thank you in advance for your patience and hopefully support.
I'm a good programmer, I've limited electrician skills but I successfully installed 4 fibaro roller shutters following online tutorials and done some other small electric changes in my home
Now I would like to modify my electrical system adding one Fibaro double relay switch, in order to remotely control two lamps.
Actually each lamp is controlled by two push buttons and one Finder Relay like this one
On each button there are 2 wires attached: 1 common neutral and 1 wire attached to the Finder relay.
What I would like to achieve: replace the two Finder relays with one Fibaro Double Relay in the electric box, and have all 4 buttons still working.
Do you think this is possible?
I attach also a draw made by me with my actual system.
If this is possible, do you have some hints for needed wiring?
Sorry for my non-technical schema
Thanks in advance for your time
Best regards
