I'm installing some Fibaro Roller Shutter modules with Somfy Sonesse 40 motors and some of them stops before, some other stops after the end. I could fix by changing the motor position but I was wondering if there is a way to tell the blind where to start and where to stop...
Any help?
Dem
With my blinds i used the parameter 29 to do the shutter calibration. Just set parameter 29 to 1, the shutter will make the calibration of end points and voila.
    thanks for your answer, I already did the calibration multiple times...the problem is that even with the calibration the blind doesn't go until the floor but stops before...any other suggestion?
    Thanks,
    Dem
    All blinds have limiters. Mine for example have some red small buttons on the motor that you have to twist to set the limits.  Calibration in Fibaro is done after you set the mechanical limits of the blinds.
    Other then that i have no idea, sry
    Thanks, it looks like I have to modify the limiters in the motor...
    Will let you know how it goes...
    Thanks!
    Dem
    Please try some advices from these threads:
    thanks for the reply, I've read them, but in my case the calibration and the positioning work, it's just the blind that stops too early, I think it's because of a wrong set up of the motor's limits.
    The motor come with a tool to change the start and stop limits, I just have to find the time to do it.
    Will confirm it when I'll try it.
    Thanks,
    Dem
    Or it can stop because of inappropriate power threshold that is recognized as limit switch.
    this just to confirm that the calibration in the Somfy Sonesse 40 is VERY easy, there is a tool to rotate 2 sort of screws and you can easily adjust the stop positions...
    Thanks,
    Dem
    Thanks,
    Dem
    Yep!
    There are two white plastic screws in end of the motor. One is for the upper and one is for the lower stop position. Just turn those screws few rounds (one by one) and then test manually where the limit is after that. When you have good limits, calibrate controller in Fibaro.
