2 and the  HikVISION DS-2CD2342WD-I or DS-2CD2T42WD-I. As far as i know both of those cameras have a substream that can be set to MJPEG so in theory they can work with HC2, right? Any suggestions, anyone?
Hi all!
I am looking for an outdoor wireless IP camera to integrate into Fibaro system.  Can anyone recommend a good cam type?
