Netatmo plug-in
Guest Lode
Guest Lode
Is this why Netatmo plug-in stops working after about 3 hours ?
Dear A.Socha, I suppose you had a bad day or I realy suggest to improve your english skills, all in all you are representing a company which sells its products on international market….
Wow, seriously ?
Couple of things, your grammar, spelling and sentence structure are appalling for an English native tongue, and secondly, irrespective of the reasoning behind any response, perhaps you should be a little more accepting of the fact that you are also on their international forum .. All of the contributors write significantly better English than I would write in many of the other languages that are spoken around the world ...
Where's a mod when you need one !
+1 to that Allandee.
+ don't shoot the messenger!!!!
[ Added: 2015-01-28, 21:42 ]
3 wickets and no gloating. Are you really Australian?
robmac, Oh is that game only just over .. I thought it had finished shortly after you turned up
Guest Lode
    Wow, seriously ?
    +2
    ok leaving aside lingiustic innuendos which were lame by it's nature - WHEN is Netatmo gonna be fixed?
    if we had the upload facility we could fix it ourselves
    /emoticons/default_icon_idea.gif" alt=":idea:" />
    For me with 4.033 it is still not showing any data. I never got data into the device from my Netatmo Thermostat. Not for one minute. Temp is alway 19 and all other fields are "--".
    That was one of the reason why I bought this HC2 device
    regards
    Markus
    Hi Markus, did you tryed to contact the support I'm shure they can help you. Since 4.033 release it really works perfectly for all people i'm in contact with including my self.
    I just received the 4.033 yesterday. I kicked the Netatmo plugin out of my HC2 when it was still broken in 4.032. You say it is actually fixed, now?
    mmmh - I will check again - I have created a new App on the developer page now and will try it again. I will let you know...
    regards
    Markus
    hi yeah the netatmo seems to work, it has been 7 hours for me already
    i wonder why fixing netatmo is not advertised at all and stays as urban myth... I would  be all singing all dancing if I was fibaro and fixed that. After all there has been million posts on netatmo:)
    Also happy that it's working.
    I think Fibaro changed the focus to fix the problems
    Only Hc2 and not the plugins. (I hope)
    Even the netatmo version number was not changed
    Nice work fibaro , mine seems to work too
    /emoticons/default_icon_smile.gif" alt=":-)" />) ( sometimes a little communication would be nice
    /emoticons/default_icon_smile.gif" alt=":-)" /> )
    Sure very nice
    I'm going to use the netatmo for the temperature measurement in all the rooms for controlling the heating.
    I still have problems - now I am not getting any device added - just the one saying "Your account is connected".
    In an earlier test I also got a second device showing a template that looked like the values Netatmo Thermostat is able to show. But all fields empty and Temp = 19C.
    Are you also using Thermostat - or the weather station?
    Same few weeks ago.
    When restart of hc2 is not solving the problem
    Removed the app from netatmo and build a new one.
    Guest solarium
    HC2 updated with 4.033.
    The official netatmo plugin did crash after 8 hours ...  polling time was set to 300.
    The pluggin says my account is disconnected.
    This is not an issue at Netatmo Side (because i Can generate my own graph based on the same appId without any problem)
    Working for me since I upgraded to 4.033 friday.
    For me it is only showing this... Anyone an idea? Or am I missing a step in configuration?
    Creating an App on Netatmo developer Page, configure Plugin with Secret and auth-key. Then I have 2 entries in devices - one is the Account and the other one looks like the attached picture...
