LUA - HC2+Nest+Danfoss LC13
I've got a HC2, Nest and some Danfoss-valves, eventually I want a Multi-zoned Heating Systems.
= Modulating through a Nest =
Problem is I live in The Netherlands and out here usually have Modulating Central Heating Systems. So I can't just use The Heating Panel and keep my pipes heated or not according to the outside temperature.
With the Modulating system, I need to control my Central Heating through for example a Nest. I am controlling the Nest through an API, with the help of @TW1979 in topic "
= LUA =
I've read up on the Danfoss-radiator valves. (special thanks to: @tinman@Momos@hTiger1@petergebruers) * They're not that reliable. So before I start with the Multi-zone-LUA, here is my description of the LUA I'm gonna write for the one-room-system.
Can someone tell me if this is gonna work?
Edited by Sardar
Hi @Sardar
I dont know if it will work. Currently i am using the danfoss valves but as you also mentioned, they are not that reliable. I am in doubt too buy the nest as an add-on or replace the valves. Lately I saw this on the internet and i'm very curious about it.
I don't have a modulating central heating but "district heating", dont know if this is the right word. (In Dutch it's called: stadsverwarming, ik zag dat je nederlands bent @Sardar).
This means that I always have the access to warm-water without having my own heating system.
