Dako02 1
Witam
jest stworzony przez kolegę z Germani " Boomx " prosty kod aby uzyskać ip i url do Kamerki Netatmo Welcom.
A że dzisiaj zainstalowałem Netatmo Presence chciał bym wam ułatwić zadanie z dostępem do Presence.
trzeba podmienić poniższy kod w wirtualce dla welkom cam.
function oAuth(nextFunction)
local request_body = 'grant_type=password&client_id=' .. client_id .. '&client_secret=' .. client_secret .. '&username=' .. username .. '&password=' .. password .. '&scope=read_presence access_presence'
dla leniwych cały kod :
%% properties
%% globals
-- DIESE DATEN ANPASSEN wprowadzić swoje dane
local client_id = '55xxxxxxxxxxxxxxxxxxxxxx69'
local client_secret = 'quoLyxxxxxxxxxxxxxxxxxxxtuRlwnpNPbP5'
local username = 'dkonecko@xxxxxxxxx'
local password = 'xxxxxxxxxx'
local language = 'german' -- german/english
-- AB HIER NICHTS MEHR ANPASSEN
local token = ''
local request_body = ''
Debug = function ( color, message )
if (debug == 1) then
fibaro:debug(string.format('<%s style="color:%s;">%s', "span", color, message, "span"))
elseif (debug == 0) then
DebugChange = function ( color, message )
DebugError = function ( color, message )
fibaro:debug('netatmo welcome cam finder v1.0b')
if (language == 'german' or language == 'english') then
DebugError( "green", "Debug: " ..language)
else
DebugError( "red", "Please choose a language for debug")
fibaro:abort();
local sourceTrigger = fibaro:getSourceTrigger();
getResponseData('https://api.netatmo.net/oauth2/token', request_body,
function(data)
if (data.access_token ~= nil) then
token = data.access_token
gethomedata()
else
if (language == 'german') then
DebugError( "red", "oAuth-API-Call konnte nicht durchgeführt werden! oAuth 2.0 lieferte keinen Wert zurück")
elseif (language == 'english') then
DebugError( "red", "oAuth-API-Call Error. oAuth 2.0 returns nothing.")
function getResponseData(url, body, func)
local http = net.HTTPClient()
http:request(url, {
options = {
method = 'POST',
headers = {
['Content-Type'] = 'application/x-www-form-urlencoded;charset=UTF-8'
data = body
success = function(response)
func(json.decode(response.data))
function gethomedata()
request_body_cam = 'access_token=' ..token.. ''
getResponseData('https://api.netatmo.net/api/gethomedata', request_body_cam,
function(getData)
--fibaro:debug(request_body_cam)
if (getData.body ~= nil) then
DebugError( "green", "API-Call durchgeführt.")
DebugError( "green", "API-Call was done.")
for w, v in pairs(getData.body.homes) do
for a, b in pairs(v.cameras) do
if (b.is_local) then
DebugError( "green", "Lokale IP der Kamera gefunden.")
DebugError( "green", "Local IP of cam was found.")
findLocalPresence(b.vpn_url)
else
DebugError( "green", "Lokale IP der Kamera NICHT gefunden.")
DebugError( "green", "Local cam NOT found.")
else
DebugError( "red", "API-Call fehlgeschlagen")
DebugError( "red", "API-Call Error")
function findLocalPresence(url)
local selfhttp = net.HTTPClient({timeout=2000})
url = url..'/command/ping'
selfhttp:request(url, {
options={
headers = selfhttp.controlHeaders,
method = 'GET',
timeout = 5000
success = function(status)
if status.status == 200 then
if status.data ~= nil then
--print(json.decode(status.data))
for k,v in pairs(json.decode(status.data)) do
if (k == 'local_url') then
local cam_url = v
local url_new = string.sub(cam_url, 8, #cam_url)
one, two = url_new:match("([^,]+)/([^,]+)")
fibaro:debug('Cam-IP: '..one)
fibaro:debug('JPG-Stream: /'..two.. '/live/snapshot_720.jpg')
DebugError( "green", "coded 4 siio.de/siio.com")
else
print ("failed")
print(status.data)
end,
error = function(error)
print "ERROR"
print(error)
oAuth()
dane uzyskane w wirtualce jak IP I url do obrazu kopiujemy do zakładki kamera bez użytkownika i hasła.
miłej zabawy.
