Automatic Restart or Reboot Home Center lite
Dear Community,
I have a problem regarding a Home Center lite. After a week the Sensors cannot be armed anymore. As soon as I manually reboot the device everything works fine again. I would like to have a solution so that the HCl reboots automatically. For the HC2 I found some nice LUA Code. I was wondering if this is also possible with a HCl compatible HTTP request.
Thanks in advance for your help
My working command is below and it works since 4.101 beta.
Authorization is in
and it is stands for admin:admin.
Do not forget double enter (2 new lines) after authorization. Also my VD is included in attachement. There you need to change host and authorization.
Authorization is in
yours is different.
you still use POST instead of GET as other people started using with latest fw.
it seems a total mess and mixing fw and examples could be even worst.
And in the VD.vbif file is not set the port that seems to be another important random change
4 minutes ago, Flowy said:
yours is different.
I use port 80. Port 11111 should be usable only if you call as localhost (127.0.0.1), atleast that told me fibaro support.
Also Wireshark gave me it is a POST, when i clicked on Restart button in configuration and cough communication.
Edited by jakub.jezek
mine is 11111 while using real network ip and not local host
I have POST and not GET as latest FW indications from recent topics
I have SETTING instead of SERVICE in the API call
I don't have useless codes 0x0x00xAAxDDxWWx.......
I have FW 4.090
It works (the restart VD but not the firmware).
that is what I mean with total chaos among FW versions....
Edited by Flowy
From 4.101 they changed it. Up to 4.100 it's working like you said. In my VD, i have to just write "settings" instead of "service", if i want to use it in version 4.100 and lower.
That double new line should be in VD with HTTP command.
That double new line separates HTTP body from HTTP head.
Itchy hand went to upgrade from 4.10 to 4.13 & now my restart VD is not working. Can some kind soul please advise?
I had tried on my HCL
IP Address: 192.168.1.10
TCP Port: 80 (also tried 11111)
GET /api/service/reboot HTTP/1.1
(also tried POST /api/settings/reboot HTTP/1.1)
(also tried POST /api/service/reboot HTTP/1.1)
(also tried GET /api/settings/reboot HTTP/1.1)
Host: 192.168.1.10
Authorization: Basic YWRtaW46YWRtaW4=
0x0D0x0A0x0D0x0A (also tried without) (also tried leave 2 blank lines)
Is there way to revert back to 4.10? I tried restoring from old backup copies but it still remained as 4.13 :(
Edited by David Goh
Host: 192.168.1.10
Thanks Flowy.
I'm still not giving up on making the VD restart scene to work in 4.130... lol
5 hours ago, David Goh said:
Thanks Flowy.
That's why I still have 4.090, to not lose the few things I know working....
Any update on this? I do not get this to work ether in FW 4.1.33
Edited by joakim
As discribed in the cookbook, this worked at least in 4.120, have not tried in 4.130.
What i noticed. such a restart is not the same as a hard power off and on with a waiting time of 2 to 3 minutes inbetween. the system lives much longer after such a hard restart compared to a soft restart.
I do the hard restart with a remote controlled wall outlet (dect).
kuno
If you ever get it working let me know as i have the same issue on 4.131 and 4.133
@suds32nz: just tested in 4.130 and as described in the cookbook, this VD works when the scene is triggered and 'pushes' the button of the VD:
GET /api/service/reboot HTTP/1.1                                   # command to be executes
Host: 192.168.1.20                                                           # the local host for the device
Authorization: Basic YWRtaW46cGFzc3dvcmQ=            # admin:password coded base64
        # empty line
        # empty line
the two empty lines are mandatory!
4.133 not working
Host: 192.168.0.22
Authorization: Basic # admin:password coded base64
As @kunoch wrote works for me.
        # empty line
        # empty line
I have FW 4.133
Strange My other VD's dont work either ie simpple one to change a variable that has always worked no longer works, as well as some camera ones.
Only difference from mine to your can be is admin  user - which for me is now an email address (which chamged a while ago with an update)
But very keen to atleast get this one going, any ideas would be appreciated.
All I did is import this VD and change the ip etc
Just sorted this on, I can't use 12.0.0.1 port 11111 had to change it to the Actual Ip and port.
So now just have to sort the others
In my example the admin: password is 'only' representing the administrator login and password, so this has to be exactly YOUR login information.
On ‎3‎/‎7‎/‎2017 at 5:28 PM, David Goh said:
Thanks Flowy.
Ok I gave up as it isn't stable & I had revert back to 4.100
good choice, 4.090 even better.......
I am running 4.134 Beta and can confirm it runs correctly.
By doing the following I can get my HCL to restart on a schedule as a virtual device
To do this:-
First off create a  Virtual Device by going into Devices and selecting 'add or remove a device' the select 'To add the Virtual Device'
In the general tab name the Virtual Device   Fibaro Restart
Add the device into what room you would like it in
Enter your HCL IP address (if you dont know it, look in the configuration tab)
TCP port is   80                            **Previous guides mention it could be 1111 however port 80 works for me under this firmware**
Select the Advanced Tab
Scroll down to the bottom
Label:- Restart
Check the Main button on the right
Enter the below information into the text box **Ensuring you add your own ip and admin:password infomation as explained below)
Host: ***.***.*.**                                                        (Replace the stars with your Home Centre Lites IP address, find this in configuration if you dont know it)
****************************************************              (Replace the stars with your admin:password example myaccount:mypassword coded in base64) get this here
Ensure after you enter your admin:password in base64  that you press enter twice (this leaves two spaces) and then save.
In my example i used myaccount:mypassword as my user and password if you are using the base64 code program correctly, it would give you this as the result:- bXlhY2NvdW50Om15cGFzc3dvcmQ=
So presuming my ip is 192.168.9.9 a working example would be **ensuring to hit enter twice after your base64 code / username&Password**:-
Host: 192.168.9.9
To then create the scene to trigger you can do the following:-
Go to your Scenes tab and select add new scene
Select 'Add scene using graphic blocks'
Click on the '+'. 'Timers > 'Days of week'
Highlight the days you want your HCL to reboot and the exact time you want it to reboot, I reboot each morning at 01:00
Change the 'And' already populated to 'Then'
Click on the bottom '+' > ' Scenes' > 'Room you selected earlier where your HCL is located' > 'Fibaro Restart'
Save your scene
You can test by manually running your scene in the scene tab by pressing play on the scene (also ensure the scene is turned on to to allow the scene to run as per your schedule).
I hope this helps some of you.
CC
Edited by Captain Chaos
