Hi everyone
I want to start a complaint about the Qubino flush relay's still not supported by Fibaro. Still templates are not available for these modules.
I do not know why Fibaro still are not supporting these modules but to my opninion they should starting supporting these by now. Especially keeping in mind all other brands are supported much better.
I did sent templates to Fibaro several times.
A lot of customer have these units, probably because they support energy metering.
So Fibaro, what's goinig on here?
Please reply so we have as many as qustumers possible to put some pressure in Fibaro!
20 answers to this question
I concur.
Guest samuelboerhoop
Guest chaicka
still have them on my shelf waiting ..........
Also unclear to me how to activate the Relay!
Guest chaicka
Count me in...
Give it up guys, Fibaro has a policy of frustrating implementation of 3rd party devices into their HC-software for any modules that they have in their own lineup or somewhere on their roadmap. Fibaro mostly develops top quality modules, but Qubino has introduced some fierce competition.
If you want (rapid) implementation of non-Fibaro modules all the time have a look at alternatives, because Fibaro doesn't work that way.
Since Fibaro stopped producing their FGS-211 and FGS-221, Qubino relays are good alternative as 24V relay. Now, I believe Fibaro working on their own relays with gen. 500 chip (Z-Wave Plus). They could return 24V power to their relays.
But if not, Qubino relays are good alternative for 24 Volt power supply, with similar dimension like Fibaro relays.
Oh no, I stupidly assumed something like a Relay module would work with the HC2 v4.x and went ahead and installed it today.
After a bit of a wobbly inclusion its now sat there but wont react to a on/off button press though the UI.
So +1 for adding support templates. I wont bother submitting them if its already been done months ago.
On/off works for me. Have you tried both master and slave device? Fibaro is a little confused about what is what on quibino devices.
Guest chaicka
Without device template, Fibaro Home Center is detecting the I2 and I3 inputs as sensors instead of switch (refer to the screenshot below).
How can I change the I2 and I3 input to switch?
Don't think you can. And that is also partially qubinos fault. I tried to associate I2 with another relay to turn on a light that did not work because I use monostable switches and the parameter for changing bi-mono stable switch only affect I1 this is also confirmed by qubino support. Sigh...
Guest chaicka
Pardon me.
Monostable switch is those ordinary on/off toggle switch?
Bi-monostable switch is those momentary (press down and it springs back up when release) switch?
Guest fat
Other way around chaicka
Mono is bell press/ momentary
Bi stable has two states on and off (toggle)
Guest chaicka
Thanks. I am pretty sure Qubino Flush 1 Relay should be able to support bi-stable switch for I2 and I3 inputs. It is a matter of how Home Center is incorrectly detecting these two child devices.
Ah you are correct - the slave device is working for on/off with my lights! I just cannot configure anything on it as it's stuck "not configured" and doing a "reconfigure device" greets me with the message "Reconfiguration for the given device is already in progress." from HC2.
