Is there a way for a scene to trigger each time a push button connected to the S2 input on a dimmer with the scene activation setting enabled is activated?
I can only seem to trigger the scene when the sceneActivation state changes. ie: double click after single click.
I'm trying to setup a sensor override push button where the following should occur:
single click = toggle light (on/off) + enable sensor override
hold = start dimming light + enable sensor override
release = stop dimming light
double click = disable sensor override
When the sensor override is disabled, the motion sensor will have control of the light.
Cheers.
I used to have this working fine all over my house. However since updating to 4.081 beta, I have the behaviour you describe. So single press works once, then I need to do something else (eg double click or hold and release) before single click works again. Very, very annoying. Today I am resetting my HC2 and going to an older version.
    Ahh ha! Yeah, I'm running 4.082 beta also. Was having some problems getting sceneActivation going on the newer FDG-212 dimmer modules and thought I'd try the beta. Turns out the problem was not having a load connected.
    Small sidetrack: The old FDG-211 dimmer worked fine with no load but the new version gets stuck trying to auto calibrate the type of load connected. Every time the S1 or S2 inputs is closed, Parameter 13 toggles which is the auto calibration process starting and stopping.
    Hopefully the downgrade fixes it up. Good to know it's not intended to function like that at least!! Thanks mate.
    The supported and recommended way is to attach a Bypass 2.
    You might find this topic interesting:
